Pismo Beach Road Trip
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Cisko213, Jun 25, 2017.
  1. Jun 25, 2017 at 11:37 AM
    Cisko213
    Cisko213 [OP] New Member
    So Cal
    2016 Tundra TRD Pro
    Retrofit Headlights, Baja Design Fogs
    Took my boys on a little road trip this past week with the TRD Pro. Wanted to see what this truck could do stock. First unplanned even was the tide being so high. I stopped coming down here years ago. And at first approach and paying the ocean tide was damn near up the ramp. Leaving no path except to drive on the powdery soft pack. Drove into the soft packed sand. Quickly aired down and was off. Took the truck into the dunes. Hoping to not get stuck. Truck and tires performed better than expected. I just didn't feel confident enough to pull anybody out stuck in the muck. Truck performed better than expected. Toyed around with no problems.
    Allrsdup, 619Tundra, drobb and 12 others like this.
  2. Jun 25, 2017 at 4:11 PM
    Always a great time at Pismo. Thanks for sharing.
    Rica25 likes this.
  3. Jun 26, 2017 at 6:40 PM
    fjorge2323
    fjorge2323 New Member
    2016 TRD off road Tundra
    That is is an awesome experience with your family. How much did you have to air down? I am planning on being at the dunes next month. Thanks
    Rica25 likes this.
  4. Jun 27, 2017 at 9:21 AM
    15whtrd
    15whtrd Mr. Blonde
    In my experience at Pismo beach with a 2wd truck in the past, was it all depends on the rim size tire size and weight of the vehicle. My 2wd regular cab short bed ram with 20 inch wheels seem to like to be air down to 15 to 20 PSI to get a nice float. You're trying to broaden the footprint. Just make note that now that you are aired down you run the risk of popping a bead on the tire if you take turns too hard. I had no problems cruising around in the soft sand with that truck but I didn't want to risk going back into the dunes with it. But once you get rolling and the rest is pretty easy. I always made sure I stopped in a good spot where I could get going again. Now with the tundra being a heavier vehicle but also having 4 x 4 I would think 20 PSI is a good place to start. No my buddy had an old 85 jeep with the V8 conversion and it was very light also being on mud terrain 35 inch tires we air down to around 8-12 psi before it would even start to bulge. I watched a lot of people make the mistake of blooming airing down the rear tires of their trucks and the front tires with just knife into the sand and they would get stuck. Typically I'm looking for the same amount of bulge in front and rear so the front I wouldn't air down quite as much as the rear. I'm not an expert but I have been to Pismo Beach many times and this formula worked for me. Hope that helps.
    Sunnier, Rica25 and Cisko213[OP] like this.
  5. Jun 27, 2017 at 10:20 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I was out there on Saturday cruising around while waiting for my girlfriend at her friend's wedding nearby..
  6. Jun 27, 2017 at 10:24 AM
    SlickRick2013Tundra
    SlickRick2013Tundra #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
    Man i surely do miss piano
    Great pics guys
    Rica25 likes this.
  7. Jun 27, 2017 at 11:17 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Nice. But, come on man. We all know you have more pics that just that one. Load 'em up so we can see more shots.
    Rica25, SlickRick2013Tundra and JC303 like this.
  8. Jun 27, 2017 at 11:40 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    I'm about to do a family vacation down there for a few days; looking forward to it.
  9. Jun 28, 2017 at 10:46 PM
    Cisko213
    So Cal
    2016 Tundra TRD Pro
    I aired down to about 23lbs. I still wanted to drive around town. I could have gone lower but didn't want to risk busting a bead
    Rica25 and Tundrado like this.
  10. Jun 28, 2017 at 10:48 PM
    Cisko213
    So Cal
    2016 Tundra TRD Pro
    Its hard to be camera man and Driver/Dad at the same time. Next time I plan to get some more.
  11. Jun 28, 2017 at 10:50 PM
    Cisko213
    So Cal
    2016 Tundra TRD Pro
    Thinking about that rack but worried how you wash the top of the truck when you need too?
  12. Jan 15, 2021 at 7:25 PM
    Rica25
    Ricardo
    Tulare
    Taking my 2wd to the Oceano Dunes tomorrow
    porkitt, junior and Sunnier like this.
  13. Jan 15, 2021 at 7:44 PM
    Sunnier
    Sunny
    San Diego, CA
    @fjorge2323 what @15whtrd said should get you through! I’ve driven a stock 2017 TRD 2wd with stock Michelin tires, aired down, all over Anza Borrego sand, and did fine.
    Additional hints are: keep distance in front of you so you don’t have to make sudden stops... keeping the tires moving through anything soft avoids getting stuck. Also, when you have a planned stopped, in addition to looking for former ground, let up on the gas and slow without using much brake; if you brake to stop, that build-up of sand in front of your tires can be an obstacle to getting moving again.
    15whtrd[QUOTED] and Rica25 like this.
  14. Jan 15, 2021 at 10:24 PM
    Rica25
    Ricardo
    Tulare
    Last time I took mine to the dunes was about 2011. It was stock height and highway tires towing a 34 foot trailer. So its been a while lol.......so let's see how it does now.
    Sunnier likes this.
  15. Jan 16, 2021 at 1:28 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    When you say dunes, I think of my days in Glamis, California...
    Brought my old 58 Baja Bug and 80 Toyo Long Bed to the party. Great memories
    drobb, Sunnier and Rica25[QUOTED] like this.
  16. Jan 16, 2021 at 10:54 PM
    Rica25
    Ricardo
    Tulare
  17. Jan 17, 2021 at 6:18 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    So do I, it was my second home for a long time.
    OP, thanks for the report. Its impossible to not have a great time there.
    Rica25 likes this.
