Please relieve some of my ignorance
Discussion in '1st Gen Tundras (2000-2006)' started by Markshere2, Dec 26, 2021.
  1. Dec 26, 2021 at 2:13 PM
    Markshere2
    Markshere2 [OP] New Member
    2006 tundra 4door 2wd
    Hi folks,
    Great site you have here! I have been looking and not finding the info i need.
    I live in western PA where the winter road salt just devours cars n trucks.
    I scored a southern 2006 tundra with high milage (200,000 ) and no real corrosion. Its 4 full door, 2WD with the 4.7 V8.
    The reasonable purchase price is being offset by the recent failures.
    The rear end started making bearing noises. My local guy had me get a new wheel bearing, then found somebody had put a wrong bearing in and it spun in the rear end and naffed up the axle housing.
    I've been looking for months and the local salvage yards are not helping at all.
    What rear ends will swap out with this one? Sequoia? 4runner SR 5?
    Will 2000 to 2006 interchange?
    Since it is not 4wd, i am not concerned with the gear ratio.
    I saw a post that the ABS pickups changed one year....
    Thanks
    Mark
  2. Dec 27, 2021 at 5:32 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Sequoia and 4Runner are coil spring and disk brake... so would require modification to work. Not sure about the input shafts though.
  3. Dec 27, 2021 at 5:50 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I before E, except after C...is that what you meant?
  4. Dec 27, 2021 at 5:55 AM
    Markshere2
    Yeah, can't find the "edit title" button.
    Neighbor, I just want to weigh my options, hey wait a minnit.....
    gascap, Darkness and Uhhhh.... like this.
  5. Dec 27, 2021 at 5:56 AM
    Markshere2
    Thanks, some ignorance has been relieved.
    Darkness and FirstGenVol like this.
  6. Dec 27, 2021 at 5:59 AM
    Refusuck
    Refusuck New Member
    Si Tres
    Arch Cape OR
    2021 TRD Pro
    Did you try Ebay? I've had luck with them - also CL.
  7. Dec 27, 2021 at 6:00 AM
    w666
    Maryland
    dbittle likes this.
  8. Dec 27, 2021 at 7:49 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    To edit the title, click on Thread Tools in the top right corner of any thread you started:
  9. Dec 27, 2021 at 8:48 AM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    Don't know which bearing but would it be possible to have the housing bored to have a sleeve installed that would fit the standard Toyota bearing?
  10. Dec 27, 2021 at 10:00 AM
    Markshere2
    Thanks!
  11. Dec 27, 2021 at 12:58 PM
    Markshere2
    I haunt Craigslist, but to no avail thus far.
    I am amazed at the prices these trucks command, but moreso the prices of parts.
    Wowsa!
    Got a 2003 Tundra rear end located in eastern Ohio for 600, and i have been balking on that price until i found out if it would line up without excessive mechanical buffoonnery.
  12. Dec 27, 2021 at 1:19 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    First thing I'd do is find an new local mechanic. Your guy does not know Tundras.
    Tundra bearings do not seat in the axle housing like a Ford or Chevy 8.8. The bearing resides in a bearing cup that is bolted to the axle. If an undersize bearing was used, you'll just need to buy a new backing plate for $100 from a Toyota dealer parts counter. Aftermarket are available for cheaper, but are cheaper in quality as well.
  13. Dec 27, 2021 at 7:33 PM
    Markshere2
    Uff-Da!
    Cool beans.
    I guess its time to get a shop manual and DIY.
    Many thanks!
  14. Dec 28, 2021 at 8:48 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    @Markshere2
    If it's just the part posted above, I'd grab one from a junkyard and get the bearing swapped out. The axle shaft above is pretty cheap and when I had my bearing swapped by a very knowledgeable Toyota shop labor was only $100 (I pulled the axle and took it to them)
    Markshere2[OP] likes this.
  15. Dec 28, 2021 at 8:57 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
  16. Dec 28, 2021 at 8:57 AM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Also, the bearing is pressed onto the axle shaft and basically fits right into the backing plate. So maybe your backing plate is fine and he just thinks it’s loose. It’s kinda a little puzzle putting it together to keep the bearing in the backing plate while getting the bearing to the right spot on the axle - unless you have the special tool for the press.
  17. Dec 28, 2021 at 9:28 AM
    Markshere2
    Wow, THANKS!
    GREAT INFO guys. This place rocks!
