Pop sound- cv joint?
Discussion in '2nd Gen Tundras (2007-2013)' started by sbtgrfan, Jan 21, 2023.
  1. Jan 21, 2023 at 8:06 PM
    sbtgrfan
    sbtgrfan [OP] New Member
    Stephen
    Chattanooga, TN
    2023 SR5 TRD Sport 4x4 CrewMax Midnight Black Metallic
    When I’m reversing in and out of a parking spot I get one pop sound coming from the front end. This only happens in reverse. Does this sound like a cv axle issue? It started right after I had my shocks/struts replaced.
  2. Jan 21, 2023 at 8:16 PM
    2mchfun
    Could be lots of things, I'd start having a good look around and see if everything looks to be proper.
  3. Jan 21, 2023 at 10:16 PM
    Dank
    Dank New Member
    2010 Black Tundra 4wd
    Did you replace your upper or lower control arms when you had your struts replaced? Could be those.
  4. Jan 22, 2023 at 6:09 AM
    sbtgrfan
    Stephen
    Chattanooga, TN
    Everything looks normal to me. Nothing looks out of the ordinary.
    I did not replace the upper or lower control arms. I’ll take a look at them today.
  5. Jan 22, 2023 at 6:18 AM
    2mchfun
    Only in reverse????
  6. Jan 22, 2023 at 6:22 AM
    2mchfun
    Check out the motor and transmission mounts as well as u joints on the rear driveshaft, I suspect it may be a coincidence issue of sorts and nothing to do with the shocks. Maybe it was happening all along and you thought it was the shocks??
  7. Jan 22, 2023 at 6:24 AM
    This would only be possible if you are in 4wd. Otherwise, all signs point to the new suspension bits.
  8. Jan 22, 2023 at 6:32 AM
    2mchfun
    Check front differential mounts as well
  9. Jan 22, 2023 at 6:32 AM
    2mchfun
    Check brake caliper mount points too
  10. Jan 22, 2023 at 6:35 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Loose cam bolt(s) on the LCA(s)??
    2mchfun likes this.
  11. Jan 23, 2023 at 5:58 AM
    sbtgrfan
    Stephen
    Chattanooga, TN
    Only noticeable in reverse. Ujoints are relatively new, less than a year. All mounts look normal. Going to go over the control arms closer this afternoon but everything else looks normal.
    2mchfun[QUOTED] likes this.
  12. Jan 23, 2023 at 5:59 AM
    sbtgrfan
    Stephen
    Chattanooga, TN
    CV joint issues only present in 4WD?
  13. Jan 23, 2023 at 6:06 AM
    2mchfun
    No, cv shafts are in rotation if the truck is rolling.
  14. Jan 23, 2023 at 6:09 AM
    2mchfun
    Whatever you figure out, please post it here for the next person to reference. Thanks!
  15. Jan 27, 2023 at 9:55 PM
    Sierramare’
    Sierramare’ New Member
    Ted
    Alaska
    2007 SR5 DC 4wd
    i had popping sounds from the front after getting a front alignment recently. Sounds were noticeable at slow speed loading/unloading of the front when braking/accelerating. Came to find out that one of the LCA alignment bolts hadn’t been torqued to spec.
    landphil[QUOTED] likes this.
  16. Jan 31, 2023 at 3:59 AM
    sbtgrfan
    Stephen
    Chattanooga, TN
    Took it to my local shop after I couldn’t find anything myself and it turned out to be the cv axles after all. They said they had enough play in them to cause the issue, so they replaced. Sound fixed.
    FrenchToasty and KNABORES like this.
  17. Jan 31, 2023 at 4:41 AM
    pyrite12
    pyrite12 New Member
    NY state
    2021 Silver Sky TRD DC
    yep...had this with my 2012. Boot had torn and the grease had leaked out all over. Only heard the popping when pulling out of my parking spot at work.
  18. Jan 31, 2023 at 4:46 AM
    Thanks for reporting back. Glad they got your issue fixed. My CV that went bad drivers front only made the horrible clicking noise when under load in 4wd. It was quiet when disengaged. They do spin all the time as we don’t have locking hubs. Hopefully your experience will help someone else when they run into the same thing!
  19. Feb 10, 2023 at 4:32 AM
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    how much did they charge if you don’t mind??
    thank you
  20. Feb 15, 2023 at 5:35 PM
    sbtgrfan
    Stephen
    Chattanooga, TN
    It ended up being right at $1000 but I had a few other minor things done as well.
  21. Feb 16, 2023 at 8:11 AM
    KeepOnTruckin
    KeepOnTruckin New Member
    Randy
    2010 4.6 4x4 Bare Bones
    IME an unloaded CV has to be real bad shape to ever make a noise. If in a parking lot and wheels at full lock left/right they can make a continuous popping sound which shows wear and need for replacement.
    Because they had to pull the suspension apart to get the axles out, I'm betting they tightened whatever was loose when assembling it. (loose shock mount?).
    Why am I thinking this way? More often than not we are steering when backing up and this loads sway bars, shocks, control arms inducing force that leads to a pop when something is loose.
    I'm saying this because it didn't do it before parts were replaced and started after parts were replaced which seems to point to the work done.
    Whatever the case, im glad it's fixed.
    JLS in WA likes this.
  22. Jul 25, 2023 at 11:12 AM
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Did you get a brand new preassembled CV axle or did you use the repair kit with new rubber boots and grease packs?
  23. Jul 25, 2023 at 11:18 AM
    In my ignorant exuberance, I purchased a pair of what appeared to be beefy aftermarket CV axles from Advanced auto with lifetime warranty. I (sheepishly admits) got rid of my OEM CV axles. The aftermarket axle joints have held up very well, the boots however are crap. They split open after a few years and I have already swapped them under the lifetime warranty. They need to be replaced again, but I may just reboot them.
  24. Jul 25, 2023 at 11:20 AM
    monaco730
    16 Inferno Tundra
    My passenger boot is busted and leaking and i ordered the repair kit from Toyota because i've heard toyota CVs are much better than aftermarket. But i have noticed the pop noise and I'm not sure if that means i need a brand new CV axle and not a repair kit.
  25. Jul 25, 2023 at 11:27 AM
    You'll know when you get it apart.
    monaco730[QUOTED] likes this.
