Plastic Dip Wheels
Discussion in 'Wheels & Tires' started by alpinepro4, Mar 30, 2020.
  1. Mar 30, 2020 at 1:12 PM
    alpinepro4
    alpinepro4 [OP] What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I am going to plastic dip a set of wheels is it better to spray on with or without tires mounted?
    Y0TA PR0 likes this.
  2. Mar 30, 2020 at 1:19 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    When I had my Tacoma I plastidiped the wheels with them on. It was PITA to cover the disc brakes and calipers. If I do it again I’d take them off.
  3. Mar 30, 2020 at 1:22 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Tires on wheels, but wheels off truck.
    YeeYeeTundra likes this.
  4. Mar 30, 2020 at 1:59 PM
    Swarley
    Swarley New Member
    I sprayed my wheels recently with them on, would probably take them off next time. Just easier to get all the angles covered.
  5. Mar 30, 2020 at 3:36 PM
    Pairodice
    Pairodice New Member
    Jay
    Wd40 works great to remove it
  6. Mar 30, 2020 at 3:41 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  7. Mar 30, 2020 at 3:49 PM
    alpinepro4
    Pat
    I have the wheels un mounted. Sounds like tires off is the route to go.
  8. Mar 30, 2020 at 4:45 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I did mine with them on. Wasn't bad at all. I did roll the truck back to rotate the wheels once. You need them standing up anyway for the sprayer to work so no reason to remove them. Plus it just risks damaging your fresh dip job when putting them back on
    I used index cards to block the tires but you can probably get away with dip release or carefully over applied tire shine so it's easier to peel.
    TXMiamiFan likes this.
  9. Mar 30, 2020 at 4:47 PM
    Pudge
    CT
    Oh I just saw you don't have tires on the wheels you're planning to dip.
    I would be very concerned that the dip will be damaged when putting the tires back on. I'm 99% sure it will get fucked up.
    Since you have the tires off, if you can afford it and 2 days of downtime....get the wheels powder coated.
    My advice is done dip wheels without tires mounted.
  10. Mar 30, 2020 at 4:58 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Agreed with both points - the dip will absolutely get screwed up by the mounting machine. I've got the TVD Vinyl overlays on mine, which are more durable than PD, and they got pretty nicked up when my tires were put on. I would go the powder coat route if you have the time and cash for it.
    YeeYeeTundra and Pudge[QUOTED] like this.
  11. Mar 30, 2020 at 5:58 PM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    It will definitely get torn off when you put rubber on rim. Speaking from personal experience. Use note cards around rim and take rims off car (w/tires on rim) if at all possible. Otherwise use note cards as above and plastic inside rim over brake system.
    Post up before and after pics to brag and you'll be all set. (Go many coats starting very light and first)
  12. Mar 30, 2020 at 6:01 PM
    Swarley
    Swarley New Member
    Agreed, I had PD because I wasn’t sure I wanted my wheels black permanently. I’d probably powder coat down the line.
