Possible causes of consistent surging/hesitation?
Discussion in '1st Gen Tundras (2000-2006)' started by brawleymade, Dec 29, 2023.
  1. Dec 29, 2023 at 4:49 PM
    brawleymade
    brawleymade [OP] New Member
    Socal
    2003 ac sr5 4x4 stick
    Looking for suggestions as I haven’t tracked it down. 2003 4x4 v6 manual trans. I have owned since new and well taken care of. I have consistent hesitation/surging in 4th and 5th gear at moderate acceleration between 2200 and 2900 rpms. Here is recent work.
    maf is good
    Tps is good
    Throttle body is clean as a whistle
    New double plugs, wires and coils
    New cats and 02s due to theft
    New pcv
    No intake leaks
    Newer driveshaft
    was thinking a dead spot on a sensor that I would skip over quick/not notice in first through third gear. Also the hesitation seems to stop if I stomp it to the floor during acceleration. Any ideas?
  2. Dec 29, 2023 at 4:54 PM
    The Black Mamba
    The Black Mamba He must increase, but I must decrease - John 3:30
    Ryan
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    What are double plugs? You should only be using Denso p/n 90919-01166. Not sure if that’s your issue, just something that caught my eye. What parts are OEM and what is aftermarket?
  3. Dec 29, 2023 at 4:55 PM
    brawleymade
    Socal
    Yes oem. Double electrode.
    Mr.bee likes this.
  4. Dec 29, 2023 at 4:57 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    OEM plugs are not double. What other parts that have been replaced are aftermarket? What did you use?
  5. Dec 29, 2023 at 4:59 PM
    brawleymade
    Socal
    There is an actual sticker still on my engine to only use double electrode plugs.
    Mr Badwrench likes this.
  6. Dec 29, 2023 at 5:02 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    OK, forget about the plugs for a minute. You said you have a bunch of other stuff that is new. What brands / part numbers did you replace them with?
  7. Dec 29, 2023 at 5:06 PM
    brawleymade
    Socal
    I always use oem except for the cats as they were 8-12 months out. Hesitation did not come at the same time as the cats though.
  8. Dec 29, 2023 at 5:08 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    Understood. So this hesitation between 2200 to 2900 RPMs only occurs while in 4 and 5th gears and not any other gears?
  9. Dec 29, 2023 at 5:10 PM
    brawleymade
    Socal
    4th and 5th only. But other gears tend to work through that rpm range pretty quickly
  10. Dec 29, 2023 at 5:12 PM
    shifty` In South Dakota Trouble ain't hard to find
    Fuel filter. :bananadance:
    How many miles?
    You have any way to monitor fuel pressure while at those RPM ranges?
    Last person I recall with similar, it was a bad coil pack. And they weren't throwing codes for it.
    Mr.bee and The Black Mamba like this.
  11. Dec 29, 2023 at 5:13 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    You led into what I was about to ask if the answer was yes
  12. Dec 29, 2023 at 5:13 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    ^^^THIS GUY^^^
  13. Dec 29, 2023 at 5:14 PM
    brawleymade
    Socal
    Forgot to mention, I changed the fuel filter. 240,000 miles. Monitoring fuel pressure is on my mind, but wouldn’t that effect gears 1-3?
  14. Dec 29, 2023 at 5:15 PM
    brawleymade
    Socal
    No cel, no codes
  15. Dec 29, 2023 at 5:16 PM
    brawleymade
    Socal
    Changed coils wires and plugs after it started. It was due, no effect on hesitation though
  16. Dec 29, 2023 at 5:18 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Hesitation, then a surge?
  17. Dec 29, 2023 at 5:18 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    Over the next few days, drive at a slower speed through that range of RPMs in the lower gears to see if you can replicate it. It Hass to be engine related and not transmission or speed related.
  18. Dec 29, 2023 at 5:19 PM
    If you're not hitting those RPMs in those gears, maybe?
    If it were me, I've be checking fuel pressure/delivery with my MX+ at those RPMs and compare to similar in lower gears. But let's be honest. It sounds like you're implying it's something from the transmission (well, torque converter) back. And the symptoms could match a torque converter shitting the bed. Transmission shop should be able to tell you.
    FrenchToasty likes this.
  19. Dec 29, 2023 at 5:19 PM
    If this ^^ I'd expect something vacuum related.
  20. Dec 29, 2023 at 5:21 PM
    brawleymade
    Socal
    I’ve tried . Won’t due it. Weird as hell. Its like a am bucking a heavy wind. Accelerates then slows then accelerates then slows, unless I stomp on it, then it just accelerates through. Once above 3000 rpm, no problems.
  21. Dec 29, 2023 at 5:25 PM
    brawleymade
    Socal
    Manual trans. Plan to look into fuel delivery.
  22. Dec 29, 2023 at 5:33 PM
    The Black Mamba
    Ryan
    DFW
    Imma keep it stock
    It is time for every petroleum based vacuum hose to need replacing
  23. Dec 29, 2023 at 5:37 PM
    Whoosh, totally forgot that point from up at the start.
  24. Dec 29, 2023 at 5:38 PM
    I'd almost be tempted just to proactively replace the fuel pump, but I'm a glutton for painful jobs. At 240k miles, the shit has lived a very full life.
  25. Dec 29, 2023 at 5:41 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Injectors?
    i cleaned the injectors on my jeep with a 9v battery & spray can of carb cleaner.
    KNABORES and The Black Mamba like this.
  26. Dec 29, 2023 at 5:45 PM
    Hesitation / surge sounds air management related. MAF, TPS, throttle body, vacuum hoses etc.
    shifty` likes this.
  27. Dec 29, 2023 at 5:47 PM
    brawleymade
    Socal
    this is where I have been with this. Haven’t found a vaccum leak as of yet but will probably start replacing all the hoses tomorrow.
    The Black Mamba likes this.
