Please Help...Leveled with alignment issues!
Discussion in 'Suspension' started by TMagee24, Dec 21, 2019.
  1. Dec 21, 2019 at 3:36 PM
    TMagee24
    TMagee24 [OP] New Member
    2014 Crewmax SR5 TRD
    3/2 Readylift Leveling Kit 20x9 Fuel Hostage 295/60/20 Nitto Trail Grapplers
    2014 Tundra TRD 4x4
    Readylift 3/2 Level Kit
    JBAOffroad UCA’s (just installed)
    Ever since the level kit was installed my alignments have been off and I’ve experienced outside edge wear of the front tires. It was suggested that I go with JBAOffroad UCA’s that allow more camber/caster adjustment to correct the issue. Had those installed and took it for an alignment today and was told this was the best he could do and noted on my receipt “unable to fully adjust pass side. Bushings stuck in control arm”. What do I need to do here???94FD9472-866D-457C-830C-EAF0C2264B35.jpg
  2. Dec 21, 2019 at 5:41 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    I have a leveling kit also,
    Have gone through multiple alignments at different shops.
    With a leveling kit your alignment will never be right. Don’t listen to anyone that says otherwise.
    My advice, get it removed ASAP and go with a different setup like 5100s or another suspension lift.
    TMagee24[OP] likes this.
  3. Dec 21, 2019 at 6:22 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You have way to much toe. Total toe should be no more than .15.
    Your camber is also jacked up. Not only should it be closer to 0, camber should be equal on each side.
  4. Dec 21, 2019 at 6:39 PM
    TMagee24
    They said they couldn’t adjust the passenger side because “bushings stuck in the control arm” LCA......???? I’m not exactly sure what that even means.
  5. Dec 21, 2019 at 6:45 PM
    Creatures 1982
    Creatures 1982 New Member
    2017 SR5
    It means you need to find a new alignment shop.
    Find a tech that knows what they are doing and YES you can align a lifted truck .
    TRDSPORT118 and TMagee24[OP] like this.
  6. Dec 21, 2019 at 6:49 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    Go to a different shop. My local Toyota cost me a set of tires. I went back for 3 or 4 alignments because of outside wear. Bought a new set and had the alignment done at a reputable off road shop. Zero issues since
  7. Dec 21, 2019 at 6:58 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    If the cam bolt is seized you'll need to fix that first. Toyota has a long history of that happening. Tacos are horrible for that. Sometimes you can heat them up and get them to move, sometimes you need to cut them out.
  8. Dec 21, 2019 at 7:14 PM
    Creatures 1982
    2017 SR5
    You paid a shop to do a alignment on your truck. Any reputable shop will fix the problem (sure they will charge you ) but a good mechanic will not just say they can’t fix it.
    Find a real shop with a real mechanic!!!
    15whtrd and TMagee24[OP] like this.
  9. Dec 21, 2019 at 7:18 PM
    Jengel451
    The Bitterroot, MT
    In a sense I agree. Problem is, more often than not the cam bolt is dealer only item, and there is a HUGE chance of the LCA getting butchered to get the stuck one out. They SUCK!
  10. Dec 22, 2019 at 6:08 AM
    kxed
    kxed New Member
    Pittsburgh PA
    2020 VooDoo Blue Crewmax Sport
    Sounds like the adjusting eccentric bolt is seized in the bushing. You can try to soak the two lower control arm bolts on the right side with PB Blaster or Kroll oil for a few days then see if they loosen up. if that don't work you will have to replace the bushing.
  11. Dec 22, 2019 at 12:49 PM
    NOLA Tundra
    NOLA Tundra Sandbagging
    Jesse
    2019 Quicksand CM
    3” level leds all around Morimoto headlight and fog light bulbs Flowmaster American Thunder
    I’m on my 2nd 3rd gen on my 14 I did the Rough Country 3/2 lift level. With there’s they have two spacers to add after the 2” block. On my 14 I went to the max and did both spacers and could never get the alignment right and wore the outside of the tires. On my 19 went with the same kit left one spacer out and got it perfectly inline all green on my alignment sheet. It also still has a small rake to the front. Leaving that one spacer out makes an inch difference from front to back.
  12. Dec 22, 2019 at 1:43 PM
    Danman34
    Danman34 New Member
    Danny
    All green does not mean it’s right. All green means is that it’s in factory spec. You can no longer follow factory specs on these trucks once you change the suspension
    TMagee24[OP] and BlueDream like this.
