Plasti-dip
Discussion in 'General Tundra Discussion' started by Ike74, Jun 5, 2018.
  1. Jun 5, 2018 at 2:12 PM
    Ike74
    Ike74 [OP] New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    I have a noob question, but can someone provide a really good step-by-step pictorial of plasti-dipping the badges? I see a lot of guys leaving on the truck while dipping, and I cannot figure out how they are leaving the dip perfectly on the badges, but not on the paint inside of the letters when that part never seems to be tapped off.
    fundra_goes_west likes this.
  2. Jun 5, 2018 at 2:16 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Someone might have good photos to add, but basically the dip will not bridge the gap between the badge and the body, or if it does, it will be thin and easily separate when you pull on it. You can take a toothpick to roll up the edge of the dip on the body panel inside the letter, and once you have enough rolled up to grab with fingers or tweezers if it is a small space, then pull that off - it will not (should not) pull the dip off the badge; should separate at the edge of the badge. Some people run a tooth pick along the edges (between badge and body) between layers to make sure that it is separated.
    I hope that makes sense...
  3. Jun 5, 2018 at 2:19 PM
    What the!?
    What the!? New Member
    2017 Pro
    Check the DipYourCar channel on YouTube. It’ll explain how to plastidip your car, emblems, window trim, etc.
    jewsNbrews likes this.
  4. Jun 5, 2018 at 2:21 PM
    When I dipped my badges, I taped 1" away from badges, and got the Sunday paper and covered area for overspray, I did 4-5 light coats, 30 minutes between each coat and let dry as can says to do, I used bamboo skewers to remove from inside letters pry and twist off, I did this mid-late 2016 still holding up
  5. Jun 5, 2018 at 2:26 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Make sure to spray thick so it peels off easier. I made the mistake that I didn't and now I have a project to redo on the truck. Keep your can warm (in sun or in warm water) so it sprays easier. After each coat, flip can upside down and spray the gunk off the nozzle.
    Pigglet222 and Les7311 like this.
  6. Jun 5, 2018 at 2:28 PM
  7. Jun 5, 2018 at 2:28 PM
    Boerseun
    Ferdie
    Sarasota Florida
  8. Jun 5, 2018 at 2:29 PM
    TXMiamiFan
    Jose
  9. Jun 5, 2018 at 2:38 PM
    Nickhood23
    Nickhood23 New Member
    Murfreesboro, TN
    2012 SR5 CM SUPER WHITE
    Follow this video man it's hard to mess up plastidip I'm literally drinking beer right now plastidiping my whole Rav4 matte black lol warm the cans in hot water makes all the difference
    Watch "How to Plasti Dip Badges" on YouTube
    https://youtu.be/vGBOteFrPfo
    Krezz, sprtbkr and TXRailRoadBandit73 like this.
  10. Jun 5, 2018 at 2:42 PM
    Nickhood23
    Murfreesboro, TN
    Its old and beat to shit anyways. Sunny day out and some cold beer i thought why not
  11. Jun 5, 2018 at 5:32 PM
    Professional Hand Model
    Hand Protectors
    My plasti-dips shares are banking!
  12. Jun 5, 2018 at 5:47 PM
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    It is on the inside of the letters. I too used a bamboo skewer to get it out like someone said. I’m new to this stuff and I promise you watch 2-3 videos and go at it. The key is to make sure it is on thick enough. If you spray light it won’t come off as easy. Just do it.
  13. Jun 5, 2018 at 7:13 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    55BCC651-AB9D-42A3-889B-AD04FC5D7412.jpg And if you get some overspray to the paint, use a damp cloth and wipe away gently.
    I sprayed outdoor with light wind
  14. Jun 6, 2018 at 7:53 AM
    Ike74
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    Thanks everyone for the information. plan on plasti-dipping fairly soon. Provided I get the Sunny back from the shop this century.
  15. Jun 6, 2018 at 8:56 AM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    I’ve plasti dipped a lot of stuff and tried doing my badges on the truck. Came out like shit and I still have residue stuck in the cracks I can’t get out.
    I think the key is using a new bottle and making sure the nozzle is cleared out really well.
