Pop or click sound only after truck sits
Discussion in 'General Tundra Discussion' started by Blackrr, Jan 15, 2019.
  1. Jan 15, 2019 at 3:31 PM
    Blackrr
    Blackrr [OP] New Member
    2016 Inferno SR5 TRD
    2016 Tundra SR5 TRD makes one pop, click or whatever you'd like to call it after truck sits for a little while when first taking off. This is the only time I hear it so doesn't seem like the skid plate issue I've read about. Anyone else had this issue?
  2. Jan 15, 2019 at 3:32 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    ABS self check, not an issue youll get used to it.
  3. Jan 15, 2019 at 3:33 PM
    Blackrr
    Thanks, strange I haven't noticed it before though. Maybe music has been loud enough in the past I didn't notice
  4. Jan 15, 2019 at 3:38 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yep, ABS self check
    Blackrr[OP] likes this.
  5. Jan 15, 2019 at 3:42 PM
    AZTundra
    Paul
    Phoenix, AZ
    Mine will sometimes make a pop/click after backing out of the driveway and shifting into drive. Right as you move forward it makes the noise, but only once in a while. Is this the same noise (ABS self check)?
  6. Jan 15, 2019 at 3:52 PM
    15whtrd
    15whtrd Mr. Blonde
    Right around 15mph? If so, yes abs self check. Mine does it. Mine also creeks when I launch off the line. But that’s my driveshaft I’m pretty sure.
  7. Jan 15, 2019 at 3:55 PM
    AZTundra
    Paul
    Phoenix, AZ
    The noise is immediately once you hit the gas and start to move. Only happens once in a while usually in the morning when leaving for work maybe 1-2 times per month.
  8. Jan 15, 2019 at 4:04 PM
    15whtrd
    15whtrd Mr. Blonde
    Id guess it’s what mine does. I chalk it up to drivetrain creak.
  9. Jan 15, 2019 at 4:14 PM
    Warreng
    Warreng New Member
    Mine does it too, i just believe what everyone says here and tell myself its normal
