Portable Air Compressor
Discussion in 'General Tundra Discussion' started by JRPro, Jul 5, 2018.
  1. Jul 5, 2018 at 4:14 PM
    JRPro
    JRPro [OP] Snappin’ necks & cashin’ checks
    Rich
    Austin, TX
    17 TRD Pro CM Cement
    What portable air compressors do you all recommend? I’ve been almost sold on the Viair 400P but reading just now it says it can only inflate a 35” tire up to 30psi. I’ve been looking all over and just not finding what I need. Help!
  2. Jul 5, 2018 at 4:34 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I have a 400p and can do much more than that....are you reading an eBay listing or?
    JRPro[OP] likes this.
  3. Jul 5, 2018 at 4:36 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Per their site, max working 150psi.
    As well, a 35" from 0 to 30psi takes 6min.
    Sunnier and JRPro[OP] like this.
  4. Jul 6, 2018 at 9:12 AM
    JRPro
    Rich
    Austin, TX
    That's what I read as well....but maybe I'm just overthinking it. You could easily cram 150psi in a small tire but I was reading it as all it could do is fill a 35" up to 30psi. Reading it differently, it could potential air up beyond 30psi, it would just take longer? The only reason I have any disbelief is because I've used some compressors in the past that when they get to a certain psi, they just can't pump anymore in....which was probably the "max working psi" if I'm understanding correctly. Again, probably just complicating things as usual, but I don't want to get out in the middle of nowhere without being able to air up/down properly.
  5. Jul 6, 2018 at 9:27 AM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    I have the ARB single in my engine bay.. LOVE it!
    joonbug, ccdawnpatrol, ARES and 2 others like this.
  6. Jul 6, 2018 at 12:00 PM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    Masterflow tsunami
  7. Jul 6, 2018 at 12:16 PM
    East TN Yota
    East TN Yota Superhero by Night
    2006 Phantom Gray Tundra TRD Access Cab
    Masterflow here too. I have the cyclone. It's several years old and still going strong.
  8. Jul 6, 2018 at 12:33 PM
    NoKenDo
    NoKenDo New Member
    Ken
    Grand Rapids MI.
    2018 Platinum 4x4 Mesquite Brown
    TRD Pro Suspension. Moonroof. Front window tint. Compustar Pro T11 remote starter. N-FAB running boards Bedrug Bedmat XLT DiamondBack HD Tonneau Weather Tech Window Visors
  9. Jul 6, 2018 at 12:36 PM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    I used 4 x Masterflow connected to 12 gal tanks on my Jeep XJ 33" tires and still not fast enough to air up my tire from 16 PSI to 30-35 PSI.
    I am now carry a portable 20 lbs CO2 bottle and happy so far. Uses it to air up tires and blown dust to setup a tent on the truck bed. It is portable so I also carry with me when taking the gen 2 out or put it in the moho.
    joonbug, aperezsh, Sunnier and 2 others like this.
  10. Jul 6, 2018 at 12:53 PM
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    I’ve had the Viair 400p for over 3 years now. It works great to get my 35’s from around 20-40psi in short order. I think it only takes about 20 mins to do all 4 tires.
    Their claim of 0-30psi in 6 mins is just an example for timing not max psi. I fill my tires up to about 42psi with the Viair every time i get back on pavement.
    14burrito, JRPro[OP] and Sunnier like this.
  11. Jul 6, 2018 at 12:56 PM
    CO2 tank guy here as well.
    I even had the Kilby engine set up and it wasn’t as fast as CO2.
    lionix, Sunnier and 01erionracing like this.
  12. Jul 6, 2018 at 1:17 PM
    jc153
    San Diego
    For speed no doubt CO2 is the way to go.
    I just like the convenience of not having to fill a CO2 tank and just leave the compressor in the truck behind the back seat to use whenever needed.
    Sunnier likes this.
  13. Jul 6, 2018 at 10:06 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I picked this one up today. It's the ARB Single mounted in a plastic tool box called the CKMP12. Took a 33 inch tire from 36 to 40lb in about 30 seconds. 20180706_215438.jpg
    Then I added a tire repair kit and a digital gauge to the box. 20180706_195330.jpgI originally wanted to Mount the compressor in the engine bay but opted for the portable unit so that I could take it in any vehicle. I'm all in for about 400 bucks.
    ARES, aperezsh and JRPro[OP] like this.
  14. Jul 6, 2018 at 10:10 PM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I had been trying to use this little unit that I bought from O'Reilly's Auto Parts. It makes an okay jump box but it completely sucks as a compressor.
  15. Jul 7, 2018 at 5:37 AM
    War Machine
    War Machine SSEM # 5 3MW
  16. Jul 7, 2018 at 9:44 AM
    ZPMAN
    Minnesota
  17. Jul 7, 2018 at 10:43 AM
    Sunnier
    Sunny
    San Diego, CA
    :spy: hmmmn. Jimmy's got a Jeep too....
    01erionracing[QUOTED] likes this.
  18. Jul 12, 2018 at 3:21 PM
    Professional Hand Model
    Hand Protectors
    Free Black and Decker plugs into the power jack when needed. Size of a football and fits in the sidebox. Yew!
  19. Jul 30, 2018 at 6:51 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    that is pretty cool, will that tool box fit under the back seats when folded down ?
  20. Jul 30, 2018 at 6:22 PM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Too tall.
  21. Aug 1, 2018 at 12:16 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
  22. Aug 1, 2018 at 12:29 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    What mount did you use?
  23. Aug 1, 2018 at 3:07 PM
    ccdawnpatrol
    ccdawnpatrol New Member
    Salt Lake City, UT
    2017 SR5 MGM CM 4x4 5.7L
  24. Aug 1, 2018 at 3:23 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    ccdawnpatrol[QUOTED] likes this.
  25. Aug 1, 2018 at 3:27 PM
    ccdawnpatrol
    Salt Lake City, UT
    Cool, I also like the one you quoted up above. Is it powder coated black maybe? I wonder what the cost is too. @itsdchz for reference.
  26. Aug 1, 2018 at 3:33 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    It looks like it had cutouts
