Power Door Lock Not Unlocking, for Passenger Doors, Intermittently
Discussion in '2nd Gen Tundras (2007-2013)' started by titaniumman60, Jul 26, 2023.
  1. Jul 26, 2023 at 10:23 AM
    titaniumman60
    titaniumman60 [OP] New Member
    Greg
    2011 Toyota Tundra
    Hello fellow enthusiasts!
    My Tundra is suffering as the title states, but it seems the problem goes away when the temperature rises during the day. Whether I've been driving or just getting in it for the first time, if the outside temperature is very warm (>80F) then all works well, otherwise, it's crawl across the seats or roll the windows down and walk around to unlock passenger door(s).
    The drivers door work as it should, always. The key fob(s) make no difference. They don't unlock when parking and putting trans into P if temp is cooler as well.
    So, I'm thinking relay, but can't find it. Only one I can find is in the fuse box under the hood. (Integration Relay) but it is not labeled as having anything to do with the power windows.
    Suggestions, other ideas?
    Thank you,
    Titaniumman60
    2011 Tundra Dbl Base, 4.6L Auto 4WD
  2. Jul 27, 2023 at 7:15 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    2012 4.6 double cab. I have intermittent loss of door lock/ unlock when there’s too much moisture in the air. Seems like when there’s enough moisture collected then it will act up. Other than that I don’t think I have anything of use to add. Good luck.
