Possible Mice Damage?
Discussion in 'General Tundra Discussion' started by d_kinneyjr, Dec 20, 2021.
  1. Dec 20, 2021 at 9:32 AM
    d_kinneyjr
    d_kinneyjr [OP] New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    With the warmer weather (in the 60's) here in the Northeast last week, I decide to give the truck a good wash. I opened the hood and noticed something I hadn't seen before. See below picks. My thought would be mice. Has anybody ever come across this? What did you do? And did it keep the mice out of the truck?
  2. Dec 20, 2021 at 9:35 AM
    Blueknights75
    Ron
    Clayton, NC
    Use the search function of the forum and you will find several threads with some great information for your issue…
    d_kinneyjr[OP] likes this.
  3. Dec 20, 2021 at 9:43 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
  4. Dec 20, 2021 at 9:45 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Found one under my engine cap yesterday. Got spun through the cam belts and shredded into pieces. :mad:
    I heard eucalyptus is good? Can anyone confirm?
  5. Dec 20, 2021 at 9:46 AM
    Did you lift the engine cover to see if there is anything under it? Rats will build a nest, not sure about squirrels.
  6. Dec 20, 2021 at 9:47 AM
    My anti-mice/rabbit/squirrel devices.
  7. Dec 20, 2021 at 9:55 AM
    PKFan
    It's hard to say what works, as you're trying to prove a negative. I've recently had some activity under the hood that I suspect was mice or rats (based on droppings), so I've re-started spraying nightly with water with drops of eucalyptus and peppermint (15 drops of each in a quart sprayer). I haven't seen any more tracks or scat since. Just to be safe, I also added mesh to the openings to the cab to prevent any intrusion there (see this thread for details).
  8. Dec 20, 2021 at 9:59 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    check your cabin air filter, little bastard probably got inside.
  9. Dec 20, 2021 at 10:05 AM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    @Tundra234, Yes I did lift up the engine cover and saw nothing. I also gave a good look around the engine compartment for any other damage or nests, and did'nt see anything.
  10. Dec 20, 2021 at 10:07 AM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    @PKFan, Thanks for the info. I may look into this.
  11. Dec 20, 2021 at 10:12 AM
    Tundra1D6
    Things that I’ve found to work for mice, rats, and other associated vermin;
    Dryer softener sheets
    Peppermint oil ( available on Amazon )
    Irish spring green body soap in a bar
    Top cat mouse bait
    Snap traps
    Bitter apple didn’t do jack for me, peanut butter on a spring trap only attracted roaches.
  12. Dec 20, 2021 at 10:19 AM
    d_kinneyjr
    Dave
    Southern NH
    2018 Crew Max SR5
    @Tundra1D6, Thanks appreciate the info
  13. Dec 21, 2021 at 4:52 PM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    Check both filter housings I had a rabbit and a pack rat jump out at me before in customers vehicles...
  14. Dec 21, 2021 at 5:19 PM
    TL TRDPro LR
    TL TRDPro LR New Member
    Troy
    SoCal/Idaho
    2021 TRD Pro Lunar Rock CM
    Def rats! I put out traps and bought some peppermint spray off Amazon - even caught one in my wheel well….9F06E982-0586-45C9-AF20-5CA4EDCEEDFB.jpgE92183CE-F15A-473F-95E3-2EAE1545E267.jpg
