Positive battery/wires to terminal
Discussion in '1st Gen Tundras (2000-2006)' started by jakobe1411, Aug 25, 2025 at 1:02 PM.
  1. Aug 25, 2025 at 1:02 PM
    jakobe1411
    jakobe1411 [OP] New Member
    Yesterday
    2000 toyota tundra
    battery crapped out on me. I should have taken a picture before i took everything apart… have the negative side hooked up, but can’t remember how the positive side went due to taking the whole clamp apart, don’t want to make things worse. a little help in the right direction would be appreciated.
  2. Aug 25, 2025 at 1:25 PM
    Calif-Tundra
    Calif-Tundra New Member
    Bob
    2023 Tundra Limited TRD
    First off rotate that clamp 90 clockwise.
    - Large flat connector to one post
    - Other two rounded connectors together on the other post.
    My two cents . . .
  3. Aug 25, 2025 at 1:42 PM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    2003 V8 SR5, Access Cab, 4x4, White
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Umm. You ALWAYS connect the negative terminal LAST! Turn the positive 180 degrees, square ended bolt goes through the terminal horizontally, other two connect where they make the most sense vertically.
    shifty` likes this.
  4. Aug 25, 2025 at 1:59 PM
    jakobe1411
    Yesterday
    2000 toyota tundra
    i got it. thanks
  5. Aug 25, 2025 at 2:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
  6. Aug 25, 2025 at 4:19 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  7. Aug 25, 2025 at 4:38 PM
    bfunke
    South Carolina
    Actually the OEM terminals are kinda cheapo. My previous Toyota I had a gold plated marine terminal and it never got corroded like the OEM ones.
  8. Aug 25, 2025 at 5:11 PM
    shifty` NOT A NU JACK! NU JACK, NU JACK!
    Was going to say this also! Take the neg off. Connect positive last to avoid sparks that could pop fuses and harm electrics.
    Also @jakobe1411 you see that felt donut (they come in red and green) @bfunke is using? You really should have those felts on your batteries to help with corrosion.
    You also need to clean those terminals hanging off to the side with a wire brush before reinstall. Apply di-electric grease.
    I'd recommend a new terminal, I don't think that terminal is factory, but for now, this is where everything goes. Note the plate (purple) should be oriented correctly, I think it goes with the dimple in the valley? And the bolt with orange line is going to use a washer, just like the one with the blue line, and I think the washer is next to the bolt with the red line. Basically red bolt + green nut is what makes the terminal clamp.
    I would:
    • Have the two holes facing to the corner of the battery
    • Loosely install the red/green fasteners
    • Lay the purple part onto the terminal
    • Use the orange bolt (with washer) to lock down connector 1
    • Use the blue bolt (with washer) to lock down connectors 2 + 3
    • You could probably also sandwich connectors 1, and 2+3 between the terminal and the purple plate
    • PS - your evap canister hoses (all the vacuum hoses above the bolts) are fucking rotted to shit! Do you have any codes set currently?
