Plug and play amp
Discussion in 'Audio & Video' started by Pudge, Oct 21, 2017.
  1. Oct 21, 2017 at 10:56 AM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I've been reading a little about options for a plug and play amp. Seems that there are a few out there but no really good reviews or opinions by someone who actually installed one. I've read about using a line out converter or sound processor in conjunction. I was hoping to just replace my amp with something and buy harnesses as needed to make the install easy.
    So does anyone have anything to say about an amp swap or just adding a LOC? Is any of this worth it? I really don't want to get into replacing head units or speakers.
  2. Oct 21, 2017 at 2:34 PM
    Pudge
    CT
    So maybe I could just start with a speaker swap? I'm looking for decent sound. Nothing crazy.
    GNTundra likes this.
  3. Oct 21, 2017 at 3:06 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Lmk what you go with. As a jbl owner I'd like better sound too. I was thinking of replacing the head unit and it might sound better. Just not sure if an aftermarket head unit works with the stock amp or everything has to be rewired? Any jbl owners know?
    831Tun likes this.
  4. Oct 21, 2017 at 4:16 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I swapped out my door speakers, replaced the stock amp, and added an LC6i. From what I understand, adding a controller like the LC6i is necessary if you want add an aftermarket amp and keep the stock HU. I wasn't too impressed with the difference in sound at first. The amp and speakers were both Fosgate. Not top of the line models, but should have been better than stock. I decided to add another Fosgate amp and a small JL Audio sub. Sound was better, but still a little off for some reason. I took a closer look at the wiring my installer did on the LC6i, comparing it to a wiring diagram I found online. Installer had mixed up a couple wires. After correcting it, the sound was great. Nothing like the slamming 12's I used to have in high school, but more than enough punch and highs in the cab. The JL sub came in its own box, and it fit under the seat in my double cab (barely). If the wiring had been done correctly to begin with, it might have been ok without the sub.
    831Tun likes this.
  5. Oct 21, 2017 at 4:37 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I got all of my audio from Tech12volts. I have a JL 5 channel amp that he gave me a harness that made it plug and play. You do not need a LOC to make it work, just the harness. I believe any of the amps that can take a speaker level output can become a plug and play, you just need to get the harness that plugs into the factory harness at the factory amp. I got mine from Tech12, but I know ********* has them as well. I was all set to start ordering my stuff, harnesses from *********, speakers from one place, subs from another etc. Then I talked to James at Tech12 and he gave me a great deal and I saved a couple hundred bucks going through him for everything and he was great to work with.
    BMR tundra and Pudge[OP] like this.
  6. Oct 21, 2017 at 5:05 PM
    Pudge
    CT
    This is what I have read a few places. Even that simply changing the amp, especially to a 5 channel which also powers the sub, will bring the stock speakers alive and that they are that bad after all.
  7. Oct 21, 2017 at 5:12 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I've also heard that one of the biggest issues was the fact that there isn't any power and that replacing the amp will help a ton. When I changed out the speakers though, the factory speakers felt so cheap that I don't see them lasting long with increase power. I changed everything except the head unit out. Front, rear speakers, amp and 10 inch sub and it made a big difference.
  8. Oct 21, 2017 at 5:17 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    831Tun and Pudge[OP] like this.
  9. Oct 21, 2017 at 5:28 PM
    Pudge
    CT
    I'm gonna shoot the guys at tech12 an email and see what they have to offer. I'm not sure I'll do anything but maybe I can add something to my Xmas list
  10. Oct 21, 2017 at 6:07 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Hmmm. :popcorn:
  11. Oct 21, 2017 at 6:26 PM
    Cfincke
    San Antonio
    Tech12 is running a sale for the week, started today.
    I ordered everything else I needed to replace everything but the head unit.
    Pudge[QUOTED][OP] likes this.
  12. Oct 21, 2017 at 8:03 PM
    Pudge
    CT
    James already answered my email. Seems that not only does the JBL system suck, it also makes it a little more difficult to upgrade certain parts. James told me this..." Can't replace the amp with the JBL. It has to stay in. You can add a processor after the amp and then add an amp"
    I emailed him back and will see what he says. I asked if he could put together a plug and play kit, processor, amp for all stock speakers within the correct wattage, and harnesses to make it all work. If he can come up with something maybe we can do a group buy or something for anyone looking to do something similar to me.
    831Tun likes this.
