Polishing TRD exhaust tips
Discussion in 'General Tundra Discussion' started by GSD, Mar 21, 2020.
  1. Mar 21, 2020 at 9:32 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    2019 Platinum Crewmax
    Wondering what everyone uses to polish their TRD exhaust tips? I’ve got the black chrome tips less than a year old and they seem to have a film on them and finish looks rather spotty. I’ve got numerous different metal/chrome polishes that usually do the trick, but they just aren’t polishing out that good.
    Also, any recommended protectant that can be put on them?
    Thanks
  2. Mar 22, 2020 at 12:27 AM
    newguy
    newguy New Member
    2016 CM TRD off road limited.
    TRD Dual Exhaut TRD Pro wheels BFG KO2 275/70/18 GoRhino RB20s Blacked out tail lights Bilstein 6112/5160 combo Coach builder +1 in the rear
    Following. I have the same issue!!
  3. Mar 22, 2020 at 12:35 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I had turtle wax compound I used when mine was chrome it made it look new again.
  4. Mar 22, 2020 at 7:14 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If this polish (link below) doesn't work, the cure for the film and spotty finish is going to be new exhaust tips. This assumes the "black chrome" is actually a plated finish and not painted coating. Use that on a painted finish, and it will "soon get through to the bottom of it". Might be advisable to first try any metal polish on an inconspicuous location.
    Without applying a protective clear coat, your options for protection are going to be the same as for your paint, i.e. wax, sealant, ceramic, etc.
    https://www.amazon.com/Simichrome-3...=1584886077&sprefix=metal+poli,aps,190&sr=8-5
  5. Mar 22, 2020 at 7:44 AM
    xtyfighterx
    Ty
    North Idaho
    Or just paint them black again
  6. Mar 22, 2020 at 6:58 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    Thanks for the link. They’re actually a plated finish, not painted. TRD makes them either in a silver chrome, or black chrome finish.
  7. Mar 24, 2020 at 4:40 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Interesting post. Let me know if you try something that works.
    Hammerdog likes this.
  8. Mar 24, 2020 at 5:09 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    I have the black also.. add me to the interested crowd.
  9. Mar 24, 2020 at 5:32 AM
    JohnLakeman
    I used that Simichrome polish to clean up some chrome exhaust tips on a Malibu LTZ. I found the deposited residue from condensation of combustion products extremely difficult and slow to remove, even with a lot of effort. It did work, but it was a lot of work...be prepared.
  10. Mar 24, 2020 at 7:08 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  11. Jun 23, 2020 at 7:08 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    Here is a pic of what the finish looks like, any ideas what will get this film to polish out? Simichrome??
  12. Jun 23, 2020 at 7:41 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    One can of this should do the trick
    Y0TA PR0 likes this.
  13. Jun 23, 2020 at 8:00 PM
  14. Jun 23, 2020 at 8:36 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    Not looking to paint as they're already black plated chrome, just trying to find a polish that works. I've tried the Never Dull and a few other of my go-to metal polishes which aren't really working. I haven't tried the Simichrome that was recommended, not sure if this would work??
  15. Jun 23, 2020 at 10:09 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Not sure about your black chrome, but I use Super Fine 0000# steel wool to polish my chrome welded on tip..
    Tundyfundy likes this.
  16. Jun 23, 2020 at 10:13 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I use steel wool and windex. Seems to get most anything off of true chrome. Not sure for the black.
    1lowlife[QUOTED] likes this.
  17. Jun 23, 2020 at 10:17 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    I liking this idea. ^
  18. Jun 23, 2020 at 10:26 PM
    GSD
    GSD [OP] New Member
    Seattle, WA
    Anyone tried this on the TRD black plated tips?
  19. Jun 23, 2020 at 10:48 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I ve never polished my exhaust tips.:mudding:
