Popping Creaking...Skid Plate!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by TravisH, Nov 30, 2021.
  1. Nov 30, 2021 at 7:03 AM
    TravisH
    TravisH [OP] New Member
    Travis
    2019 Tundra TRD Off Road Double Cab
    None
    Hi,
    I started to notice this more and had been trying to pin point the source. I swore it was coming from the CV joint area. I watched videos that suggested skid plate, the TRD Pro one especially, and guys spraying down the front suspension with PB Blaster.... I full time RV and it's been hard to get to a dealership and was wary if they caught wind I was towing and RV may impact warranty.
    Anyways...finally got to dealer and they confirmed...skid plate! Looks like they may have torqued it at some point during maintenance as the tech was showing me almost stripped bolts in the back. I own and use a torque wrench and sure it was not me!
    They checked and found my battery failing so got a new battery for free too!
    400 miles left on 36K warranty and all's well!
    Sumo91, Fotnot and Cruzer like this.
  2. Nov 30, 2021 at 9:43 AM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    What did they end up doing to/with the skid plate to eradicate the squeak?
  3. Nov 30, 2021 at 5:02 PM
    TravisH
    Travis
    None
    Haha!
    Nothing! Since I installed it. They said as I've gathered get some rubber grommets or a hard rubber strip underneath it.
    I assume they didn't want to assume responsibility if it didn't work.
    No problem!
  4. Nov 30, 2021 at 5:22 PM
    Spyker
    yeah I was planning on either running a rubber strip, kind of like a weather strip wherever the skid touches frame, either that or some heavy duty rubber ‘washers’.
  5. Dec 1, 2021 at 2:01 PM
    dkahs05
    dkahs05 New Member
  6. Dec 20, 2021 at 9:26 AM
    TonyNCo
    TonyNCo New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    Hello, I had the same issue recently. The Svc Mgr said that sometimes the techs don't pay attention to the bolts. There is more than one length. As well as, there is a kit to get from dealer. Apparently some of the items are single use when removing. I only had it off myself once. I did not store info in long term. I know when I put it back on, there were no issues. After the dealer messed it up. They owned up to fixing it. Thus how is know about this "kit"... It was all on their dime. I only assume that info is correct. It is back to normal now. No noise.