  13. Oct 21, 2017 at 8:19 PM
    Pudge
    CT
    He said a full plug and play is worthless. Some wires will need to be ran and new connections made. I can deal with that. This guy seems great. I'm sure he thinks I'm an idiot for asking some of the questions I'm asking, but I wanna keep this simple and see if it's possible for me to keep my stock speakers. I feel like he's being honest with me and won't put a kit together that won't sound good. Hopefully I'll get a price and idea of what's involved in the next couple days. Once I get these answers and post them up here, I'll see who else is interested and talk to him about it.
  14. Oct 21, 2017 at 9:42 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @Pudge did you ask him if changing the head unit on a jbl would benefit from better sound? Can we even change our head unit with the existing amp?
  15. Oct 21, 2017 at 9:54 PM
    Pudge
    CT
    I didn't ask him that but I will. I believe the amp on these trucks doubles as the sound processor, which is why it has to stay. I'm thinking a head unit is doable without much trouble.
  16. Oct 21, 2017 at 10:07 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks. I'm hating the JBL system the more I find out about these stuff!!! Total garbage. I really dont want to rewire everything. I was looking to doing the oem plus since its pretty much pnp. But i want a different head unit for apple car play and hopefully better sound.
  17. Oct 22, 2017 at 7:51 AM
    Cfincke
    San Antonio
    I beleive if you change the head unit you can remove the stock amp under the passanger seat on a JBL system. The stock amp is tied to the volume control for the JBL head unit. An aftermarket head unit will have better sound over the stock head unit.
    Pudge[OP] likes this.
  18. Oct 22, 2017 at 10:27 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Didn't realize you had the JBL system. I just had the regular system which from what I have read, the JBL does make it a pain in the ass to upgrade. He is very knowledgeable, and will work with you within your budget. Not sure how much more it was cost to over come the JBL issue though.
  19. Oct 25, 2017 at 7:19 PM
    Pudge
    CT
    I'm a little disappointed as to the direction this has gone. I emailed back and forth with James Saturday night. He was very helpful. He stopped emailing me once I asked what I could do as far as a LOC and aftermarket 5 channel amp for around $500. Not sure if he was insulted by my possible budget but he just stopped emailing.
  20. Oct 25, 2017 at 10:12 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    o_O hmmmm
  21. Oct 26, 2017 at 11:43 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Try emailing him again. I know he's made comments before that there are times he gets so many emails that he may lose track of some of them. The experience I had with him, he always seem to try and find something that would work for you and I would think he would just tell you that's not possible if that's was the truth instead of just ending communication.
    Pudge[OP] and 4x4_Angel like this.
  22. Oct 26, 2017 at 12:14 PM
    Pudge
    CT
    Will do. Thanks guys
  23. Oct 26, 2017 at 12:31 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I'll have to look at the wiring diagrams again, but I'm pretty sure you should be able to remove the JBL and replace it with aftermarket.
    If you've decided to replace speakers anyway, I would try that first. The cheesy 20 watt paper cone speakers need to go with any upgrade in my opinion. And replacing them may just give you the upgrade you're looking for.
    4x4_Angel likes this.
  24. Oct 26, 2017 at 12:34 PM
    Cfincke
    San Antonio
    What @bsktball55 said, sometime James emailed me back within a few minutes, then there would be times where it was hours or a day for him to email back.
  25. Oct 26, 2017 at 12:42 PM
    Cfincke
    San Antonio
    Both James at tech12volts and ********* have told me the amp under the passenger seat have to remain if you keep the head unit in a JBL equipped tundra. ********* said they tried unsuccessfully for months to remove the amp while keeping the JBL head unit
  26. Oct 27, 2017 at 7:14 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    They are correct. I took a look at the JBL diagrams and there is a lot signal mixing going on in the JBL amp. The JBL HU does not put out discrete audio channel signals.
  27. Oct 27, 2017 at 7:17 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    o_O so lost....
  28. Oct 27, 2017 at 7:24 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Do you know if I can replace my stock jbl headunit and it work with the existing wiring and jbl amp? Without re wiring of course.
  29. Oct 27, 2017 at 7:34 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I don't know exactly what's going on with the signal generation and mixing between the JBL HU and Amp, But from the signal names coming out of the HU and the signals coming out of the amp, it looks to me like they are an "all or nothing" design. For the same reasons you can't just replace the amp, I don't think you can just replace the HU.
    I do think you could replace both and still use use the factory wiring, but there wold be some research involved to build up the adapters.
  30. Oct 27, 2017 at 7:51 PM
    Pudge
    CT
    Your knowledge amazes me @TundraTex , I look at a wiring diagram and damn near have a seizure. Your posts are so helpful and somehow you can explain things in terms I can understand. Thanks for all your help with all this wiring stuff.
    I'm sure you've said it somewhere, but ehat do you do? Engineer? Electrician?
