Pics of the part of your job that sucks the most....EXCLUDING HUMAN SUFFERING!
Discussion in 'Off-Topic Discussion' started by TomC843, Aug 31, 2019.
  1. Aug 31, 2019 at 10:12 PM
    TomC843
    TomC843 [OP] The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    I used the general term "I do HVAC" when asked what I do. But the longer answer is I mainly work in restaurants specializing in commercial cooking equipment and refrigeration, along with HVAC. I had to pull out a drawer cooler with a grill sitting on it this morning to get to the compressor compartment that in the back. In the pics you see the panel that I needed to access. Not a lot of fun. If any one claims to be real picky about food and eats out anywhere I just laugh to my self. This is not unusual in my 30 year experience on any equipment hard to pull out. Please share pic of the shitty part of the job.
  2. Aug 31, 2019 at 10:24 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
  3. Aug 31, 2019 at 10:45 PM
    AZTundra
    Paul
    Phoenix, AZ
    Health inspector doesn't check down there? :eek2:
    YardBird, Tundra234 and TomC843[OP] like this.
  4. Aug 31, 2019 at 10:49 PM
    Marty McFly
    Morty McBoonJug
    I wish I could unsee that
  5. Aug 31, 2019 at 10:53 PM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    I learn so many non-truck things here.:playball:
  6. Aug 31, 2019 at 11:02 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I have worked as an ER nurse for 15 years. So.......yeah I have stories and mental images. Nothing I can share here unfortunately
    Jorgy1, Tundra2, ColoradoTJ and 16 others like this.
  7. Aug 31, 2019 at 11:14 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
  8. Sep 1, 2019 at 12:36 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Dear lord.
    BestGen likes this.
  9. Sep 1, 2019 at 1:40 AM
    Sorry, no pics, just description, for me working the railroad with OTC (On Track Equipment) when hydraulic lines bust, sprays all over machine, then you can't see where it's coming from from, so you have to have another set of eyes see when you turn hydraulics on, then get In that area to change the hose, so you get wet with hydraulic, some parts are so gunked up with grease work clothes, arms covered up with old grease, yeah I like it
  10. Sep 1, 2019 at 2:00 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I did a lot of that in the past, but no more.
    The worst work environment these days are small dank well houses, filled with all sorts of nasty critters large & small. I'll return to this well house in a week or so to swap out an old filter for a new one, this large spider watched me work last time.
  11. Sep 1, 2019 at 3:56 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    That's an intense job. I bet you have some stories. I've been veterinarian for 19 years. Most people probably don't want to see what I've seen. But, with the bad comes a whole lot of good.:)
  12. Sep 1, 2019 at 8:16 AM
    TomC843
    Tom
    Charleston, SC
    Lol, they
    check dish machine temps, food temps, door gaskets, and make sure food things are labeled correctly. If a health inspector was more like a technician and moved things places would close left and right. If they carried a screw driver and removed the front cover of an ice machine no gas station soda machine would be in use.
    Trooper2, Boerseun and jewsNbrews like this.
  13. Sep 1, 2019 at 8:19 AM
    TomC843
    Tom
    Charleston, SC
    That is the only way to think if it really bothers you. It's every where.
    Marty McFly[QUOTED] likes this.
  14. Sep 1, 2019 at 8:24 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    OMG stop it, just let me live in my clean bubble.
    Bob_Wiley, Ostrich, GODZILLA and 2 others like this.
  15. Sep 1, 2019 at 8:27 AM
    Outbound
    Aaron
    Northern Alberta
    No pics but two things stand out from early in my welding career. First was when I had just entered the trade. The company I worked for then got the refurbishment contract for the local wastewater treatment plant. Working on scaffolding right above the sewage water and the humidity in the building was nasty. I'd drive home after work with all the windows open, have a 30 min shower and I could still smell it.
    Second was just a lousy part of being a welder in the field. Air-arc gouging pile caps off while lying underneath a compressor building on a remote site in the pouring rain. Of course, drainage on the site sucked and the water would run under and pool underneath the buildings. Cold, wet, and muddy for a week straight...
  16. Sep 1, 2019 at 8:31 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Similar to @Pudge , HIPPA prevents pictures. I work in a surgery clinic. Lots of wonderful wounds and infections
  17. Sep 1, 2019 at 8:43 AM
    TomC843
    Tom
    Charleston, SC
    Oh I will never tell you where these are. Just shearing the fun times.
  18. Sep 1, 2019 at 8:48 AM
    TomC843
    Tom
    Charleston, SC
    Few years ago stores started putting the ice machine on top of the soda machine so employees did not have to fill ice bin on top any more. Now it is out of sight and out of mind. What 80% on ice machines look like inside.
    Leo's first and jewsNbrews like this.
  19. Sep 1, 2019 at 9:10 AM
    gm125800
    gm125800 New Member
    2018 GMC Sierra Denali
    Damn, it’s stuff like this that makes me reluctant to get back on the field. Every summer I get the itch to run calls again.
    Obligatory pic of what I always ran into.
    Homeowner states they “always” change their air filters....
  20. Sep 1, 2019 at 9:15 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    pics of the part of your job that sucks the most
    How do I take a picture of other people's inherent stupidity manifesting in lack of forethought? Half of my day is spent putting out fires.
  21. Sep 1, 2019 at 9:21 AM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    That’s going to change my purchasing decisions now
    jewsNbrews likes this.
  22. Sep 1, 2019 at 9:47 AM
    NR-J
    NR-J New Member
    Justin
    2015 white tundra
    That used to be my job when I did low voltage work. Lots of tight, hot attic spaces. I think the worst part was all the roofing nails sticking me in the back and head.
    I got my pants stuck one time doing a security job. I was splayed out squeezing under one roof line trying not to fall thru the drywall and my pants hooked bad on a gusset plate. I had to kick my shoes off, brace myself, reach down and undo my belt and crawl out of my pants. I walked over in my boxers and got my wire, then went back and unhooked my pants. That was a super itchy day.
    Leo's first likes this.
  23. Sep 1, 2019 at 9:55 AM
    P-Factor
    P-Factor New Member
  24. Sep 1, 2019 at 10:05 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    The worst part of my job is knowing my customer is wrong and not being able to tell them. Also, I make suggestions that would save them money and they don't take them.
    You can lead a horse to water...
    The next time I get a nasty email I'll post a screenshot.
  25. Sep 1, 2019 at 10:59 AM
    TomC843
    Tom
    Charleston, SC
    Or "what air filter" from a renter.
    gm125800[QUOTED] and GODZILLA like this.
  26. Sep 1, 2019 at 12:50 PM
    Cannaday57
    Cannaday57 New Member
    Tyler
    I'm a distiller, spontaneous fermentation. The ground is usually blue.
  27. Sep 1, 2019 at 1:04 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Check your voicemail... might be your boss.
    Jerry311SD likes this.
  28. Sep 1, 2019 at 1:09 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I worked in a bar, kitchen was disgusting behind appliances. Food was still great.
  29. Sep 1, 2019 at 8:45 PM
    GNTundra
    Gino
    2013 White
    Gotta be the weather for me.
    :mad: :eek: :D20190224_012618.jpg 20190224_012613.jpg 20190224_012620.jpg
  30. Sep 1, 2019 at 9:45 PM
    Pudge
    CT
    Ok ill share one pic from work, not really of my work but the result of something that happened at work. Was wrestling with a psychotic patient and I blew out my knee. The orthopedic Dr fixed me up really good and my new knee is as good or better than the one I was born with :militarypress:
