Potential Blown Head Gasket
Discussion in '2nd Gen Tundras (2007-2013)' started by kenomouth64, Sep 30, 2020.
  1. Sep 30, 2020 at 2:23 PM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I pulled back into my driveway after a 20 minute drive through the country where I was "racing and high-revving" my truck quite a few times. Anyway, the truck smelled like coolant and you could hear the coolant overflow reservoir boiling after the truck was shut off.
    Fast forward a few weeks, I had a coolant flush completed as well as the thermostat replaced, and radiator cap. The truck still overheats after a little while.
    Exact symptoms:
    After driving the truck around for 5-8 Miles, you will see the Temperature gauge slowly rise to in between the 'H' and the "Normal operating temperature hash mark". The temperature will drop after idling at a stop sign for about 15 seconds. Thena after take-off, it will start to heat up again. The truck does not overheat from sitting at idle.
    The shop has block tested it three times and it has passed all of them. They did say on the last test there was a slow decrease in pressure but was still in spec. The motor oil is clean and not milky, the exhaust does not smell like coolant, and there are no obvious coolant leaks anywhere, including the water pump and the block.
    At this point I am thinking there are only a few options:
    1. Blown head gasket
    2. Failing water pump or some time of idler pulley causing friction on the serpentine belt
    3. Semi-clogged radiator or collapsing hose
    What do you all think?
  2. Sep 30, 2020 at 2:47 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Air in the system?? My celica would boil coolant due to air in the system until I bleed it, but that is apples to oranges..... Ensure your cap is still good to go and not missing pieces to it.. Double check all your hoses and ensure no cracks or leaks... Not sure what your mileage is, but my water pump blew up at 25k mi. more or less and has been flawless ever since.....
  3. Sep 30, 2020 at 4:09 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Does your recovery tank smell like exhaust?
  4. Oct 1, 2020 at 12:57 PM
    kenomouth64
    Tetrus
    Well, the shop figured out the issue. the exact same issue as detailed here:
    <https://www.tundratalk.net/threads/2011-5-7-coolant-leak.657346/>
    Essentially the valley plate gasket is leaking coolant into the valley of the motor. So the coolant is losing pressure and getting air into the system further making the coolant loss more exasperated.
    Filthyphil likes this.
  5. Oct 5, 2020 at 8:40 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    Interesting, does the valley plate experience pressure from the intake at all? Wonder why beating on it caused it to fail.
  6. Oct 15, 2020 at 7:16 AM
    kenomouth64
    Tetrus
    I am unsure if it receives pressure from the Intake.
  7. Oct 20, 2020 at 7:06 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    probably because heating up to high temps fast and then cool offs a lot just caused it to give way just like any other sealer would.