  13. Dec 22, 2019 at 2:05 PM
    NOLA Tundra
    Jesse
    2019 Quicksand CM
    Well it must be close to factory specs because I see 0 wear on the outside of my tires. On my other truck it was noticeable if the street was wet you could see where the sidewall was wet from touching the street. Streets are wet today just went to get something to eat and sidewalls are high and dry. Just saying it’s better aligned on my new truck then my old truck just by leaving a 1/4” spacer out.
    TMagee24[OP] and Danman34 like this.
  14. Dec 22, 2019 at 3:49 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Maybe someone can tell you what shop to go or they have used. What state are you in
    TMagee24[QUOTED][OP] likes this.
  15. Dec 22, 2019 at 8:41 PM
    TMagee24
    Thanks for your input guys. I’m in PA near Pittsburgh. This alignment was done at Goodyear.
  16. Dec 22, 2019 at 8:46 PM
    NOLA Tundra
    Jesse
    2019 Quicksand CM
    I went to the same Firestone down here in NOLA with both trucks. The same guy still works there and said he remembered he couldn’t get the other one aligned.
  17. Dec 23, 2019 at 4:39 AM
    kxed
    kxed New Member
    Pittsburgh PA
    Im in Bridgeville area I have heard good thins about Lou Bevier's Alignment Shop in Canonsburg although I never used them. I used to be a Master Toyota tech now my son works at South Hills Toyota and he does my alignments. That being said I don't care who you go to it will never come into alignment if you have a seized adjusting eccentric bolt you will just be wasting money for someone to tell you the same thing.
  18. Dec 23, 2019 at 6:11 AM
    TMagee24
    So then you’re pretty close!!! I’m actually in the South Hills! So at this point, would you guys say it’s just better to replace the LCA’s and be done with it???
  19. Dec 23, 2019 at 6:19 AM
    Jengel451
    The Bitterroot, MT
    If you're this far into it, yes, and cam bolts.
  20. Dec 23, 2019 at 6:25 AM
    kxed
    kxed New Member
    Pittsburgh PA
    You don’t have to replace the whole cont arm I believe you can just get the bushing you will also need a bolt it’s not that hard of a job a sawzall will be your friend.
  21. Dec 23, 2019 at 7:45 AM
    How long has the kit been installed? Are the front spacers installed correctly? There is a marking that points out. I have seen them installed backwards. I have the same kit in mine.....for now.
  22. Dec 23, 2019 at 9:43 AM
    TMagee24
    Kit has been on for almost 6 years. Not sure about the spacers how can I tell? I had a friend to the install for me.
  23. Dec 23, 2019 at 10:23 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s false. An alignment can be done. If it’s lifted too much whether it’s with the spacer or 5100s. Usually around 3 inches the upper control arm needs to be addressed and upgraded, to one that will make up for the extra lift.
    Same thing, you are on the borderline of needing upper control arms.
  24. Dec 23, 2019 at 3:16 PM
    TMagee24
    I just had the JBAOFFROAD HD UCA’s installed 3 days before the alignment. The alignment tech said he wasn’t sure what I was trying to get at with the new UCA’s because it wouldn’t affect the alignment but they look cool. He was a dick. At any rate the JBAOFFROAD UCA’S are good for up to 4” of lift.
    15whtrd[QUOTED] likes this.
  25. Dec 23, 2019 at 5:12 PM
    15whtrd
    15whtrd Mr. Blonde
    What an idiot. Definitely not just for looks. They correct your angles with the lift. Never let that alignment “tech” work on your truck again with a statement like that LOL.
    To be honest he kind of deserves a pop in the mouth. I really hate it when people I’m paying are being snarky with me, but it lets me know how stupid they really are. Don’t treat me like I’m stupid because I’m having you do something I’m not qualified to do. Doesn’t mean I don’t know shit.
  26. Dec 23, 2019 at 8:13 PM
    TMagee24
    YOU GOT THAT RIGHT!!!!
  27. Dec 24, 2019 at 2:56 AM
    kxed
    kxed New Member
    Pittsburgh PA
    Not that I'm standing up for the guy but ignorance shouldn't deserve violence. Some people just don't know about lifted trucks and what's available aftermarket to fix those issues. He is working in a tire shop not a fab or 4x4 shop.
  28. Dec 24, 2019 at 6:22 AM
    15whtrd
    15whtrd Mr. Blonde
    Well I was exaggerating, I don’t go around punching people.
  29. Dec 24, 2019 at 10:57 AM
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    But they probably need it
  30. Dec 24, 2019 at 12:21 PM
    15whtrd
    15whtrd Mr. Blonde
    Exactly!
    jordan0317[QUOTED] likes this.
