Please help a noob with wheel question
Discussion in '3rd Gen Tundras (2022+)' started by wired, Dec 30, 2021.
  1. Dec 30, 2021 at 11:00 AM
    wired
    wired [OP] New Member
    David
    2022 Tundra Black SR5
    So I am picking up my Black 2022 SR5 Tuesday. It will have stock 18" wheels and the stock tires. I want to replace the stock silver wheels and go with KMC 540 Recon wheels. Going all black with red, dipping the emblems, etc. KMC says the wheel has the correct bolt pattern, etc, but has a +18 offset, whereas the factory wheel is +60 so they can't guarantee they will fit. I tried to read the thread on wheel offset/fitment, but I don't understand offset. Anyone help a noob out?
    Oh and here's a pic of the wheel for people to like or make fun of or whateverupload_2021-12-30_12-59-51.jpg
  2. Dec 30, 2021 at 11:04 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    The lower the offset # the more it sticks out past the wheel wells , basically.
    wired[OP] likes this.
  3. Dec 30, 2021 at 11:08 AM
    NoRcptn
    NorCal
    2017 Platinum
    Also here is a link.
    Type in your stock wheel and tire size and your new wheel and tire size. it’ll give you a visual .
    1lowlife and wired[OP] like this.
  4. Dec 30, 2021 at 11:08 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    @NoRcptn gave you a better link because it shows a visual
  5. Dec 30, 2021 at 11:16 AM
    wired
    David
    Thanks. So it will stick out 1.65" (42mm) more than the stock. It's hard for me to picture but I think I can live with that. But with it being further from the vehicle, I can't imagine any way it could bind or rub.
  6. Dec 30, 2021 at 11:19 AM
    alb1k
    Left Coast
    It's good
    It can on hard turns, because the outside of the wheel is traveling farther on a larger radius. Kinda like running 1.5" spacers.
  7. Dec 30, 2021 at 11:22 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    There someone on the 2022 tundra Facebook who put 18x9 +19 with no lift on a TRD off-road.
    paradizecityz likes this.
  8. Dec 30, 2021 at 11:46 AM
    wired
    David
    Thanks again, @alb1k and @TakiEvo . So if his 1" larger tires don't rub with +19, then I should be fine with my smaller tires sticking out 4/100 of a inch further. And the pictures make me feel better that I won't get kicked out of the neighborhood (for tire poke, anyway).
  9. Dec 30, 2021 at 11:53 AM
    alb1k
    Left Coast
    It's good
    I imagine you will be fine, although I'm gen 1 so don't quote me. A 1" wider tire on the same wheel, pretend it's 0mm offset, sticks out 1/2" further, because half of the width is to the inside. Tire height and width, wheel width and offset, all work together to determine the outcome.
    OppoMojo likes this.
  10. Dec 30, 2021 at 1:48 PM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    thats me :)
  11. Dec 30, 2021 at 3:10 PM
    wired
    David
    Nice looking truck! Thanks for checking this out!
    paradizecityz[QUOTED] likes this.
