Positive and negative speaker wire
Discussion in 'Audio & Video' started by Dustinlane, Mar 2, 2018.
  1. Mar 2, 2018 at 8:30 PM
    Dustinlane
    Dustinlane [OP] New Member
    Can anyone tell me which wire on my driver side door speaker is positive and which is negative. I drive 2016 tundra double cab sr5 non jbl. Thanks!
    Y0TA PR0 likes this.
  2. Mar 3, 2018 at 7:03 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome!
    :worthless:
  3. Mar 3, 2018 at 7:12 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    In older times it did not matter which way speakers were hooked up. Not sure if things have changed. Would not think hooking up to see if works either way would hurt anything. If really concerned get a volt meter to check polarity. Good Luck
    NewImprovedRon likes this.
  4. Mar 3, 2018 at 7:47 AM
    15whtrd
    15whtrd Mr. Blonde
    I always wondered if it mattered. I was always anal retentive and colorblind, so I would have to trace the wire all the way back to make sure I had it right. Mostly with those home stereo clear jacketed speaker wires.
  5. Mar 3, 2018 at 7:59 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    It does matter. Bass hits harder when polarity is correct. It can distort when reversed.
    1BadTundra, Les7311, 831Tun and 2 others like this.
  6. Mar 3, 2018 at 8:00 AM
    15whtrd
    15whtrd Mr. Blonde
    This was always my understanding.
    BlueBottle[QUOTED] likes this.
  7. Mar 3, 2018 at 8:47 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Here you go.
    GNTundra, MSTOYTUNDRA and 15whtrd like this.
  8. Mar 3, 2018 at 4:47 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Yes it does matter which way a speaker is wired. If you swap the +/- your speaker will be out of phase. It will be playing in to the door instead of in to the cab.
  9. Mar 4, 2018 at 9:15 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    The earlier posted diagram doesn't match what's in my 2016 Non-JBL. This is an excerpt from the TIS data that matches my truck - Should be the same in yours... Purple is positive, Pink is Negative.
    NewImprovedRon and nk1794 like this.
  10. Mar 4, 2018 at 9:25 AM
    nk1794
    San Jose, CA
    Thanks. Haynes's diagram must be incorrect.
    TundraTex[QUOTED] likes this.
  11. Mar 4, 2018 at 9:27 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Ahh... That's why I like going to the OEM source data.
  12. Mar 4, 2018 at 9:28 AM
    nk1794
    San Jose, CA
    Yeah, I preferred OEM also. How much does it cost?
  13. Mar 4, 2018 at 10:30 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
  14. Mar 4, 2018 at 10:52 AM
    nk1794
    San Jose, CA
  15. Mar 4, 2018 at 3:28 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Thats the same site I used. Try just typing in www.techinfo.toyota.com
  16. Mar 4, 2018 at 3:33 PM
    nk1794
    San Jose, CA
    Same error. Clicked on Subscribe and it redirected me to the site below and got the error.
  17. Mar 4, 2018 at 4:13 PM
    nk1794
    San Jose, CA
    Thank you for confirming that :cheers:
  18. Mar 4, 2018 at 9:06 PM
    the_midwesterner
    Luis
    None, yet....
    It may be down for maintenance. Check during the week. That's the site that TIS is housed in. My iPad goes straight through without issues.
    nk1794 likes this.
  19. Mar 5, 2018 at 1:44 PM
    nk1794
    San Jose, CA
    Success! :bananadance:
  20. Mar 5, 2018 at 1:48 PM
    nk1794
    San Jose, CA
    $400/year. Ouch!:spending:
  21. Mar 5, 2018 at 1:53 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yeah. I usually do the 48-hour for $15.
    nk1794 likes this.
  22. Mar 5, 2018 at 1:59 PM
    nk1794
    San Jose, CA
    Is there a "Print All" option? :)
  23. Mar 5, 2018 at 2:07 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Sadly, no. And the manuals are broken into separate files that you have to save off one at a time. But, it's better than nothing.
    nk1794 likes this.
