Power built unijack
Discussion in 'Off-Topic Discussion' started by Tundra234, Nov 29, 2019.
  1. Nov 29, 2019 at 12:18 AM
    Tundra234 [OP] New Member
  2. Nov 29, 2019 at 12:33 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I can't really tell how it works but as a general rule I never use a jack as a jack stand
  3. Nov 29, 2019 at 12:50 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Mine's been reliable.
    Tundra234[OP] likes this.
  4. Nov 29, 2019 at 5:45 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    There is some chance that the seals in a hydraulic jack cylinder can fail suddenly, allowing a 2-3 ton vehicle chassis to crush you like an egg without jackstands, so it's a good general rule not to EVER trust a hydraulic jack to sustain the load while you're working under.
    This device appears to work like an hydraulic hoist; i.e. as the vehicle is raised by the bottle jack, a mechanical stop trails behind, falling into detents that effectively make it a jack stand, with a built-in bottle jack, that locks-in the last highest detent. To let it down, you'll have to jack it up slightly, release the mechanical stop, then let it down.
    Interesting idea. They are correct about modern vehicles not having space to both jack and support. This device will do both at a single small contact patch. The only concern I would have is the weight (not an issue for you young, strong guys); floor jacks are heavy, but they have wheels for moving to the work area and positioning. Using this will help you get your daily "curls". :D
  5. Nov 29, 2019 at 6:21 AM
    JohnLakeman
    Coffee hasn't hit yet...biggest problem with these is having enough clearance at the lift point to get them under. I need something for a Honda Insight, which probably has 6" ground clearance at the frame lift points. :facepalm:
    TundraDude18 likes this.
