Phone Charger Tray .... arm rest pad
Discussion in '2.5 Gen Tundras (2014-2021)' started by brandostundra, May 19, 2020.
  1. May 19, 2020 at 7:52 PM
    brandostundra
    brandostundra [OP] New Member
    considering getting one of these phone charger tray kits that install in the arm rest cavity.
    anyone out there have one installed?
    do you think it would still charge if I have an otter box defender case on my phone ?
  2. May 19, 2020 at 7:54 PM
    I don't have the Toyota one, but mine works with my defender case on. I'm sure it would work.
  3. May 19, 2020 at 7:57 PM
  4. May 19, 2020 at 8:00 PM
    Lowgybear and biebs96 like this.
  5. May 19, 2020 at 8:03 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    If wireless charging works with the case and it fits in the hole it’ll work
  6. May 19, 2020 at 8:20 PM
    biebs96
    PA
    I used the same one as @Jim LE 1301
    Remove the top cover of the charger and the backside of the console tray acts as the top.
    Be sure to use a fast charger adapter so you get the full output of the charging pad.
    I bought an extra female 12v socket and wired it underneath the center console, so there is zero exposed wire or plugs.
    https://youtu.be/HXHcqhTXrS0
    Works great. And never slides of disconnects after I added two rubber bumpers for an “as close to factory” look.
    Jim LE 1301 likes this.
  7. May 19, 2020 at 8:23 PM
  8. May 20, 2020 at 6:49 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    I installed an stainless cover on my tray. Do you think the pad has enough power to go through it? It's relatively thin and just an accent piece that I like the looks of.
    https://www.amazon.com/gp/product/B074VRY5K3/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
  9. May 20, 2020 at 7:26 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
  10. May 20, 2020 at 7:52 AM
    1lowlife likes this.
  11. May 20, 2020 at 7:56 AM
    blueshound
    blueshound New Member
    2015 Red Tundra Platinum
    I have a case with a piece of metal attached to my iphone for a magnetic holder, the magent slips into the cd slot of the truck and covers up the touch screen. I can't use wireless charging due to the metal blocking it. I may ditch the metal and do this but I'm not 100% on that since the entune radio is so terrible in the truck. I'd rather use Waze on my phone. I always laugh at the touch screen in the truck because it makes Spotify look like it was designed in 1982.
  12. May 20, 2020 at 9:30 AM
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    I have the South Eastern Parts charger, I have and Otter Box and it charges fine.
  13. May 20, 2020 at 5:19 PM
    Dirtyrat91741
    Dirtyrat91741 New Member
    Randy
    Glendora CA
    2020 SR5 CrewMax
    Stock so far
    I was thinking about this mod, can anyone confirm that the APPLE Car Play will still work?
  14. May 20, 2020 at 6:19 PM
    pillpusher84
    pillpusher84 New Member
    2024 Silverado High Country
    I have retrofitted the 2020 Navigation Radio to my 2019. I also added CPLAY2AIR USB Adapter & CHOETECH wireless charger to armrest tray. I can confirm that My phone charges wirelessly when in the armest holder and my apple carplay also works fantastically (wirelessly)
    wolfeman007 likes this.
  15. May 20, 2020 at 6:28 PM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    I’m sticking with the plug in rather than elbow cancer.
    Borador likes this.
  16. May 30, 2020 at 9:40 AM
    TundraDrew
    TundraDrew New Member
    Drew
    Hahira, GA
    2020 White Tundra 1794 4x4
    Bakflip Revolver X4, Nitto Ridge Grappler 275-60R20
    Apple CarPlay will still work when plugged in, but will charge with the wire even if it's in the charging tray. If you have a wireless CarPlay mod, then it will work and charge in the tray. I would get the Toyota branded wireless charger if you're willing to spend around $170. I just installed mine, it's pretty straightforward, took about an hour.
