Popping in 4 lo
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jebell4747, Sep 29, 2019.
  1. Sep 29, 2019 at 6:48 PM
    Jebell4747
    Jebell4747 [OP] New Member
    2018 Tundra TSS
    My 4wdin my 2018 works fine, but I’m getting a clunking sound from what seems to be the transfer case when the dial is turned to 4h/4l. Never noticed this before. Anyone else hear this in theirs?
  2. Sep 29, 2019 at 6:50 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Yes it’s normal, it’s the gears engaging, in the manual it says to drive at least 10 miles monthly to lubricate the system. Mine makes a noise but 4wd is working fine so it doesn’t bother me.
    OR18TRD and GODZILLA like this.
  3. Sep 29, 2019 at 7:01 PM
    Jebell4747
    2018 Tundra TSS
    Thanks!
    Samoan Thor[QUOTED] and GODZILLA like this.
  4. Sep 29, 2019 at 7:05 PM
    VietGuy
    VietGuy New Member
    Houston
    2019 Tundra CrewMax Cement
    Where does one go to drive for 10 miles in 4wd? I haven’t touched 4we since I bought it.
    GODZILLA likes this.
  5. Sep 29, 2019 at 8:46 PM
    Danny
    Danny New Member
    2018 Tundra Crewmax SR5
    to and from work for me.
    OR18TRD likes this.
  6. Sep 29, 2019 at 8:48 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    I agree, That’s a lot of miles!
  7. Sep 29, 2019 at 8:48 PM
    What part of Houston are you? Drive along the feeder road don't make any turns though
    15whtrd likes this.
  8. Sep 29, 2019 at 9:07 PM
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Yeah don’t turn on dry pavement, it will bind the system up. Since rainy days are common here in Houston, I normally put it in 4x4 on a really wet day, the wet pavement let’s the tires slip while turning and won’t bind the system up, you’ll get your 10 miles in no time.
    Btw, 4wd launches in the rain are fun lol:mudding:
  9. Sep 29, 2019 at 9:21 PM
    I run along Clay Road to Hwy 6 in 4wd drive, I'm in right lane let others pass me
  10. Sep 29, 2019 at 9:23 PM
    What part of town are you?
  11. Sep 29, 2019 at 9:28 PM
    Tundracollector
    I stay in the heights area by downtown, pretty much can’t go anywhere without turning lol
  12. Sep 29, 2019 at 9:30 PM
    lol true, I'm 290 and Fairbanks
  13. Sep 30, 2019 at 8:49 AM
    VietGuy
    VietGuy New Member
    Houston
    Im on the southeast side down by 146 kemah area.
    is it safe to go 60mph on the highway in 4lo or is there a max speed limit i should stay under?
  14. Sep 30, 2019 at 8:53 AM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    You don't need to switch to 4lo, you can stay in 4hi. No max speed for the 4wd system in high range. In your low range gearbox (4lo) you can only go ~30-35 mph max.
  15. Sep 30, 2019 at 8:56 AM
    Samoan Thor
    Just remember while in 2wd do not switch to 4wd while going more than 60mph, go under then switch to 4hi.
  16. Sep 30, 2019 at 9:14 AM
    Keep it under 5-10 mph, that's me
