Plowing with your Tundra - Tow / Haul Mode??
Discussion in '2.5 Gen Tundras (2014-2021)' started by Eborseti22, Nov 16, 2022.
  1. Nov 16, 2022 at 9:41 AM
    Eborseti22
    Eborseti22 [OP] New Member
    Evan
    2020 Toyota Tundra TRD Offroad
  2. Nov 16, 2022 at 9:47 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I did a little plowing in my truck when I was younger too. The biggest issues were the windows fogging up.
    soobahru, Sumo91, NWPirate and 8 others like this.
  3. Nov 16, 2022 at 9:48 AM
    Taco-Spike
    Two Trucks
    Won't hurt to use it
  4. Nov 16, 2022 at 9:54 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    I've got a 2007 DC with 5.7L and Fisher minute mount plow.
    I only do our own driveway, but have not used tow/haul for it....
    SPP
  5. Nov 16, 2022 at 10:38 AM
    Eborseti22
    Evan
    Thanks SPP. That's probably all I will do, maybe occasionally bail the in-laws out with their long, steep driveway, but mine is just big and flat. Didn't plan on using anything other than 4wd, but saw some older threads on plow sites that talked about older (different) trucks using that feature. Figured I would ask the wealth of knowledgeable folks here to see if there was any updated info!
  6. Nov 16, 2022 at 1:03 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    4low of course and tow haul would certainly assist
  7. Nov 16, 2022 at 1:05 PM
    slowpokepete
    Peter
    Hillsdale, NY
    Yeah my truck is pretty much stuck in the snow if its not in 4WD, especially with the plow on the front.
    SPP
  8. Nov 16, 2022 at 1:07 PM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    Plowing snow can be hard on an automatic transmission.
    Rocko9999 likes this.
  9. Nov 16, 2022 at 4:30 PM
    ssls6
    ssls6 Dr. Awesome
    Richard
    South Park, CO
    2020 TRD Pro CM
    Bakflip, Bedstep, Gulfstate stuff
    I don't think I would use tow/haul mode. It seems to increase the throttle tip in which would increase wear when plowing.
  10. Nov 16, 2022 at 5:48 PM
    Eborseti22
    Evan
    wondering why you would use 4lo not high? I know you’re not supposed to go fast obviously, but just trying to learn!
  11. Nov 16, 2022 at 5:53 PM
    Running in 4hi at slow speeds can overheat your transmission, and with your truck being a 2020, you already lack an external transmission cooler. 4lo will keep the torque converter locked and prevent the heat from locking and unlocking that happens in 4hi. General rule, if you are going under 15-20 MPH and want 4WD use low range.
  12. Nov 16, 2022 at 6:20 PM
    Eborseti22
    Evan
    that’s good info to have. Much appreciated!
  13. Nov 17, 2022 at 4:24 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I would not use it to plow snow. Throttle is too sensitive.
  14. Nov 17, 2022 at 5:13 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    If you're plowing your driveway and possibly the in-laws, I wouldn't worry about wear and tear. Trucks aren't that sensitive. Just use common sense and don't do dumb things like hitting big mounds with speed. 4H and drive mode should be plenty for what you're doing.
    If you were doing it commercially (As in for multiple houses throughout your day) then that could change the plan.
    WILLINH likes this.
  15. Nov 17, 2022 at 5:25 AM
    Eborseti22
    Evan
    Thanks for the input! I’m not too concerned about the west and tear either. Like you pointed out, won’t be hammering the truck with hours of plowing, and likely won’t be driving around very far with the plow on anyway.
    once it snows I’ll start messing around with different modes and techniques and see what works best.
    WILLINH and Jaypown[QUOTED] like this.
  16. Nov 17, 2022 at 5:31 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    :thumbsup:
    Also, kind of like with towing, it may not hurt to get scanguage or something to monitor your transmission temps. Just to play it safe.
  17. Nov 17, 2022 at 6:54 AM
    slowpokepete
    Peter
    Hillsdale, NY
    My truck is pretty much parked once the plow goes on, other than doing the driveway...already got enough rust underneath (which is probably not too bad) and not looking for anymore from driving on salted roads.
    Fortunate to be retired, and have our '09 Highlander to drive instead.
    One thing that surprises me is, despite being driven all through the winters here, the Highlander has very little rust compared to the Tundra.
    Why is that?
    SPP
  18. Nov 17, 2022 at 8:44 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    I do some plowing with mine and never used tow/haul. Don’t need it as the plow only weighs 400 pounds.
    I’m usually in 4HI and probably should have been in LO for some driveways. I haven’t plowed since I got my scangauge so I have no idea what my trans temps were during those times.
    Eborseti22[OP] likes this.
  19. Nov 17, 2022 at 9:36 AM
    Eborseti22
    Evan
    wonder if it has to do with ground clearance and what gets kicked up by the tundra vs what kicks up from the Highlander?
    my parents have a Highlander older than my tundra, wonder if theirs is the same scenario, but they drive a lot less than me!
