Play in front differential/axle junction
Discussion in '2.5 Gen Tundras (2014-2021)' started by blaserdude, Oct 26, 2024.
  1. Oct 26, 2024 at 6:25 AM
    blaserdude
    blaserdude [OP] New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    Greetings,
    My 2019 tundra has some play in the junction of the drivers side axle/differential, (where the notorious needle bearing is located). I am not hearing the associated noise but there is some cyclic sound at 50 mph. Any thoughts on this? I still have Platinum warranty (at 80 k Miles).
    Regards,
    BC
  2. Oct 26, 2024 at 7:49 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum
    I'm experiencing a cyclic sound at 42 MPH. The cyclic sound goes away when I shift it into 4WD on straight paved roads. This typically indicates a needle bearing issue. The driver side CV axle has a lot of play where it enters the differential. The passenger side CV axle has hardly any play. I'll be bringing it into the dealer to get looked at this week. Suspect I'm going to end up replacing the needle bearing with an ECGS bushing at some point.
  3. Oct 26, 2024 at 7:51 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Check your driver's side CV for play; many have had needle bearing issues and that's a likely culprit for your symptoms.
  4. Oct 27, 2024 at 12:39 PM
    blaserdude
    Eugene
    none
    It does have some play. How much is normal is the question. The sound I hear is does not depend on being in 4WD high. Will have it checked at my dealer.
    bc
  5. Oct 27, 2024 at 12:55 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    My Dad’s 2010 and my 2021 had the same play in the driver’s side half shaft at the differential. I had the needle bearing issue and he has not, so I don’t know that you can use that as a way to tell if it’s bad. At least by hand they felt the same, I never measured run out or anything like that.
    You may also have a bad wheel bearing if it isn’t going away in 4HI. My passenger rear started going bad shorty after I replaced my differential needle bearing and it was god awful loud at 59 MPH.
  6. Oct 27, 2024 at 1:25 PM
    blaserdude
    Eugene
    none
    The dealer checked for rear bearings and differential for noise back in August. I checked the the fronts myself and both were quiet and smooth with no play. May be tire related since its more pronounced at times than others. Will see.
    bc
