Power Distribution Block(s) for Ham Radio, Winch, Air Compressor, etc.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mr. Moto, Jan 18, 2021.
  1. Jan 18, 2021 at 12:33 PM
    Mr. Moto
    Mr. Moto [OP] SPIDERMAN, my 2019 Tundra TRD Sport-PRO
    Eastlake, OHio
    2019 Tundra TRD Sport (converted to PRO)
    TRD Pro Shocks (Fox 2.5 internal bypass w/ external reservoirs all around), TRD Pro dual exhaust; Nitto LT285/60R20, TRD off-road skid plates CBI Steel bumper, RC 20,000 lb. winch synthetic rope, BD S1 bush lights, rear floods.
    Greetings fellow preppers,
    I have purchased a Ham radio (Yeasu FT-991A):
    https://www.dxengineering.com/parts/ysu-ft-991a
    and will be mounting it probably in the rear cupholder of my 2019 double cab using a RAP-299-3-C-234-U tablet tray from OC Mounts:
    (https://ocmounts.com/products/ram-a...ZcT-O9TjbpjVriNxXrdb3NCvrzbuA7sBoCvLEQAvD_BwE).
    My Comet CMA-UHV-4 multi-band antenna (10m, 6m, 2m, 70cm) from DX Engineering will be mounted at the left tail light using a mount from Rago Mfg.: I am using a Power Stream PST-SR700 12VDC to 13.8VDC 30A step-up converter:
    https://www.powerstream.com/dc2.htm
    between truck battery and radio and am asking those of you in the know, what is a reasonable power distribution setup under the hood to run power to my radio and any future equipment such as winch and ARB air compressor. I have so far considered a power distribution block-busbar with cover system from Amazon: https://www.amazon.com/gp/product/B07C5SC7TB/ref=ox_sc_act_title_4?smid=A1XKVJCRK1NWP1&psc=1
    I would prefer to consider other options so that I have room for everything, maybe even a second battery under the hood for plenty of power.
    All advice is welcome.
  2. Jan 18, 2021 at 12:39 PM
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
  3. Jan 18, 2021 at 12:45 PM
    Mr. Moto
    Eastlake, OHio
    Hey Scott,
    Thanks for the quick reply. Do you have any photos under the hood?
  4. Jan 18, 2021 at 12:56 PM
    InfernoPRO
    Scott
    Sacramento
    Here is one. If you follow the link to my build in my signature you can see a more detailed Switch-Pros install. I didn’t add the terminal blocks until later. 49CE5713-819B-41A2-A1F8-E0327B3FEA07.jpg
    Mr. Moto[QUOTED][OP] likes this.
  5. Jan 18, 2021 at 1:14 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    These have worked great for me:
    https://www.amazon.com/gp/product/B076C46DP1/ref=ppx_yo_dt_b_search_asin_image?ie=UTF8&psc=1
    I connect my compressor, winch, power inverter, and all other accessories.
    HulkSmurf14 likes this.
  6. Jan 18, 2021 at 1:16 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Forgot to add a pix:
    Mr. Moto[OP] likes this.
  7. Jan 18, 2021 at 1:22 PM
    Mr. Moto
    Eastlake, OHio
    Thanks Cruz,
    I really like that setup. It would be nice if fuse holders were integrated.
    Nice compressor setup too!
  8. Jan 18, 2021 at 1:29 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    :hattip:
  9. Jan 18, 2021 at 2:50 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    For accessories that are lower voltage (<30A) I like using Blue Sea Fuse Panel. IDK how much the air compressor uses but the winch definitely needs to go straight to the battery w/maybe a cut-off between if you want.
  10. Jan 18, 2021 at 3:23 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
  11. Jan 18, 2021 at 3:38 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    ^^fancy-smart...
