Popping/Thump noise when driving
Discussion in '1st Gen Tundras (2000-2006)' started by Freedom39, Nov 30, 2019.
  1. Nov 30, 2019 at 11:05 AM
    Freedom39
    Freedom39 [OP] New Member
    2006 Toyota Tundra
    I have an 06 Tundra RWD with the 4.7 engine. I've been having an issue with it for a while where there's a weird popping or thumping noise. It seems to be coming from the front side of the truck towards the driver's side. I usually hear it whenever I break, take off or turn. However, it doesn't always do it. I've taken it to 4 different shops and replaced most of the suspension, but it still make the noise.
    So far I've replaced:
    1. Outer/inner tie rods
    2. Upper/Lower Ball Joints
    3. Struts
    4. Stabilizing bar ball joints
    It's bugging me to no end. I took a water proof camera and attached it to the bottom of the truck and drove around in it. I uploaded the video to YouTube.
    Here's the link: https://youtu.be/ipw96sadzm0
    Does anyone have any idea what it could be?
  2. Nov 30, 2019 at 11:15 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    It sounds like something is loose inside the cab... are you in Australia?
    TX-TRD1stGEN and bmf4069 like this.
  3. Nov 30, 2019 at 11:22 AM
    Freedom39
    2006 Toyota Tundra
    Lol no, It's just I had to mount the camera upside down.
    What do you mean something lose inside the cab?
  4. Nov 30, 2019 at 11:27 AM
    Rex Kramer
    Georgia
    I can't tell where the microphone is, but the sound I hear seems more body / interior oriented.
    BTW, that's a good video - maybe check you body mounts.
  5. Nov 30, 2019 at 12:26 PM
    Freedom39
    2006 Toyota Tundra
    It's with the camera. I don't know which side though. How would one check the body mounts? Also, when I drive it i hear it under me, towards the front. And sometimes when it's really bad I can feel it on the steering wheel.
  6. Nov 30, 2019 at 12:28 PM
    Professional Hand Model
    Hand Protectors
    Those 4 bolts missing on the transmission thread? Someone? Seems its an 06 thing.
    Aerindel likes this.
  7. Nov 30, 2019 at 12:44 PM
    Hand Protectors
    I just happened to be catching up on some lost reading here last night from 3 months time spent in the Brasilian Rainforest this past summer... and came across this.
    First time I’ve ever heard of this. Blows me away that all 4 bolts fell out and the transmission didn’t rip off.
    Solution was reinstall new mounting bolts. Applies to 05-06 Tundras and 05-07 Sequoias. Both RWD ONLY.
    Fits your specs on your truck. Hope this is an easy one for you. Check out the link. Report back!
    https://www.tundras.com/threads/clunk-noise-at-low-speeds.51352/
  8. Nov 30, 2019 at 12:53 PM
    Hand Protectors
  9. Nov 30, 2019 at 1:08 PM
    Freedom39
    2006 Toyota Tundra
    Hmm, i checked and there is 1 bolt missing. The other 3 might be loose. I'm going to tighten them and find a new bolt for the other one... hopefully this fixes my issue.
  10. Nov 30, 2019 at 2:15 PM
    Rex Kramer
    Georgia
    It sounded like the clunk was behind the camera...
    FrenchToasty, Sas and Aerindel like this.
  11. Nov 30, 2019 at 2:31 PM
    Hand Protectors
    I couldn’t tell exactly, but from my house it sounded like it was coming from my computer speaker.
  12. Nov 30, 2019 at 2:34 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    This is what I was thinking. The sound seems like it's emanating from somewhere very close to the camera.
  13. Nov 30, 2019 at 2:34 PM
    Rex Kramer
    Georgia
    One must be inverted to enjoy the full effect of this video.
    Professional Hand Model and Sas like this.
  14. Dec 1, 2019 at 6:26 AM
    Hand Protectors
  15. Dec 1, 2019 at 12:46 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    My Dell 17 Inspirion just took that trip from the comfort of my couch inverted which did work better than getting dizzy standing on my head :)
    On seriousness note, any chance you would want to do that at night. I saw something but then glare of light covered the area.
    Rex Kramer[QUOTED] likes this.
