*****PLEASE HELP diagnose****
Discussion in '1st Gen Tundras (2000-2006)' started by Ripmamagirl52, Oct 7, 2022.
  1. Oct 7, 2022 at 1:51 PM
    Ripmamagirl52
    Ripmamagirl52 [OP] New Member
    so let’s see.... started with the fuel pump fuse then relay, then pump, nothing, did the plugs coil packs checked all my fuses about 5 thousand times. Went on to the crankshaft pos. Sensor nothing, camshaft position sensor nothing. Took the timing covers off cause it must have jumped timing or something right? I mean wtf
    Else could it be.? Well the timing belt is rite on the money, maf sensor is fine .... why won’t this motherfucker start? Up till last week she ran like a fuckin raped ape.... now ......
    Crickets...... somebody help a motherfuckinn honkey out sorry guys forgot to say that we’re dealing with a 06 tundra 4.7 v8
  2. Oct 7, 2022 at 1:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Whoa Nelly!!!
    What was the original issue? Not starting? Why have you checked/replaced everything you listed?
  3. Oct 7, 2022 at 1:57 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    I know what’s wrong with it, ain’t got no gas in it!
    shifty`, Jack McCarthy and Tundra2 like this.
  4. Oct 7, 2022 at 2:07 PM
    Ripmamagirl52
    Its got almost a half a tank. And it started soon as I started it up to leave last week I backed out the driveway put it in drive and bam.... started to shake like it was running out of gas ( wich it was) but it died and ain’t started yet
  5. Oct 7, 2022 at 2:10 PM
    Ripmamagirl52
    Also it’s not getting no power to the fuel pump relay . I can run a jumper wire from the pos. Lead in the relay slot straight to the battery and I can hear the pump and
    Hear the gas rushing to the motor
  6. Oct 7, 2022 at 2:18 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Have you checked all your wiring harnesses for any rodent damage?
  7. Oct 7, 2022 at 2:32 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Just throwing darts here - fuel filter?
  8. Oct 7, 2022 at 2:57 PM
    BoysandHisToys
    Central Virginia
    Sorry, that was a joke I was making. Have you seen the videos of vehicles wrecked or not working and that audio is played?
    But I guess it actually could have been your issue with what you gave us on first post.
  9. Oct 7, 2022 at 3:06 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
  10. Oct 8, 2022 at 1:32 PM
    Ripmamagirl52
    Still nothing, cmon guys need ur help
  11. Oct 8, 2022 at 1:39 PM
    alb1k
    Left Coast
    It's good
    I would start with as much background and detail as you can. Your original post isn't very informative. Even model and year help.
    I would start the next post like it is the first post. Symptoms, What you have tried, why? - we will assume what you don't list hasn't been tried. I'm guessing you have no clue if the fuel filter is a problem, for example. Not that's a huge diagnosis, but it killed my truck once. Share more.
    Jack McCarthy likes this.
  12. Oct 8, 2022 at 1:53 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Codes? Vehicle doesn’t need to turn over to read past codes ya know, only turned to the accessory position.
  13. Oct 8, 2022 at 7:17 PM
    Ripmamagirl52
    It’s got no cel but the weird thing is is it did have the cel on rite before it took a crap on me to me it almost seems like it’s a computer or ecm issue cause when I do crank it it shows no rpm’s
  14. Oct 8, 2022 at 7:35 PM
    TILLY
    Massachusetts
    Why would you see RPM'S while cranking?. Also, you said you had a CEL before it died, but you didn't say if you checked it for codes as others have asked.
  15. Oct 9, 2022 at 10:03 AM
    That one's going to fly over a lot of peoples heads, but I LMAO when I read it. Bravo.
    You mentioned wanting to swap ECU in the other thread, but before you do that, you should confirm the fuel system is working as intended, and you have spark to the plugs.
    Understand: You need spark, air, and fuel to make ignition. At minimum, you need to verify you've got spark, and verify you've got fuel pressure. Before you start getting into "ECU bad ..." and whatever. Sure, ECU needs the MAF to work right so it can see how much air is coming in and adjust. Yes, it needs the throttle body assembly to work right, so it can actually open the throttle and let air in. But the two most important things to confirm are: Do you get spark? Do you get fuel (with ample pressure)?
    Have you pulled a spark plug or two yet to see what condition they're in yet?
    Have you confirmed fuel pressure yet?
    Have you randomly tested the plugs are firing yet?
    If I remember right, there are at least 3 components of the fuel system that can go bad which will stop the fuel pump from coming on and staying on:
    • Fuel pump resistor - on older trucks, it's the silver finned thing on top of driver side fender, under master cylinder, on newer trucks, it's the silver finned thing on top of passenger side fender, next to the power steering reservoir
    • Crankshaft Position sensor (not to be confused wthe camshaft sensor) - you said you already verified wiring and tested it, I think
    Here's the fuel pump circuitry if you want to understand how the fuel system works.
    Here's a link to some diagnostic videos that may help you figure out starting issues:
    https://www.tundras.com/threads/2005-ac-wont-start-fuel-system-problem.113385/#post-2921783
    Before you run yourself ragged, know the circuitry in these trucks only turns the fuel pump on on when (a) you're actually turning the key forward to start it and (b) when the ECU senses (via crankshaft position sensor) that the engine is running. You need to monitor fuel pump activity and fuel pressure during either A or B.
    For spark, there are plenty of tools to test at your local auto parts store, but if you don't mind getting shocked, that's another easy way to test. And if you've EVER bought non-Denso, non-Aisin parts for this truck, OR you bought ignition/fuel parts from scAmazon or fleaBay, know both of them are notorious for selling counterfeits, especially spark-related stuff (plugs, coils). These trucks tend to not like non-OEM coil packs, as one or two folks who "upgraded" to MSD brand found out. (I love MSD; sad when I saw ppl had issues on the 2UZ)
