Possible lift
Discussion in 'Suspension' started by Local46er, Jan 16, 2017.
  1. Jan 16, 2017 at 10:17 AM
    Local46er
    Local46er [OP] New Member
    Neil
    Ontario Canada
    2016 Tundra SR5 TRD double cab
    I am planning to get a 6" rough country lift installed. Not sure the tire and rim set up yet but apparently you can run the stock ones. Any input or advice will be greatly appreciated.
    Thanks in advance
    Neil.
  2. Jan 16, 2017 at 10:46 AM
    Hello Neil I have a '14 CM with a rough country 6" lift...I'm running 35*12.50*20 no rub no cab mount chop or trimming...But in all honesty it's a rough ride I don't really like it don't get me wrong it looks great but ride wise No...also your turning radius decreases and I don't like the CV axle angels as well (at joints or where they pivot) I'm saving funds for a TOYTEC BOSS kit I believe 35s fit someone else will chime in good luck
  3. Jan 16, 2017 at 11:46 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I don't have the Boss installed yet, but 35s will fit, but may require CMC depending on your wheel offset. I plan to get it done just to avoid any hassles later on. But plenty of other guys on here that already have it done and could give you better factual info.
    Law323 likes this.
  4. Jan 16, 2017 at 11:52 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    If you really have your heart set on the Rough Country lift, I would log off this site and never come back because you're about to get some strong opinions on why to get something else.
  5. Jan 16, 2017 at 12:01 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    IMO the only reason you go for a 6" lift is if you plan on running 37's. If you want to run 35's, you only need a 3/1 suspension lift (Toytec, Kings, Icon, etc.) with the +12 to +30 mm offset wheels, and you'll likely need aftermarket UCAs.
    CM-LENNY likes this.
  6. Jan 16, 2017 at 12:07 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Save yourself the money and buy something different. Rough Country is cheap for a reason...
    CM-LENNY, Law323 and zcarpenter92 like this.
  7. Jan 16, 2017 at 12:58 PM
    Local46er
    Neil
    Ontario Canada
    Thanks guys. That's why I haven't committed to anything yet.
  8. Jan 16, 2017 at 3:02 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I'd definitely spring for a suspension lift over anything else. IMO a 3/1 lift with 35's looks so much better than a 6" with 35's.
    Can't stand overdone lifts with underdone tires. To each their own, but I'm more of a ride comfort guy and 6" rough country won't give you that.
    3RsDad, CM-LENNY and zcarpenter92 like this.
