Power door lock issue
Discussion in '2nd Gen Tundras (2007-2013)' started by sbtgrfan, Sep 28, 2017.
  1. Sep 28, 2017 at 5:59 PM
    sbtgrfan
    sbtgrfan [OP] New Member
    Stephen
    Chattanooga, TN
    2023 SR5 TRD Sport 4x4 CrewMax Midnight Black Metallic
    First post, lurked awhile though.
    I've got an '08 Tundra crewmax limited 4WD, lately the driver side door will not lock with the power lock on the fob or the buttons inside except maybe once every 25 tries. I can only manually lock and unlock it. I've googled a lot and sounds like the actuator went bad. Sounds expensive at a shop, so I was able to find an actuator for $100 online that fits. My first question is does this sound like the problem? If so, how easy is it to take the driver door panel off in a driveway and how long should I expect it to take?
    Thanks!
    Stephen
    T-Rex266 likes this.
  2. Oct 10, 2017 at 6:13 PM
    I heard you have connections with insurance carriers. Please confirm.
  3. Oct 10, 2017 at 6:16 PM
    JimBeam
    JimBeam Moderator Staff Member
    South Carolina
    2015 Limited
    Bump for OP's issue/question
  4. Oct 10, 2017 at 6:21 PM
    PermaFrostTRD, Bob and JimBeam like this.
  5. Oct 11, 2017 at 1:07 PM
    sbtgrfan
    Stephen
    Chattanooga, TN
    Too bad those connections don't get me lower rates...
    Thanks
    I appreciate it. Taking the door panel on/off is my only worry.
  6. Oct 11, 2017 at 1:29 PM
    But you get better rates on craft beer, so that’s good enough.
    Also, see if this will be of any help.
    https://youtu.be/vE1Q0_R80Qc
  7. Oct 11, 2017 at 1:30 PM
    Better video here
  8. Oct 11, 2017 at 4:26 PM
    sbtgrfan
    Stephen
    Chattanooga, TN
    That is very true...
    Thanks for the videos, definitely going to help.
  9. Nov 29, 2017 at 8:53 AM
    PermaFrostTRD
    Northern NY
    Is this a common issue??
    My driver door lock just went out too. :eek::confused::mad:
