picture of underside of truck with off road package?
Discussion in '3rd Gen Tundras (2022+)' started by 23 Platinum, Jan 14, 2025.
  1. Jan 14, 2025 at 1:54 AM
    23 Platinum
    23 Platinum [OP] 25 Platinum Off-road
    California
    25 Tundra Silver Platinum off-road
    Any pictures of underside of truck with off road package? I did a search on here and didn't see any photos. Just wondering how substantial the skid plates are.
  2. Jan 14, 2025 at 2:54 AM
    raylo
    raylo not so new member
    Frederick, MD
    Only OEM skid plate I have is the front, and that was called out as a separate option, so not actually part of the OR package. At least in 2023. It is pretty substantial, made from heavy duty aluminum. It's a bit of a PITA to deal with during oil changes since it needs to be removed. I have since added a cat shield that is like another skid plate of sorts. There are several aftermarket vendors that have full skid packages.
  3. Jan 14, 2025 at 4:36 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    '24 here, and same as raylo.
    It's fairly common to see the TRD Off Road package equipped trucks with the optional TRD PRO skid plate.
    It's the one and only skid plate that's offered as O.E. (At least on a non-TRD PRO?)
    Not sure if all, but most of the aftermarket offerings have an oil filter/drain access cover that make oil changes easier.
    The TRD version is a little clunky and awkward to remove and replace.
    It is stout enough to jack on and lift the front of the truck.
  4. Jan 14, 2025 at 4:51 AM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Keep in mind the skid plate above is the ‘ST’ option for $380 in 2024. It is substantial.
    My nephews is a 24 SR5 TRD Off Road without the option. His came with a ‘plastic’ (?) skid plate.
    ScottieBones and 23 Platinum[OP] like this.
  5. Jan 14, 2025 at 4:56 AM
    BlackNBlu
    Rich
    MN
    'ST' ??
  6. Jan 14, 2025 at 4:58 AM
    MaineTundy
    On the sticker. Skid plate option is separate from TRD OR package.
  7. Jan 14, 2025 at 5:12 AM
    tlpilot30
    tlpilot30 New Member
    Can someone post a picture of the TRD Off Road Package skid plate..it seems to me that the one pictured above will not be included in that package and I would have to order it separately to get that one. Thanks
    23 Platinum[OP] likes this.
  8. Jan 14, 2025 at 5:16 AM
    BlackNBlu
    Rich
    MN
    Don't have a picture handy, but it's not much to look at.
    Not much more than a glorified splash shield. Definitely wouldn't call it a skid plate.
    23 Platinum[OP] and troutback like this.
  9. Jan 14, 2025 at 5:43 AM
    23 Platinum
    California
    Bummer, mine didn't come with the TRD skid plate option.
  10. Jan 14, 2025 at 5:46 AM
    raylo
    Frederick, MD
    Easy enough to go buy one and pop it on.
    TRDoffroadPRO likes this.
  11. Jan 14, 2025 at 5:50 AM
    23 Platinum
    California
    True, but I figured the off road package said skid plates, turns out not really
    troutback likes this.
  12. Jan 14, 2025 at 6:57 PM
    troutback
    troutback New Member
    2023 Blueprint SR5 CC
    The TRD OR skid plate is thin and is not really a skid plate as you would think it should be. I was surprised by what they consider a skid plate. I put a Talons Garage skid plate for the catalytic converter. I still need to replace the pitiful OE engine skid plate. I’ll snap a photo tomorrow of the engine skid.
  13. Jan 14, 2025 at 7:47 PM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Google is your friend. This is it, pretty useless, the front diff is a sitting duck for a rock or the like to smash it. If you hit that plastic skid plate, next in line is lower and exposed. I’ll be purchasing a trd pro skid once I can swallow the over $700 price here in Canada after tax.
  14. Jan 14, 2025 at 8:29 PM
    23 Platinum
    California
    Sad. I'll probably roll with the Talon Kit
  15. Jan 14, 2025 at 9:38 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    I would go with the Talon skid. I have it for my cat shield/trans skid and it's beefy. The standard TRD OR skid is a pathetic attempt at a skid plate and will do close to nothing. Going to be adding the Talon engine skid, which will cure the issue.
    troutback and 23 Platinum[OP] like this.
  16. Jan 15, 2025 at 4:16 AM
    raylo
    Frederick, MD
    If I didn't already have the optional Alu TRD skid I'd get the Talons since it has an access panel for oil changes. Looks like it is tight but should be doable. I have their cat shield, and it is solid and mates well with the optional TRD Alu skid. I have gotten used to pulling the Alu TRD skid for oil changes... but the next one that is due soon might be a challenge since I have to do it in the driveway and what with the ridiculous cold winter we are having.
  17. Jan 15, 2025 at 5:09 AM
    Somorris
    Somorris New Member
    I have had the bolts holding the skid plate stripped by a tech at the dealership getting in too big a hurry. The oil change access door is a nice option.
  18. Jan 15, 2025 at 5:17 AM
    BlackNBlu
    Rich
    MN
    This (and time) is why I do my own oil changes and the dealer doesn't touch my truck unless absolutely necessary.
    It's likely I'm going to pick up the Talon cat shield, I might as well get their skid plate too for the access door.
    Somorris[QUOTED] likes this.
  19. Jan 15, 2025 at 5:43 AM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Falken Wildpeak tires
    Not necessarily cheaper, but Canadian made, does skid and cat shields too - check out this site - Myke I believe is still a member here, located in Alberta I think!
    Catalytic Converter Protection Plates
  20. Jan 15, 2025 at 6:33 AM
    iforceAZ
    iforceAZ New Member
    Hey! That's my truck!
    Anyway. I took that off and put on Talon's Garage steel plates
  21. Jan 15, 2025 at 7:02 AM
    raylo
    Frederick, MD
    How does the Talons skid access panel for oil changes work? Can you get to both the filter and drain plugs? How easy or how hard is it?
  22. Jan 15, 2025 at 7:02 AM
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Yeah, I ordered the TRD OR skid plate since I had the package, I have not checked the bolts but I usually do after every oil change. One dealer I go to has an open air oil change center so you can see the techs as they change the oil. Yes the oil change guy or gal is the lowest paid tech in the building, they usually do not care what damage they do.
  23. Jan 15, 2025 at 3:36 PM
    iforceAZ
    iforceAZ New Member
    For the filter there is a removable panel. If you put a hose on the little drain pan for the filter it is easy peasy.
    The drain plug is another story. I stuck a milk jug above the plate cut to size. This directs all the oil out the hole in the plate. Worked ok for me. Takes some finess. A fomoto or ValvoMax drain plug would make it super easy which is likely the route I'm going at the next change.
    raylo[QUOTED] likes this.
  24. Jan 15, 2025 at 4:24 PM
    MaineTundy
    I had the RCI skid, with door on previous truck. It was still a pita and could be messy. It was easier to just remove it. Same with new OEM plate.
