Possible steering issue question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Robster80, May 31, 2022.
  1. May 31, 2022 at 4:40 PM
    Robster80
    Robster80 [OP] New Member
    Hey guys, im not much on mechanic-ing so bear with me. Ive got a ‘21 tundra and lately ive noticed my steering doesnt feel quite right. Small bumps are noticeably felt in the steering wheel and almost feel like a pop or click at times going over small bumps. Theres no play in the wheel tho. Is this normal or does it sound like a possible issue?
  2. May 31, 2022 at 5:32 PM
    Retired...finally
    Mine doesn't do this. Has your rack been inspected or changed on account of the recall? My first quess would be the rack has been changed and not properly installed.
    Oey12 likes this.
  3. May 31, 2022 at 7:35 PM
    Robster80
    I havent taken it in for a recall i was only aware of a recall for the headlight issue
  4. May 31, 2022 at 7:38 PM
    Lots of things could produce this. Ball joints, tie rod ends, LCA or UCA bushings. Yours being a 21 with an active steering rack recall, I would bet on steering rack. Good luck with this.
    Mike59 likes this.
  5. Jun 1, 2022 at 12:47 AM
    Retired...finally
    Unless yours is a later 21 build you probably aren't affected by the recall. You would have heard about it if you were.
    JDR76 and Mike59 like this.
  6. Jun 1, 2022 at 3:38 AM
    Robster80
    Tracks straight yea. Tire pressure 37 all around. Maybe thats the issue ill let some out and see
  7. Jun 1, 2022 at 3:38 AM
    Robster80
    Yea mines like a 8/20 build i think
  8. Jun 1, 2022 at 4:54 AM
    Retired...finally
    I believe you're good for the PS rack recall unless you happened to have your rack replaced during the last 4 months of 2021.
    I don't believe the PS rack and headlight recall overlapped.
    Your symptoms sound like a steering rack that has become loose.
  9. Jun 1, 2022 at 4:56 AM
    Retired...finally
    Shouldn't be. I'm running 37 ft and 40 rear and other than feeling a toothpick on the road all is well.
  10. Jun 1, 2022 at 4:57 AM
    timsp8
    NY
    Take it in and let the dealer look at it. You’ll most likely get the “I don’t feel it” response so make the mechanic drive with you to point it out.
  11. Jun 1, 2022 at 4:58 AM
    Retired...finally
    Check your lug nuts.
  12. Jun 1, 2022 at 6:59 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Advice above is good, check air pressure, lugs and you may need alignment. Oddly my Tundra has felt firmer/rougher when alignment was off.
    Air pressure in the tires raises with ambient temp, so your tire pressure could be much higher than needed now that the weather is warmer and you will feel that in steering and bumps.
  13. Jun 6, 2022 at 6:40 AM
    Robster80
    Thanks for responses guys. Dropped the tire pressure a bit and that seems to have solved my issue
    frichco228, KNABORES and Oey12 like this.
  14. Jun 6, 2022 at 6:45 AM
    I would still be interested in what was making the popping or clicking sound. The lower air pressure may have softened the ride a bit and made the popping go away, but what was the noise?
  15. Jun 6, 2022 at 7:42 AM
    Robster80
    Yea i may hav the mechanic up the road double check everything in the next day or so and be sure theres not an issue
  16. Jun 7, 2022 at 7:39 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Intermediate steering shaft.
  17. Jun 10, 2022 at 9:57 AM
    codename607
    codename607 New Member
    Chicago
    2024 Tundra
    I had a similar issue with my steering a while back. Clicking and knocking when turning or going over small bumps. I took it into Toyota and they said it was my alignment cam tabs on the lower control arm. Some how they bent at this was allowing the lower control arm to shift.
    I ended up having a shop weld in some metal tabs to give the cam tabs strength. It fixed the problem. I believe Total Chaos makes a product that also fixes this.
  18. Jun 16, 2022 at 6:41 AM
    Robster80
    Do u know what that product is called?
  19. Jun 16, 2022 at 8:16 PM
    codename607
    Chicago
    2024 Tundra
    Yeah it's called Total Chaos Chamber Gussets. You can also get a local welder to fab something up for cheap.
