Poor Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by 00PS, Aug 4, 2019.
  1. Aug 4, 2019 at 6:51 AM
    00PS
    00PS [OP] New Member
    2016 Barcelona Red Limited Crewmax TRD 4x4
    Thought you all might get a kick out of this. I think he’s a little overloaded...
  2. Aug 4, 2019 at 7:00 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Good heavens! They make hitches to stop that....
    15whtrd, Prostar 190 and Tundrablue like this.
  3. Aug 4, 2019 at 7:03 AM
    Tundrablue
    Dave
    Ohio
    :eek: Wow, that’s just dangerous and irresponsible.
  4. Aug 4, 2019 at 8:12 AM
  5. Aug 4, 2019 at 8:31 AM
  6. Aug 4, 2019 at 8:37 AM
    BlueDream, TTund16, Paul B and 8 others like this.
  7. Aug 4, 2019 at 8:42 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    People see that and it gives Tundra a bad name
  8. Aug 4, 2019 at 9:53 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Good Lord!! That's gotta drive like crap!! He'd probably be fine with a WDH...
  9. Aug 4, 2019 at 10:00 AM
    Dank1296
    Dank1296 New Member
    JC
    2015 Grey Tundra SR5
    Nerf Bars
    Hopefully just moving it a short distance after buying
    Black Wolf likes this.
  10. Aug 4, 2019 at 10:08 AM
    15whtrd
    15whtrd Mr. Blonde
    A raised hitch and weight distribution set up would help that tremendously. It also looks even worse because he’s leveled.
  11. Aug 4, 2019 at 10:15 AM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Hey if it can pull the space shuttle, it can pull a travel trailer...….
    bvia and Black Wolf like this.
  12. Aug 4, 2019 at 10:27 AM
    Grumpy Uncle
    Pat
    CO
    Darwin has patience, not compassion.
    TTund16, landphil, Black Wolf and 2 others like this.
  13. Aug 4, 2019 at 10:31 AM
    TRDProLife
    TRDProLife LETS GO BLUES
    St.Louis
    Barcelona Red Metallic TRD Pro Tundra
    Window Tint, ICI Magnum Steps, firestone spring helpers for towing, 295/70R18 Atturo Trsil blade X/T's
    He's definitely doing it wrong.
  14. Aug 4, 2019 at 10:39 AM
    15whtrd
    15whtrd Mr. Blonde
    That has to be one of my favorite GIFs to use! So perfect
  15. Aug 4, 2019 at 12:32 PM
    Reno138
    Reno138 New Member
    Reno
    2013 tundra 5.7 4x4
    None
    Hello all! I just signed up here because of this post. This photo looks like it's not too far from where I live. I saw a black tundra with a trailer and thought it might be me. Luckily, it's not me.
    Is it normal for tundras without the tow package to sag like that? I wouldn't imagine that trailer has enough weight at the tongue to cause that. Mine has 700ish and it just levels the truck.
    Also, OP, is this 380 around McKinney Texas?
  16. Aug 4, 2019 at 12:58 PM
    00PS
    Close! The 380 and 423 (edge of Prosper)
  17. Aug 4, 2019 at 1:43 PM
    Reno138
    Reno138 New Member
    Reno
    2013 tundra 5.7 4x4
    None
    Yep. After thinking about it, that cvs marked the spot. I can't imagine trying to get down these wavy, bouncy, and crowded roads with a rig like that.
  18. Aug 4, 2019 at 4:27 PM
    Sp33dNut
    Sp33dNut New Member
    2019 White Tundra DCOR
    That’s awesome. I’m pretty sure TRD engineers didn’t have this in mind when they installed the headlight height adjustment.
  19. Aug 4, 2019 at 4:35 PM
    Mr Badwrench
    Mr Badwrench New Member
    ... meanwhile... Nobody can figure out why their auto insurance is through the GD roof.
  20. Aug 4, 2019 at 8:03 PM
    He’s good...:rolleyes:
    There has to be a point when everyone has the light bulb go off....right?
    landphil, 15whtrd and Black Wolf like this.
  21. Aug 4, 2019 at 8:09 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    That trailers door steps are like... :eek2:
  22. Aug 4, 2019 at 8:13 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
  23. Aug 4, 2019 at 8:14 PM
    BIGUGLY
    Paul
    2018 Limited
    New meaning to the word fucktard.
  24. Aug 4, 2019 at 8:59 PM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    Depend on your definition of fine. That travel trailer looks like a hog, even if wdh added. Gotta be in the 30's + (I'd bet) without including the tongue length. I'd guess that truck's about maxed unless that thing is stripped. Tundra's tow great, but even with my confidence and a wdh, I would not want to tow that set up any great distance.
  25. Aug 4, 2019 at 9:32 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    One light bulb or two
    Maybe a red and a blue
    Here I’m a poet
    And you didn’t know it.
    :D
  26. Aug 4, 2019 at 9:37 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Pretty sure he has a WDH but it’s not hooked up! And even if it was....the hitch head isn’t adjusted right anyways, needs rise not drop! It would probably tow fine if it was actually connected
    15whtrd likes this.
  27. Aug 4, 2019 at 9:48 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Easy fix ;):
    BlueDream, 15whtrd and realtorblake like this.
  28. Aug 4, 2019 at 10:12 PM
    15whtrd
    15whtrd Mr. Blonde
    :rofl::rofl:
    BlueDream likes this.
  29. Aug 4, 2019 at 10:47 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Not really much more to say
    landphil and JH5370 like this.
  30. Aug 4, 2019 at 11:56 PM
    TXTundra2722
    2015 Black Tundra
    But....I don't understand it you guys, the front of my trailer tires are wearing out faster than the rear ones are.
    :D:D
    15whtrd likes this.
