Post-Lift Driveline Vibration-What Spacer?
Discussion in '2.5 Gen Tundras (2014-2021)' started by lawfarm, Sep 12, 2019.
  1. Sep 12, 2019 at 6:53 AM
    lawfarm
    lawfarm [OP] New Member
    2018 Tundra SR5 Premium TRD Crewmax
    2018 Tundra Crewmax, 4x4, SR5, 5.7L.
    Recently lifted. In the rear, there are 2” lift shackles and a 1” block. I installed the driveline drop spacer that came with the shackles, which is roughly 3/8” thick. I am getting a driveline vibe that starts at low speeds, gets bad around 20mph, tapers off, gets bad from 40-50mph, and then goes away. It isn’t a tire; definitely driveline.
    When I say “gets bad”, I’m being overly dramatic...it isn’t bad, but I can feel it in my seat. What kind of driveline spacers is everyone running with lifts? I searched and could not find much info on spacer sizing. To be clear, I mean a drop spacer on the carrier bearing, mid-driveshaft.
  2. Sep 12, 2019 at 7:05 AM
    15whtrd
    15whtrd Mr. Blonde
    My 2” longer shackles came with a 3/4” spacer for the carrier bearing. Basically I got a 1” lift from the shackles. So if using that formula you are lifted 2 inches. But dropping the driveline and inch and a half seems excessive. I would start experimenting with adding shims until it seems to smooth out.
  3. Sep 12, 2019 at 7:55 AM
  4. Sep 12, 2019 at 8:08 AM
    lawfarm
    Anyone have an idea what size the bolts holding the carrier bearing are? I’ll need to get longer ones...
  5. Sep 12, 2019 at 8:12 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The stock bolt is long enough to add about a 1” spacer.
    Pinay and 15whtrd like this.
  6. Sep 14, 2019 at 11:48 AM
    lawfarm
    Solved: I tried 1” spacers and it was better, but not perfect.
    My local Ace Hardware had M10x1.25 bolts, 70mm long, and some 1.5” thick-wall spacers. Those worked perfectly, and there are no vibrations of any kind now.
    Again, I have 1” blocks and 2” shackle lift. 1.5” spacers worked perfectly for me.
