Platinum 20x8 rims looking for photos with larger tires
Discussion in '2.5 Gen Tundras (2014-2021)' started by Patriot, Feb 2, 2017.
  1. Feb 2, 2017 at 4:33 AM
    Patriot
    Patriot [OP] Member
    Western NC, “Boondocks”
    I am getting ready to have the TT Boss 3/1 lift installed next week on my 14CM and am actually thinking about keep my stock Platinum rims and possibly bumping up the tire size to 285/65/20's or whatever I can fit without trimming.
    Any Platinum owners running a 3" lift with larger tires on the Platinum stock rims?
    Thanks!
  2. Feb 2, 2017 at 11:51 AM
    Patriot
    Patriot [OP] Member
    I am thinking not many Platinum owners upgrade to larger tires on 20" stock the OEM stock rims pictured above.
  3. Feb 2, 2017 at 12:07 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    no, I haven't seen too many, if any. Typically, people try to get the wheels / tires out away from the UCA, especially when lifting. The stock wheels being a +60 offset are sunk into the wheel well pretty good
    Patriot[OP] likes this.
  4. Feb 2, 2017 at 12:22 PM
    Zharris
    Zharris Merica!
    2016 Super White 4x4 Crewmax
    Yeah, the ones that do keep the oem wheels usually throw the 1.25" spacers on there I believe. Which puts it roughly around a +30 offset. In that neighborhood at least.
  5. Feb 2, 2017 at 12:59 PM
    allstar617
    allstar617 New Member
    Sy
    Boston,Ma
    2014 sunset bronze 1794
    Thule areoblade roof racks,Full Led conversion, rackarod lockable rod holders,Led bed lights,Lock'er down safe, 42" led light bar.......6112/5160 suspension lift Coachbuilder +3 shackles, shims and bushing set. Toyo open county AT2’s 295/65/20’s on stock black painted wheels..........
    With 1.25 bora spacers I got 295/65/20
    "35's" with platinum wheels Lifted with bilstien 6112/5160 combo CB shims +3 CB shackles
  6. Feb 2, 2017 at 4:47 PM
    Zharris
    Zharris Merica!
    You have any rubbing or have to do any trimming?
  7. Feb 2, 2017 at 5:57 PM
    Rancid13
    Rancid13 New Member
    Jax Beach, FL
    2011 4x4 DC SR5
    OME Dakar/Bilstein rear Rough Country leveling spacer front
    I don't have the platinum wheels but I do have the JTI 20's from the xsp package. I believe they're similar offsets if not the same. I have 285/65/20 nitto terra grappler G2's no spacers, no rubbing at all. Didn't have to do any trimming. Not a whole lot of room between the tire and the UCA, maybe 1/2". I've driven on the beach and some trails, nothing serious, but there was flexing and no contact with the UCA's. I can get you some pics tomorrow
    Patriot[QUOTED][OP] likes this.
  8. Feb 2, 2017 at 6:16 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    One of the package wheels are +50 instead of +60 like the platinum wheels. I think either the xsp or tss wheels.
  9. Feb 2, 2017 at 6:22 PM
    Zharris
    Zharris Merica!
    Yeah, the XP package is what I have and those wheels were +50.
    joonbug[QUOTED] likes this.
  10. Feb 2, 2017 at 6:23 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    i've always wondered this myself.
    i leveled mine with 6112's on the 3rd setting and threw on some 285/55's on the stock platinum 20's and find them just a hair smaller than i'd like.
  11. Feb 2, 2017 at 6:29 PM
    Rancid13
    Rancid13 New Member
    Jax Beach, FL
    2011 4x4 DC SR5
    Gotcha. There's not much info out there on the JTI's. In that case, 10mm closer to the UCA would be a little too close IMO
    Zharris[QUOTED] likes this.
  12. Feb 3, 2017 at 2:54 AM
    allstar617
    Sy
    Boston,Ma
    A little rubbing only mod was taking the small mud flap out and bending back skidplate. Purchased the body mount chop but didn't need it. The rub is at full chock and only on the molding that covers the foglight no big deal to me at least. I'll post pics shortly
    Patriot[OP] and Zharris[QUOTED] like this.
  13. Feb 3, 2017 at 3:49 AM
    Patriot
    Patriot [OP] Member
    Pics would be great thanks Rancid13!
  14. Feb 3, 2017 at 3:56 AM
    Patriot
    Patriot [OP] Member
    This info helps a lot guys, much appreciated.
  15. Feb 3, 2017 at 4:05 AM
    allstar617
    Sy
    Boston,Ma
    IMG_0121.jpg IMG_0122.jpg IMG_0123.jpg The only 2 areas it rubs, no damage just wore the molding down a little bit. Only off roading I do is on the beach and small trails, hope that helps IMG_0121.jpgIMG_0122.jpg
    Zharris likes this.
