Popping/Settling noise Rear End After Coming To Stop
Discussion in '1st Gen Tundras (2000-2006)' started by tundrainsc, Jan 2, 2020.
  1. Jan 2, 2020 at 5:53 AM
    tundrainsc
    tundrainsc [OP] Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    I just searched an hour for answers to this annoying problem and didn't find an answer. My 2006 Tundra with 160k miles has a slight popping sound coming from the rear when i come to a stop. It remind me of sounds my 61 chevy had years ago when the u joints were worn out. But on the Tundra it not noticeable when shifting the gears back and forth while not moving. I only notice the noise when I come to a stop applying the brakes. I just bought the truck and I have the records. It was service at the Toyota dealership every 5k since new. The front brakes were repadded and resurfaced 40k ago. There is never any mention of the rear brakes in the service records. Could rear brakes be the problem? Do the Tundras have wear indicators built into the pads?
  2. Jan 2, 2020 at 6:04 AM
    tundratim
    tundratim New Member
    tim
    2017 tundra dcab
    if truck is a 2wheel drive need to apply some type of lube to splines on rear yoke on transmission i use caliper grease for this
  3. Jan 2, 2020 at 7:50 AM
    tundrainsc
    06 Limited 4.7 2WD
  4. Jan 2, 2020 at 7:53 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  5. Jan 2, 2020 at 8:43 AM
    tundrainsc
    06 Limited 4.7 2WD
    2 wheel. I just bought the truck one month ago. I went to the Toyota dealer and got all service records, They show this every 5k since it was new.
    OIL AND FILTER - CHANGE
    OIL AND FILTER - CHANGE~|~ ~|~ ~|~157653 PERFORMED LUBE, OIL AND FILTERCHANGE, CHECK AND TOP OFF ALL FLUIDS. CHECK /ADJUST TIRE PRESSURES AS NEEDED AND VISUALLYINSPECT TIRES FOR WEAR AND DAMAGE. PERFORMEDLUBE, OIL AND FILTER CHANGE, CHECK AND TOPOFF ALL FLUIDS. CHECK / ADJUST TIRE PRE
    Would't they have taken care of what you refer to?
  6. Jan 2, 2020 at 8:58 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Could be the u joints or just the one closest to the rear end. Also The 5 speed transmission in these trucks can from time to time have a bump/jerk sensation when you come to a stop or when letting off the gas from a stop. Or is it just noise related?
  7. Jan 2, 2020 at 9:04 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    If your sure it’s coming from the rear. You could also jack the rear up and check the wheel bearings.
  8. Jan 2, 2020 at 11:02 AM
    Professional Hand Model
    Hand Protectors
    Your 2wd 2006 Tundra may suffer from missing transmission bracket bolts. Strangely, only the 2wd and NOT 4wd suffered from this. Should be 4 bolts. I posted up a pic in another thread last week or two and don’t have time to find it.
    2wd plus 2006 missing bolts on trans bracket. Clunk sound fixed... but popping sound?
    Riverdale21 likes this.
  9. Jan 3, 2020 at 4:47 AM
    foxtrapper
    foxtrapper New Member
    2003 SR5
    You’ve drum rear brakes. The noise you describe is typical of the shoes moving against a dry and rusty backing plate. Those contact points on the backing plate are supposed to be clean and lightly lubricated with a high temperature grease, but rarely are. This is not done as part of a typical lube job or inspection.
  10. Jan 3, 2020 at 1:00 PM
    tundrainsc
    06 Limited 4.7 2WD
    This could be the problem. When sitting still, motor running I can switch back and forth drive to reverse and there is no noise. Its when I come to a compete stop depressing the brakes is when i hear the noise. And the noise is a fraction of a second after complete stop as if its a brake shoe or caliper settling against the plate. I will check this out when I have another person to help around. Thanks, foxtrapper
  11. Aug 2, 2020 at 7:12 AM
    tundrainsc
    06 Limited 4.7 2WD
  12. Aug 2, 2022 at 2:52 AM
    tundrainsc
    06 Limited 4.7 2WD
    Thank you PHM This was my problem. Two of the four bolts were missing and the other two were loose enough they would have fallen out eventually. After I tightened the two bolts the noise completely stopped. I now have two bolts and will tighten all four with blue loctite. I should have listened to you two years ago and avoided the annoying sound. I remember crawling under the truck back then and looking. The four bolts are concealed inside the crossmember. and can only be seen from directly underneath the crossmember through four small holes in the crossmember. Not having a lift or ramps i missed them.
    des2mtn likes this.
  13. Aug 2, 2022 at 4:10 AM
    shifty` Animals and insects don't do drugs
  14. Aug 2, 2022 at 5:16 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Hell of a 2 yr anniversary post response but a response none the less.
    shifty` likes this.
  15. Aug 2, 2022 at 5:27 AM
    Ol’ PHM still spreading wurl peas from the great beyond.
    805Tundra, shifty` and des2mtn like this.
