Po101 code
Discussion in 'New Member Introductions' started by Guy1212, Aug 25, 2016.
  1. Aug 25, 2016 at 11:02 PM
    Guy1212
    Guy1212 [OP] New Member
    Kolton
    2014 tundra trd
    K&n intake, exhaust, fuel take swap,bully dog chip
    Just so happens my battery was going bad and that was the problem fixed..po101 code mass air flow volume circuit/range
  2. Aug 26, 2016 at 7:05 AM
  3. Aug 26, 2016 at 10:10 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    When was the last time you cleaned your EGR valve?
    Code: P0101
    Description:
    Mass Air Flow
    Circuit Range /
    Performance
    Problem
    Issue:
    - Mass Air Flow
    (MAF) meter
    - Air induction system
    - PCV hose
    connections
    - EGR valve
  4. Aug 28, 2016 at 9:16 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The battery going dead caused the code?