  24. May 21, 2018 at 11:55 AM
    Tundrastu
    Tundrastu New Member
    Stuart
    Kentucky
    2016 Tundra Platinum Crewmax
    HID retrofit headlights from Lightwerkz, Morimoto LED fog lamps from Lightwerkz. JL audio upgrade from Tech12Volts, Powdercoated factory black wheels local, ESP rear storage trays under seat, bed cover by BakFlip, bed liner, console safe, LED light bar by Back Country. Weathertech floor liners and ventshades. TRD rear sway bar. TRD Pro exhaust, TRD Skid plate, Fortin EvoOne Remote start from Anderson Electronics.
    Not to hijack the thread, but any chance you could provide the listing for speaker wire colors for the JBL system as well? I am about to do a full upgrade but use the factory wiring and I am lost. Thanks!, also in a 2016
  25. May 28, 2018 at 8:27 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    This is for 2014-2018 3rd Gen JBL systems...
    BLONGTX likes this.
  26. May 29, 2018 at 7:02 AM
    Tundrastu
    Stuart
    Kentucky
    Awesome, thanks. Maybe I'll finally get to it this month.
  27. Aug 15, 2018 at 6:45 PM
    J Mole
    J Mole New Member
    2018 Tundra Crew Max
    3 inch lift,Flowmaster cat back duals,35 1250 20’s on black fuels,spray in Raptor Liner
    Do you have this info for the non jbl system...just curious to see if there is a difference
  28. Aug 16, 2018 at 3:22 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    There is a difference. You can find the Non-JBL information in post 29 of my Audio Build thread.
  29. Aug 16, 2018 at 4:48 AM
    Twinky
    07 double cab work horse
    Since i dont have anything to do at the moment i hope y'all dont mind me rambling for a bit...
    Both sides of the cone actually do produce an equal amount of sound. They will be out of phase and when two sound waves of the same frequency meet, they will either cancel eachother out by about half of their output(out of phase), or amplify eachother by 6 decibel (in phase).
    "Speaker Phasing" in this context/application basically means all the speakers that are producing the same frequency are moving outwards and inwards together (This doesnt take into account where the listener is positioned in relation to their distance from each speaker).
    Speaker boxes are used for many reasons and one of their most important is to isolate the rear wave and the front wave of a speaker drive from eachother. So as you could imagine, with two door speakers playing the same material, notes, hurtz, frequency, ect.. But one of them was wired with the negative and positive reversed. It would be like only one speaker was playing. One speaker is creating a pressure wave (moving outward) while the other one actually decreases the pressure at the same time cause it moved inwards.
    You can easily check your phasing a couple ways. Easiest is to simply adjust your balance all the way to either right or left. With your volume set at normal and some music playing gradually start bringing the balance back to center. As you start to near center the volume will noticable increase on its own if you're speakers are in phase with eachother. If it doesnt get louder and stays about the same then you need to switch the neg and pos on one of the speakers. Doesnt matter which one.
    This next way works great if you are mid way into installing a new headunit and dont have a diagram handy. This isnt recommended for tweeters though. You also need to be able to see the speaker cone too.
    Grab a tripple a or double a battery. Connect the two available wires to the speaker. Doesnt matter which one is neg or pos. Now from behind the head unit headunit find those two wires(assuming they havent already been crimped to the new harness that came with you radio) and press one wire to the negative end and with other wire tap it on the positive side of the bat. You will hear the speaker crackle if you have the correct wires. You will also notice the direction the speaker moves when you make contact with the battery pos. If it moves outward then the wire you are holding to the batteries negative side is that speakers negative. The one you touched to the positive side of the battery is the positive for the speaker.
    If the cone moved inward instead, then your neg and pos are backwards.
    Easy peezy, right? Right!.
    I know op already got his answer but i needed to kill some time.
    And accomplished!
    moviepro314, ZPMAN and Stasher1 like this.
  30. Jan 23, 2019 at 5:22 AM
    MSTOYTUNDRA
    MSTOYTUNDRA New Member
    Eric
    2012 Nautical Blue Tundra CrewMax
    I'm trying to navigate through the TIS. could you please tell me how to get to the schematics like this one?
