platinum/ 1794 tundra tire measurements ON truck
Discussion in '2.5 Gen Tundras (2014-2021)' started by DexterL, Mar 9, 2020.
  1. Mar 9, 2020 at 6:10 PM
    DexterL
    DexterL [OP] New Member
    21 lunar rock TRD pro Seqouia
    Looking to get a measurement of newish stock 20in 275/65/20 tires on a truck- in inches preferably! Going to battle with a hypertech inline speedo recalibrator and this would make it much easier on getting the settings right. Even bigger win if you have a topper + decked system and an aftermarket bumper + winch- wishful thinking! Thanks everyone!
    edited for tire size
  2. Mar 9, 2020 at 6:37 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Manufacturers diameter won't work for you? Air pressure is going to make a diff on installed tires. Formula for a 275/60/20 = 275/25.4×.6x2 + 20" . This is general. Manufacturers diameters will vary somewhat.
  3. Mar 9, 2020 at 6:40 PM
    DexterL
    Nope, need it on the truck, on the ground for most accurate reading.
  4. Mar 9, 2020 at 6:44 PM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Not going to get most accurate due to different manufacturers, PSI, weight, tread depth, Etc.
  5. Mar 9, 2020 at 8:28 PM
    Fastestcolor
    Fastestcolor New Member
    Blue Ribbon Limited CM
    Those tires aren’t much bigger than the stock 275/55/20 that come on it. Well at least compared to what most folks on here put on.
    i put 275/60/20 Michelin LTX defenders on my limited. It looks great and after having these tires go 70,000 on my 4runner I won’t put anything else on a mostly street truck.
    I’m rambling but honestly recalibration my speedometer is the last thing I’m thinking about. It can’t be off by a noticeable amount.
  6. Mar 10, 2020 at 11:37 AM
    DexterL
  7. Mar 13, 2020 at 7:25 AM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    I measured my 275/65/20 Cooper AT3 XLT @45 psi and it's measuring 33.25" with 7K miles on it. It's far less than the state 34.1" spec.
