Pics of Method wheels on your 2.5 gen
Discussion in '2.5 Gen Tundras (2014-2021)' started by Willskaf, Jan 26, 2020.
  1. Jan 26, 2020 at 8:25 PM
    Willskaf
    Willskaf [OP] New Member
    William
    Castro Valley, CA
    19, Limited, CrewMax, Off Road, Cement Gray
    None Yet
    Does anyone have these on their Tundra? Can you please post a picture. I'm thinking of going with these .
  2. Jan 26, 2020 at 8:37 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    17 inch bronze. Only pic I have at the moment. @Pinay has 20 inch.
  3. Jan 26, 2020 at 8:39 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Thanks man. What size tires are those and what offset ?
  4. Jan 26, 2020 at 8:42 PM
    HappyGilmore
    Trent
    Lakewood CA
    35 by 12.5 and 0 offset, so they stick out a bit. 17s only come in 0.
  5. Jan 26, 2020 at 8:44 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Looks awesome . I love that you don't have a huge lift. They fill the wheel well perfectly. That's exactly what I'm looking for. what do you have as a Lift? Did you have to do any body chop?
  6. Jan 26, 2020 at 8:50 PM
    HappyGilmore
    Trent
    Lakewood CA
    Thank you. 5100s on the 2.25 setting. No body chop, but there is ever so slight rubbing in reverse sometimes. I did have to trim my front bumper caps about a half inch and reattach the liners. But that's only because my wheel is 0 offset so it sweeps wide on turns. I also aligned it to push the wheels as far forward as possible.
  7. Jan 26, 2020 at 8:52 PM
    HappyGilmore
    Trent
    Lakewood CA
    Also I dont have a lift in the rear. I have an unpopular preference of the front being slightly higher or level.
    Voyagermike likes this.
  8. Jan 26, 2020 at 9:01 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    So here is what I'm trying to do and wonder if you think it will work. I would like to go with the same wheels 18x9 or 17x9 whichever will look better. Since it's my daily driver, I'm going to go with 295/70/18 or 17 Nitto Ridge Grapplers which equates to 34.5 inches. Instead of cutting the plastic on the front, I'm going to install bumper shims to push it forward. I'm also going to go with either a 2" spacer lift on the front or 6112 Bilstein with 2". I'm trying to avoid rubbing or any body chop . I've been doing my homework and I think I'm able to get away with this without rubbing. Your thoughts
    Rica25 likes this.
  9. Jan 26, 2020 at 9:02 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    I'm leaving the back the same height
    Rica25 likes this.
  10. Jan 27, 2020 at 8:52 AM
    HappyGilmore
    Trent
    Lakewood CA
    If you go with an 18 inch wheel that has some offset with that tire, you will probably be fine with that set up you mentioned.
    Rica25 likes this.
  11. Jan 27, 2020 at 3:12 PM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    I am running Method NV on 295-70-18 with Nittos no BMC only had to heat and mold inner plastic very slight rub backing at full lock. Toytec boss lift @ 3" FRONT ….rear has add-a-leaf and bags.
  12. Jan 27, 2020 at 9:43 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Thanks fellas.
    Rica25 likes this.
  13. Jan 27, 2020 at 9:49 PM
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    I will have method double standards installed in a week when they come in. Stock tire size (18") and no lift. Should have no rub or mod.
    Rica25 likes this.
  14. May 17, 2020 at 8:14 AM
    BoxersBrew
    BoxersBrew New Member
    Thomas
    Northern Virginia
    2020 Black Tundra Limited Crewmax TRD
    Dealer installed TRD dual exhaust system and tonneau cover. Personally installed TRD Pro grille and surround, side mirror caps, and TRD shifter.
    :worthless:
    pnw.tundra likes this.
  15. May 17, 2020 at 9:36 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    I went with the MR304 18in +25 and really like them
    Tundra805, Wallygator and drobb like this.