  16. Feb 3, 2017 at 4:06 AM
    allstar617
    Sy
    Boston,Ma
    UCA clearance
    Patriot[OP] and Zharris like this.
  17. Feb 3, 2017 at 6:32 AM
    Patriot
    Patriot [OP] Member
    Thanks Allstar617 I appreciate the pics, I won't be using wheel spacers.
  18. Feb 3, 2017 at 6:35 AM
    Patriot
    Patriot [OP] Member
    Photo?
  19. Feb 3, 2017 at 7:02 AM
    Rancid13
    Rancid13 New Member
    Jax Beach, FL
    2011 4x4 DC SR5
    Maybe I'm wrong but if you're running 285/55 on those wheels then 285/65 won't be any wider and no closer to your UCA. Overall diameter will be larger but if you're lifted 3" that shouldn't be too much of an issue
  20. Feb 3, 2017 at 7:15 AM
    Rancid13
    Rancid13 New Member
    Jax Beach, FL
    2011 4x4 DC SR5
    Here you go.
  21. Feb 3, 2017 at 1:14 PM
    Patriot
    Patriot [OP] Member
    Hey great looking Tundra, thanks for posting Up pics!
  22. Feb 3, 2017 at 1:20 PM
    Patriot
    Patriot [OP] Member
    Thanks Rancid13...I just got back from a trip to my local Discount Tire shop and the rep the says 295/65/20 Michelin Defender MS2's will fit post Boss 3" lift install... I am skeptical and don't think so...it's a 35" tire. We'll see next week.
    It says here 285/65/20 will fit, so maybe a 295 will fit no trimming?
  23. Feb 3, 2017 at 1:25 PM
    rkboyer911
    rkboyer911 New Member
    14 Platinum crewmax
    Watching!!
  24. Feb 3, 2017 at 1:59 PM
    Rancid13
    Rancid13 New Member
    Jax Beach, FL
    2011 4x4 DC SR5
    I almost went that route but, ironically enough, the guy at my local discount tire talked me out of it. He didn't say it wouldn't fit but strongly suggested it. I didn't feel like chopping the body mount or getting new UCA's at the time (still don't) so I didn't take the chance. Hopefully for you they fit! Post pics!
  25. Feb 9, 2017 at 5:34 AM
    Patriot
    Patriot [OP] Member
    Had my TT Boss lift installed yesterday and am very happy with the results and ride. The install took 4 hrs. Left the lift shop and had Michelin 285/60/20 installed on my stock Platinum wheels placing my old 275/55/20's. Just decided I was happy with 285/60's and not to roll with the 295/65's. I don't off road at all so this tire and size just makes total sense for my needs. So essentially I bumped up from a 275/55/20 to a 285/60/20. Approx 1.5" in tire height and a little wider. I had the tech trim the front skid plate and mod the front fender well so I have no rubbing issues at all. He did a really neat and clean job even painted the skid plate where he made the cuts. The labor cost of the TT Boss install was $295.00 which included a hunter 4 wheel alignment.
    Discount tire prorated the mileage left on my old Michelin's @$315.00 which I thought was very cool with. Essentially deducting this amount from my new set.
    I like the stock Platinum "purist look" and think I achieved keeping it that way for now. Here are a few pics of before and after. Thanks to the members on this forum for their thoughts and help with questions I know they have heard hundreds of times.
    Before-
    After-
    Post TT Boss Lift- front fender flap removed for clearance.
    Before- stock suspension-
    After- TT Boss 3/1 lift-
    The shop that installed my lift- I highly reccomend their work and would do business again with them.
    CM-LENNY, CaptTyler, Viper3G and 2 others like this.
  26. Feb 9, 2017 at 5:51 AM
    allstar617
    Sy
    Boston,Ma
    Looking good
  27. Feb 9, 2017 at 6:38 AM
    Rancid13
    Rancid13 New Member
    Jax Beach, FL
    2011 4x4 DC SR5
    Man that looks super clean! Nice job
  28. Feb 9, 2017 at 6:42 AM
    Rancid13
    Rancid13 New Member
    Jax Beach, FL
    2011 4x4 DC SR5
    hey Allstar, got any straight on pics of how much the tires stick out with those spacers?
  29. Feb 9, 2017 at 11:05 AM
    Patriot
    Patriot [OP] Member
    Thanks guys!
  30. Feb 10, 2017 at 9:40 AM
    Tundra Pirate
    Tundra Pirate Bamf
    Kelly
    Stanley, NC
    2014 Super White Tundra Crewmax 4x4 Limited
    Bilsteins 5100 Leveled Method NV Machine KO2
    Hey Patriot looks as if we are from the same neck of the woods!!!
