Pop and lock 8535 on 2019 tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by shawn474, Feb 1, 2020.
  1. Feb 1, 2020 at 2:33 PM
    shawn474
    shawn474 [OP] Lego connoisseur
    MoCo, Maryland
    I have the wires run and the actuator installed and hooked up. I am getting conflicting opinions on which wires to splice into at the kick panel. There is the pop and lock green and blue wires but not sure which harness to connect to and which wires at the kick panel. Can anyone help?
    In the pop and lock instructions it says to connect the blue P&L wire to the red wire of the blue 18 pin MJ1 connector. It says the green wire should be connected to the white with silver dash wire is the blue 18 pin MJ1 connector. I have read that others have said blue goes to white with silver dash and green goes to orange with silver dash wire. Before I go splicing into the harness I would love to know if anyone has a 2019 tundra crewmax with pop and lock 8535
    Installed and can let me know what the actual wiring configuration is???? Also pics would be awesome if available. Thank you very much in advance for anyone who can advise.
  2. Feb 2, 2020 at 3:31 AM
    shawn474
    MoCo, Maryland
    Anyone? Trying to get this done today
  3. Feb 2, 2020 at 3:46 AM
    Crewmax808
    Crewmax808 New Member
    Honolulu, Hawaii
    2016 Sunset Bronze Mica Tundra Crewmax
    TRD Swaybar, 20"Black Rhino Traverse wheels wrapped in Toyo Open Country ATIIs, Bilstein 5100s on all corners, BAKFlip MX4 Bedcover
    you should buy this harness from KTJO 4x4. She makes the entire kit, and I believe she also sells just the parts that you need as well. Check out her thread, 3rd gen Plug n Play Power Tailgate Lock...
    rodm1 likes this.
  4. Feb 2, 2020 at 3:59 AM
    Crewmax808
    Honolulu, Hawaii
    this is a photo a fellow member (AZTundra) posted on another thread, if you don't have the harness or don't have the time to get one right now. Hopefully this will help you!
  5. Feb 2, 2020 at 4:03 AM
    Crewmax808
    Honolulu, Hawaii
    Oh, another note also, AZTundra has a 2017 Crewmax I believe... just an FYI.
  6. Feb 2, 2020 at 4:11 AM
    Crewmax808
    Honolulu, Hawaii
    Let me know if any of that helps or worked for you. I know how it feels. I was getting frustrated with my install until some fellow members helped me out!
  7. Feb 2, 2020 at 4:41 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    You might check out this youTube video. I installed a Pop-n-Lock on a 2017, and the blue and white wires were correct but could be reversed. I cannot verify that this video is correct, but the red/orange descriptions seem to confirm that Toyota has changed the wire colors for the door locks yet again. The wires used appear to be in the same cavities in the blue connector.
    https://www.youtube.com/watch?v=gyBk01IWuE4
  8. Feb 2, 2020 at 4:46 AM
    shawn474
    MoCo, Maryland
    thanks man; appreciate the help
    Thanks very much. this is what has me confused; guess I will try the 2018 wiring scheme first....
    JohnLakeman[QUOTED] likes this.
  9. Feb 2, 2020 at 5:19 AM
    shawn474
    MoCo, Maryland
    I would buy it if I didn’t already have everything ready - not really a patient person. And, I don’t want to spend another $45 for the harness. I probably should have just bought the ktjo kit in the first place to save time and money.
  10. Feb 2, 2020 at 6:06 AM
    shawn474
    MoCo, Maryland
    For anyone interested, 2019 Sr5 crewmax I can confirm:
    Green pop and lock wire to red with silver dash Toyota harness wire
    Blue pop and lock wire to white with silver dash Toyota harness wire
    Works like a charm and Yes it is loud but doesn’t bother me at all.
  11. Feb 2, 2020 at 7:18 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Thanks for posting! It is sure to help others.
  12. Feb 2, 2020 at 8:57 AM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    Any chance you have a photo for anyone thinking of doing it? I know I’m a visual person haha
    Thanks for letting everyone know
  13. Feb 2, 2020 at 10:30 AM
    shawn474
    MoCo, Maryland
    Unfortunately I was rushed to get ready to go to the capitals / penguins game so I just buttoned it up and left. It will take me 30 seconds to pull the panel though. I will take it off and snap a picture when I get a chance though. Also, do NOT go through the engine firewall. There is a drain plug on passenger floorboard that comes right up in the area needed to tap into harness. Pulled the plug, made a quick snip, pulled wire through and replaced the plug. Easy peasy lemon squeezy!
    posting from the caps game - that’s dedication!!!! Hahaha
  14. Feb 2, 2020 at 12:26 PM
    JohnLakeman
    See post #7. Photo for the visual, video for those needing more.