  16. May 17, 2020 at 11:12 AM
    buckeyeinlv
    buckeyeinlv International Man of Mystery
    Brandon
    Henderson, NV
    2020 Army Green TRD Pro CrewMax
    OEM Power Tailgate Lock, Peragon Tonneau Cover, S&B Intake, Bora 1” Spacers, ceramic window tint. Interior: OCD Organizer, AJT Designs Cup Tray and Shift Trim, JDMCar Rubber inserts. Tires: 285/70R18 Old Truck: Base:2017 Inferno SR5 CM 4x4 Mods: Interior- OCD organizer, Proclip USA iPhone X Mount, Wireless center console charger, TRD shift knob. Exterior- Backflip G2 Tonneau Cover, Amp Research Powersteps and Bed Step, Pop and Lock tailgate lock, Ceramic window tint, Blackout emblems, TRD Pro Grille, Stubby antenna, Vinyl American flag TRD graphics, Color matched and bullet lined bumper ends, 18x9/+25 Method NV305 Bronze wheels Engine- Stock
    Here is a picture of my old truck with 18” NV305’s, I didn’t keep it long enough to upgrade to better tires.
    InfernoToyo and Wallygator like this.
  17. May 17, 2020 at 11:30 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Method NV 18x9 +25 offset on 295/70/18 Toyo AT 2 Extremes.
  18. May 17, 2020 at 1:42 PM
    BoxersBrew
    Thomas
    Northern Virginia
    I just picked up a set of four TRD Pro wheels for $650 off Craigslist, 2,000 miles on them. Guess I'll be rocking these soon. Thanks for all the info and pics though.
    COTundra23, 17inferno and Wallygator like this.
  19. May 17, 2020 at 1:45 PM
    Rica25
    Ricardo
    Tulare
    20200417_181254.jpg not a tundra but I do have one but no methods on it but FJ does have Methods
    Wallygator likes this.
  20. May 17, 2020 at 4:33 PM
    BoxersBrew
    Thomas
    Northern Virginia
    Ok, so now that I have new TRD Pro wheels. Gonna’ try to figure out largest tires I can put on without modifications as with only 700 miles on the truck I would like to keep the two year Toyota care and factory warranty, for now. Any suggestions on largest size and best tires for a little more aggressive profile? I don’t do serious off-roading but do get off road a few times a year.
  21. May 17, 2020 at 5:52 PM
    Flytrap50
    Flytrap50 New Member
    2019 Toyota Tundra TRD PRO Voodoo Blue
    I just got Method 17s and 315 35s. Pretty sweet.
    BoxersBrew likes this.
  22. May 17, 2020 at 6:02 PM
    Deucemimo
    Deucemimo New Member
    2014 Tundra 1794
    Method 305NV 20x9 +25 offset w/275/60/20 Nitto Grapplers and 5100s on front middle setting.
    Ranger2005 and Pac12AfterDark like this.
  23. May 17, 2020 at 6:51 PM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Methods 701s 17s on 35s
  24. May 17, 2020 at 8:26 PM
    Gilby1
    Gilby1 New Member
    David
    ‘16 Blazing Blue Platinum - SOLD, '20 Super White Platinum
    17” Method 312’s with 35x12.5 Toyos.
  25. May 18, 2020 at 6:44 PM
    1engineer
    Appalachians
    Lol
    Tundra805 and BoxersBrew[QUOTED] like this.
  26. May 18, 2020 at 7:15 PM
    BoxersBrew
    Thomas
    Northern Virginia
    Went with the stock tires for now. Will lift and go to more aggressive tires eventually.
    Tundra805 and 1engineer like this.
  27. Nov 13, 2021 at 11:42 AM
    Frog97
    Frog97 New Member
    2014 Tundra SR5 4x4
    I just mounted the new Method 705 in titanium on my 2014. 275/70R18 K02
  28. Nov 14, 2021 at 11:46 AM
    DPlatinum
    DPlatinum New Member
    David
    DFW
    2017 Quicksand SR5 Doublecab 4x4
    Undercover Flex bed cover, Pro grille,2018 led headlights, bed step, console safe, Toytec/Eibach 3” front leveling shocks OEM painted to match fender flares, tow mirrors
    312’s with 315/70/17 Wildpeaks D1D15A37-DACF-4FC0-BEB3-3B12E8E04EE4.jpg
    AirMech74 likes this.
  29. Nov 19, 2021 at 9:56 AM
    Mill72
    Mill72 New Member
    California
    2021 Tundra DC 4x4 TRD
    My ‘21 with 305 NV Machined and my ‘14 304 Double Standard.
    AirMech74 and Rica25 like this.
  30. Nov 19, 2021 at 10:07 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    17x8.5 0 offset 314s
