Post pics of your Light Bar behind grille on 2nd Gen's
Discussion in 'Lighting' started by Jettech, Jan 4, 2019.
  1. Jan 4, 2019 at 2:48 PM
    Jettech
    Jettech [OP] New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    TRD Exhaust, DC 305/55/20s, TRD PRO Shocks, HID's, JOBOX, Bully Dog Tuner, TRD sway bar, Shorty FM Int,
    Can I see some pics of light bars behind the grill and what kind of bracket systems are you using.
    Stormtrooper81 and sunnysideTRD like this.
  2. Jan 9, 2019 at 11:32 AM
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    I’m curious to see this as well. Please post up some pics!
    Stormtrooper81 likes this.
  3. Jan 9, 2019 at 12:30 PM
    Stormtrooper81
    Stormtrooper81 Slow and steady
    Lost coast
    2011 DC
    X3
    Macreggg likes this.
  4. Jan 9, 2019 at 12:33 PM
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    I've searched but nothing comes up for 2nd gens.
    only 3rds.. or 2.5s or updated 2nd gens. whatever they call those....
  5. Jan 9, 2019 at 1:10 PM
    Rica25
    Ricardo
    Tulare
    The problem with our trucks is that the grille and latch sit to close and to tight of a fit
  6. Jan 9, 2019 at 1:53 PM
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    So this is a no go without a grill replacement?
    Rica25[QUOTED] likes this.
  7. Jan 9, 2019 at 5:01 PM
    Jettech
    Jesse
    Nashville, TN
    08' Tundra CM
    Yes the amount of room seems to be an issue because of the latch system. Do all the 2nd gen's have that latch in that spot?
  8. Jan 9, 2019 at 5:07 PM
    Jettech
    Jesse
    Nashville, TN
    08' Tundra CM
    Here's another. I just cant figure out what they are using for brackets.
  9. Jan 9, 2019 at 6:52 PM
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    That bracket may be mounted to the grill itself.
  10. Jan 22, 2019 at 7:57 AM
    You can get one in there. I had a 20 inch in mine but switched to 4 Rigid pods after my grill swap. I bought the hardware at Lowes and used factory mounting holes. I will get some pics together.
  11. Jan 22, 2019 at 8:15 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Does this count? Not technically behind my grill...but close. I did have to modify the light bar by removing some of the aluminum cooling fins in the rear to clear the hood latch. For a $50 bar from Amazon though I didn't mind doing a little cutting on it to make it fit where I wanted it. I used the brackets it came with.It's wedged in there so the brackets are more to hold it from every coming off.
    MTRock likes this.
  12. Jan 22, 2019 at 9:16 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
  13. Jan 22, 2019 at 9:22 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
  14. Jan 22, 2019 at 3:25 PM
    Jettech
    Jesse
    Nashville, TN
    08' Tundra CM
    Those are close to what I was looking to do but I think I'm going in another direction instead of the bar Im going to make a mount and tie into the radiator support to mount (3) of these 9" led's
  15. Feb 5, 2019 at 6:34 PM
    Here are my Rigids.
    omgboost, SC_TRD, heypal and 2 others like this.
  16. Feb 23, 2021 at 3:07 AM
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Currently going down this road on my truck.. love how clean this came out. What brackets did you use there to mount those pods? I am wondering if I can fit my 30” S8 in this location.
  17. Feb 23, 2021 at 4:44 AM
    It was all hardware from Lowes. I'll snap a picture of the setup today since it is lying in the garage.
    SC_TRD[QUOTED] and Rica25 like this.
  18. Feb 23, 2021 at 7:14 AM
    SC_TRD
    Colin
    Round Rock, Tx
    Awesome, thank you! I thought it looked liked something you threw together, but it also had a very “professional” look to it, so nicely done!
  19. Feb 23, 2021 at 7:28 AM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    Behind the valance makes for a pretty clean look. This is a 43” cali-raised light bar installed on the metal bumper behind the valance. CCA1B710-E796-4569-8BFC-F462DF999F38.jpg
    SC_TRD and toyofan87 like this.
