platinum with 35s on factory wheels
Discussion in '3rd Gen Tundras (2022+)' started by 22platitundy, Sep 7, 2022.
  1. Sep 7, 2022 at 9:03 AM
    22platitundy
    22platitundy [OP] New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    I have a '22 Platinum arriving in a couple of weeks. I will be getting the readylift 3" SST lift kit installed and new tires. I'm hoping to save some money by keeping the factory wheels and wrapping them in 35s. But some photos I've seen with bigger tires on the platinum factory wheels still look underwhelming and I'm wondering if its because of the high offset. I think they have +60. Any photos of the factory platinum wheels with 35s on them would be helpful and well as insight.
    Thanks!
  2. Sep 7, 2022 at 9:13 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    35s will not fit on stock wheels, stock wheel offset will have the 1250 wide tires hitting UCA. You can run them with lower offset wheels (+20 to 25 is the sweet spot) or use 1.25 spacers on the stock wheels.
    Or, run 285/75-18, hair taller than 35x1250 and thinner. Works with stock wheel fine and clears UCA. 285/75 will be lighter, easier to fit than 35x1250, less impact on performance, basically all the benefits of a larger tire and added height without the fitting headaches or weight of 1250 wide tires.
    And of course you realize 35ish tall and heavier tires will reduce your MPG several points from stock so be aware. 2-4 MPG drop is sometimes a shock to people when they start lifting and adding larger tires. And all the larger tires will be a higher load rating, E load most likely so they will ride considerable stiffer than the stock standard load tires.
    tyman77 and Kepaniamekolea like this.
