Poly LCA bushings???
Discussion in 'Suspension' started by TexasTundra27, Mar 29, 2018.
  1. Mar 29, 2018 at 8:36 AM
    TexasTundra27
    TexasTundra27 [OP] Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    Does anybody make poly LCA bushings for the second and third gens?? I’m hearing a popping from my front end and I’m fairly certain it’s my 173k LCA bushings since I’ve replaced virtually everything else already. Thanks in advance
    dcsleeper408 and 831Tun like this.
  2. Mar 29, 2018 at 9:02 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I wondered the same. My guess would be TC since they make LCAs
    GodlessPro and joonbug like this.
  3. Mar 29, 2018 at 9:22 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    As of a few months ago according to TC, there isn't a poly LCA bushing available.
    TexasTundra27[OP] and 831Tun like this.
  4. Mar 29, 2018 at 9:32 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    If you can get measurements you can call energy suspension and they will see if they have anything that will work
    I did that for my rear upper shackle pivot bushings. The ones in the frame. They found some gm control arm bushings that were the same size, I just had to trim a little off the length. I saved $200 over what Toyota wanted for them
    Tundra2, RJVA, chugs and 5 others like this.
  5. Mar 29, 2018 at 11:47 AM
    TexasTundra27
    Mark
    Nice, I’ll try to get some measurements without having to take everything apart again, hopefully they can find something! Do happen to have the part # for the shackles pivot bushing you used?
  6. Mar 29, 2018 at 2:13 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    2599g for black, 2599r for red
    You should take it apart and measure it with a micrometer, energy suspension measures their bushings down to the hundredths of an inch
  7. Mar 29, 2018 at 2:15 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    This 2599 bushing is designed to fit a .750” OD metal sleeve. You'll need a metal sleeve measuring .750” OD x .563” ID x 3.500” for a 9/16th bolt. Part number for the sleeve is “15.10.09.39” and you'll have to trim it a little
    *edited*
    Wait, my bad. That sleeve wasn't long enough. We ended up making a new one out of dom. If your current sleeves are in good condition, just reuse those
    GNTundra likes this.
  8. Jul 6, 2018 at 4:35 PM
    TexasTundra27
    Mark
    Little update, I ended up buying some OEM take offs to replace mine and decided to replace the steering rack bushings at the same time. Front end is nice and tight again but all that uncovered another problem, I think my shackle pivot bushing is bad. Toyota told me that after they aligned it they took it out for a drive and the rear is loose and it isn’t holding a perfect alignment... so that will be my next project after I get back from Moab and FJ Summit this month. I do plan on pressing out the LCA bushings and measuring it with a caliper to send to Energy Suspension, hopefully they can make something for us.
    KevinK, dcsleeper408 and osidepunker like this.
  9. Sep 5, 2018 at 9:39 PM
    Bulhas
    Bulhas New Member
    Joe
    2007 Double Cab Limited
    did you end up getting measurements sent out to energy suspension?? Id hate to replace my LCA's for bushings....
    831Tun and dcsleeper408 like this.
  10. Sep 5, 2018 at 10:18 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    :popcorn:
  11. Sep 6, 2018 at 6:38 AM
    TexasTundra27
    Mark
    Not yet, haven’t had the time... I’ll have some days off next week so if I get the time I’ll go out and see what I can get done on it
    831Tun likes this.
  12. Sep 25, 2018 at 5:39 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Total Chaos sell LCA bushing for the long travel LCAs. I bet you they are the same size....
    you would just need to see if they would also sell you the sleeves for the cam bolts
  13. Sep 25, 2018 at 5:50 AM
    Rica25
    Ricardo
    Tulare
    I have 2008 with 127k miles and I replaced mine about 4 months ago with some Moog LCA so far so good .....the master Technician at Toyota was actually impressed with the quality he said they were no different than stock
  14. Sep 25, 2018 at 5:52 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Maybe thats true, but moog for the first gen are garbage
  15. Sep 25, 2018 at 6:40 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Because they can visually tell difference in rubber and a hidden BJ assembly lol
  16. Sep 25, 2018 at 9:58 AM
    stealth09
    stealth09 New Member
    Canada
    Has anyone found a good replacement for our LCA bushings?
  17. Sep 27, 2018 at 11:06 AM
    Bulhas
    Bulhas New Member
    Joe
    They are not, already tried that Avenue
    Anyone measure there old arms bushings yet......
  18. Sep 27, 2018 at 11:11 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Just buy a used set of LCAs from a salvage yard off a truck with low miles; you can get them pretty cheap. I'm putting on a set this weekend that came off a newer truck with 20k miles. My current bushings and balljoint are shot.
  19. Sep 27, 2018 at 11:11 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Well then what is different about the size?
    Its not hard to call energy suspensions and get bushings. But someone needs to take measurements
    Rica25 likes this.
  20. Sep 27, 2018 at 11:41 AM
    Bulhas
    Bulhas New Member
    Joe
    chugs, joonbug, dcsleeper408 and 2 others like this.
  21. Sep 27, 2018 at 11:42 AM
    Bulhas
    Bulhas New Member
    Joe
    not so easy here, salvage yards north of the order want a premium, Id like to keep the factory arms and get a poly bushing, which if you look up, I feel I just found our answer
  22. Sep 27, 2018 at 11:44 AM
    stealth09
    Canada
    Did you mean North of the border? If so I am in Canada as well and found some LCAs down in the US for a very reasonable price and shipping. I agree everything is usually at a premium for us.
  23. Sep 27, 2018 at 11:46 AM
    Bulhas
    Bulhas New Member
    Joe
    yup canada, but heres the deal by the time i get in alberta half way up the province I could have bought 1.5 arms already from rock auto, it still does not resolve the point of this thread of looking for a poly bushing
  24. Sep 27, 2018 at 11:46 AM
    stealth09
    Canada
  25. Sep 27, 2018 at 11:46 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    KevinK likes this.
  26. Sep 27, 2018 at 11:46 AM
    Bulhas
    Bulhas New Member
    Joe
    9 is the front bushings, 8 is rear
    osidepunker likes this.
  27. Sep 27, 2018 at 11:48 AM
    Spvrtan
    Kris
    San Diego, CA
    Interesting! What's the difference between the two? I'll have to give this some serious thought for future use. Rough estimate on cost out the door?
  28. Sep 27, 2018 at 11:50 AM
    Bulhas
    Bulhas New Member
    Joe
    You need both, 241.30 for both kits from energysuspension
    Both kits come with 2 bushings each!
    dcsleeper408 likes this.
  29. Sep 27, 2018 at 11:58 AM
    Bulhas
    Bulhas New Member
    Joe
    ive ordered both kits, Ill be expecting these by next week and ill see if I can get them swapped out next weekend!
    KevinK and osidepunker like this.
  30. Sep 27, 2018 at 12:22 PM
    stealth09
    Canada
    If you were in Edmonton we should of ordered together save on the shipping costs.