  16. Dec 5, 2019 at 5:20 PM
    Hand Protectors
    Hellerr? Did we obtain victory? Or, are we still rumblin bumblin stumblin?
  17. Dec 6, 2019 at 6:34 AM
    Freedom39
    2006 Toyota Tundra
    Nope. It didn't fix it. I replaced all 3 bolts and added the one that was missing. It does seem like the clunking went away, but the popping noise is still there. I'll try to get it on camera again when I get the chance.
  18. Dec 6, 2019 at 3:44 PM
    Hand Protectors
    Maybe you have two separate problems?
    Filthyphil and Sas like this.
  19. Dec 6, 2019 at 4:47 PM
    Freedom39
    2006 Toyota Tundra
    That's what I'm thinking. What could cause a popping noise when breaking, going, and turning? All with it being random with it happening only sometimes.
  20. Dec 6, 2019 at 4:55 PM
    Hand Protectors
    Not sure about popping. Maybe shocks?
    That clunking was for sure heavy loose metal on metal sounding.
  21. Dec 6, 2019 at 5:23 PM
    Take-a-Raptor
    Take-a-Raptor New Member
    Josh
    2012Tundra
    18Method,34tire,FullKings,deaverLeaf
    It could be in your steering box. Could be your wheel hub bearings. I replaced my outer tie rods and that helped some of my issue
  22. Dec 6, 2019 at 5:46 PM
    Sas
    OKC, OK
    At times, especially at the 12s mark, it seems to coincide with a shift in something. You can see the entire stabilizer bar assembly shift abruptly when it happens. But then a little later in the video you hit some rough road and it doesn't make the sound. So it seems like if something shifted, it may have done so early on and only sometimes gets knocked out of that shifted position.
  23. Dec 7, 2019 at 6:18 AM
    Take-a-Raptor
    Josh
    2012Tundra
    I have the same issue but haven’t diagnosed it as far as you have. You should get some real mechanics involved. Toyota master mechanics should be the one to know the answer.
    Another option is to talk to folks in Huntington Beach. Camburg.com They build full out Baja Trucks but they also can just Supe up our Tundra to Baja level. They can also just make it an on road / off road monster for a more reasonable cost. My point is they know there stuff.
    Here my email webmiester17@yahoo.com
    Josh
  24. Dec 7, 2019 at 6:30 AM
    Hand Protectors
    We are all better than Toyota mechanics here Josh. We are internet experts and can diagnose anything from our sofas! See, even a hand model knows he had missing and loose bolts. I can be reached at professíonalmanosmodelos@youwho.com
    revtune, bmf4069, Filthyphil and 2 others like this.
  25. Dec 7, 2019 at 6:35 AM
    Take-a-Raptor
    Josh
    2012Tundra
    Guessing where it could be could be inside the steering box itself. Off road companies sell upgraded gear boxes.
    If it’s body mounts I’d think we’d see separation as you are lowering the vehicle to the ground or Vice-versa.
  26. Dec 21, 2019 at 7:37 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Yep, that is some crazy shit. When my 06 still belonged to my dad I was under the truck looking at how to approach something else we were getting ready to tackle. I happened to look where the trans mounts to the cross member and I told my dad the freakin bolts are missing! We looked at each other in disbelief:eek2: We put new bolts in and the clunk/noise he was complaining about went away. I still have a hard time thinking about it not being bolted down.
  27. Dec 22, 2019 at 4:39 AM
    Hand Protectors
    I checked (2002) mine and they are still there. It was crazy how I came across that one post from back in the summer and then the next day this OP was asking about noises and his truck being 2wd and an 06!
    One would never know these were missing unless you knew to look for them. You must have a good eye to have had to point that one out to your dad. Even the OP mechanics didn’t spot one missing bolt and the others loose.
    revtune[QUOTED] likes this.
  28. Dec 22, 2019 at 10:07 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    I just can’t see how they’d be become loose or fall out. I’m shocked that it didn’t damage the transmission or anything else. Everybody with a first gen should check just to be on the safe side. And yes, I’m glad I happened to look there. I like to inspect things under my trucks from time to time. It’s one of the little advantages of having a lift/level on your truck. I’m able to get under there on a creeper and check everything out:D
