Poor gas mileage on a 2005 Access cab 4.7
Discussion in '1st Gen Tundras (2000-2006)' started by VanIsle1stgenTundra, Nov 26, 2022.
  1. Nov 26, 2022 at 3:08 PM
    VanIsle1stgenTundra
    VanIsle1stgenTundra [OP] New Member
    2005 TRD Access Cab
    Off-road front bumper, rims, winch.
    Recently bought a 2005 4.7L v8 and it’s having worse gas mileage than it should be. I’m getting 160km for half a tank. Most recent fill up on gas came to 43L/100km. Is this normal? Odometer is reading 283000kms. Is there anything I can do or check on? Also experiencing a coolant leak.
  2. Nov 26, 2022 at 4:12 PM
    Aerindel
    Aerindel New Member
    Montana
    Pretty normal. Today I had 101 miles on 10.9 gallons, which read as half a tank (even though a true half tank is a couple gallons more)
    Its winter here so I've had it idling a bit and plowed the road once so thats a bit worse than I normally get, but not dramatically so. I also have oversized tires so that doesn't help.
    Welcome to the club.
    Morgan likes this.
  3. Nov 26, 2022 at 4:25 PM
    Morgan
    Morgan New Member
    04’ access cab sr5 trd 4x4, 21’ crew max sr5 trd 4x4
    My 2004’ gets 16.5mpg hwy. 13mpg in town. 10-12mpg. Towing. The gauge doesn’t move from full for a bit but then moves fast. My fill-ups are at around 316 miles with the gauge in the last quarter. I drive almost all highway miles and no short trips. Sometimes by watching the gas gauge I might be at 70miles for the first quarter…and get to half quickly…but doing the math at fill up it’s 16 something. At close to 300,000 miles I’ve never accused the truck of getting great gas mileage. I don’t think I’ve ever hit 20mpg with it.
  4. Nov 26, 2022 at 4:58 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    That's pretty bad, works out to 5-6mpg. You should typically get 11-15 in town (most seem to get 12-13mpg).
    Check your fuel trims and o2 sensor readings. You could see if the maf is bad as well.
  5. Nov 26, 2022 at 5:36 PM
    shifty` All my rowdy friends have settled down
    Is it 4WD or 2WD? Sorry if I missed that, it's somewhat important.
    V8/4WD here, with a lighter access cab. I average around 370-380km per tank with a mix of 70/30 driving (city/hwy).
    Do you know what spark plugs are installed? What brand of MAF the truck has installed? Any maintenance history at all?
    Did you sign up for Toyota Owners website yet to see if there are any maintenance docs there?
  6. Nov 26, 2022 at 5:59 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Do a proper calculation, there are too many variables using the fuel gauge. Fill up and reset the ODO, then next fill up, divide the fuel amount into the distance traveled.
