Pics with +20 Offset
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2014limited, Jul 22, 2022.
  1. Jul 22, 2022 at 5:36 AM
    2014limited
    2014limited [OP] New Member
    Kevin
    2014 Tundra Limited
    I was looking at some Fuel 20X9 wheels with +20 offset on a 2014. This looks to be the least amount of poke out you can get. Does anybody have pics running +20? I’d like to see how much they stick out. I have factory flares but they are pretty minimal coverage. I like the slight poke out look but it’s my daily and I don’t want crap thrown on the side of it constantly + drive gravel often. The Fuel site has a gallery but doesn’t list offset detail which is kind of stupid in my opinion.
    Thanks
  2. Jul 22, 2022 at 8:17 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Check out the suspension and wheel/tire forums here. Thousands of pics with details on peoples setups. Lots of rims in the +18 to +25 range and that is a popular offset so you will be able to see lots of examples.
    2014limited[OP] likes this.
  3. Jul 22, 2022 at 1:20 PM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    Here’s my +20 Fuels. Had flares on but took them off so I could redo the rubber seal. Will probably leave them off for awhile.
    WinterWarlock21 likes this.
  4. Jul 22, 2022 at 1:33 PM
    2014limited
    Kevin
    2014 Tundra Limited
    Thanks for this. Yours is spec’d just like mine. They stick out about as much as I thought they would. Do you notice a lot of stuff getting thrown on the side?
  5. Jul 22, 2022 at 1:52 PM
    SpyderRC
    SpyderRC New Member
    I’ve only had my flares off for about two weeks now, so I can’t say for sure. I plan on keeping them off for awhile, so hopefully I won’t get too much thrown into the side of my truck.
  6. Jul 22, 2022 at 2:32 PM
    2014limited
    Kevin
    2014 Tundra Limited
    Thanks again. I know the poke out is mostly due to the wheel being 20X9 vs 20X8. Sucks because if you Google the 8” then it’s pretty much OEM only, but change to to 9” and you find endless options. Definitely love the look, but like a clean truck as well.
  7. Jul 23, 2022 at 8:41 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I have +20. Got some good mud flaps and no issues. No flares.
  8. Jul 23, 2022 at 8:43 AM
    1UP
    1UP Truck Gang
  9. Jul 23, 2022 at 9:06 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Man, that scoop sure looks like on that Barcelona Red Tundy!
    1UP[QUOTED] likes this.
  10. Jul 23, 2022 at 9:06 AM
    2014limited
    Kevin
    2014 Tundra Limited
    Looks good. Thanks. I will probably just order them and deal with it. Best I can tell if you want aftermarket you have to jump to 9” wide and deal with some poke out. Guess if I’m worried about some of the lower areas, that’s what PPF is for.
  11. Jul 23, 2022 at 9:59 AM
    1UP
    1UP Truck Gang
    Check out Rokblockz mudflaps. Expensive but I have had zero issues or buyers remorse.
  12. Jul 23, 2022 at 10:19 AM
    2014limited
    Kevin
    2014 Tundra Limited
    Thanks. Did you go with the XL size I assume?
