Portable air compressor
Discussion in 'Wheels & Tires' started by mtman, Nov 12, 2020.
  1. Nov 12, 2020 at 9:33 AM
    mtman
    mtman [OP] New Member
    2020 TRD Offroad
    CBI bumper & skid plates. BD LP6 lights BD S2 Pro LED Driving Combo lights BD Squadron-R SAE LED wide cornering lights
  2. Nov 12, 2020 at 9:37 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Best depends on what you want to use it for. Share a bit more about how you plan to use the compressor...
  3. Nov 12, 2020 at 9:38 AM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    i have a tuff stuff one thats the same as the smittybilt but cheaper. works great.. airs up for 15psi really quick when i get off beach
  4. Nov 12, 2020 at 9:39 AM
    mtman
    2020 TRD Offroad
    For primarily air up and air down on tires only. No air lockers at this time.
  5. Nov 12, 2020 at 9:55 AM
    Sunnier
    Sunny
    San Diego, CA
    Then any of the three will work fine. Or you can grab a cheap-ass portable off of Amazon for <$50. I wore one of the cheapies out (the on/off switch doesn’t wok so as soon as it is attached, it’s “on”, i.e. still works) then installed an ARB twin. Because I want to install locker(s) at some point. Really, it’s just for speed and convenience right now.
    NewImprovedRon likes this.
  6. Nov 12, 2020 at 9:57 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
  7. Nov 12, 2020 at 10:23 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Just a side note, I saw on here that someone made an adapter for the 7-pin trailer plug and powered their compressor from there instead of running it straight off the battery. If i can find the thread, I'll add it to this post.
    Couldnt find the thread, but this looks to be a great solution as long as the compressor has a cigarette lighter adapter..
    https://www.etrailer.com/Wiring/Pollak/PK11896.html
    Here is the pinout if you want to convert the alligator clips to a 7 pin plug:
    mountainpete and Sunnier like this.
  8. Nov 12, 2020 at 10:46 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Viair is quality, but not cheap. I got this one and could not be happier!
