Phoenix head end unit?
Discussion in 'Audio & Video' started by AZ555, Mar 6, 2020.
  1. Mar 6, 2020 at 4:47 AM
    AZ555
    AZ555 [OP] New Member
    2018 Tundra TRD Crew Cab 5.7L
  2. Mar 6, 2020 at 5:03 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    My brother-in-law has one in his 2015 1794 CM.
    That's thing is pretty nice. There are settings you have to make based on what truck you have
    but its basically a plug and play unit.
    This FB page is specifically for those units. They will be able to answer prolly every question you have.
  3. Mar 6, 2020 at 6:07 AM
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    If your not tech savvy pass this up. It HATED my JBL system . I sent it back. I wanted Sooooooo bad for it to work right and sound good. I was VERY disappointed even after loading custom FW on it. thats my .o2
  4. Mar 6, 2020 at 6:31 AM
    purplenova
    Tom
    Ohio
    They are not a typical android unit for sure, actually quite the opposite. Large tablet running Android with a ton of settings.
    My BIL got his a while back and hasn't had any issues with his. He is also running Sergey's update and that made things
    run smoother, according to him.
    Other than locating 1 settings after installing aftermarket amp, sub and door speakers, its back to running like it should.
  5. Mar 6, 2020 at 6:45 AM
    ZPMAN
    Minnesota
    I've had the first gen and now have the second gen, they are pretty much plug and play and the sound improvement over the stock JBL is awesome with only stock speakers. It helps to unlimited tethering from phone or hotspot dongle, and you can also mirror you phone if needed. I also added a single sub from Tech12 that was also a big improvement over stock.
    https://shop.tech12volts.com/
  6. Mar 7, 2020 at 1:48 PM
    AZ555
    Thanks... I'll check it out...
  7. Mar 7, 2020 at 1:55 PM
    NateG
    NateG New Member
    Nate
    2015 SR5 Double Cab
    Are these units mainly for android users?
  8. Mar 7, 2020 at 6:42 PM
    AZ555
    I'm not 100% sure, but I believe they will work with iOS phones as well, at least for Bluetooth audio...
  9. Mar 7, 2020 at 7:38 PM
    CPdaddy
    CPdaddy Why am I so tired
    Tom
    Denver
    16 Tundra CrewMax Limited
    Boss 3" Lift, TRD Dual Exhaust, S&B Intake, TRD Rear Sway, 285/75r18 Nitto Ridge Grapplers on Fuel Beast Wheels, SPC upper control arm, Rough Country front bumper with LED bar and dual lights on each side, Rear bumper blackout covers, Go Rhino running boards, Morimoto XB Headlights, HIRev LED Tail Lights
    I had a px6 and loved it for the first week. Note. The first week. I started having little issues, apps opening without prompt, heater turning on to hades setting at full fan, also taking almost 10 minutes for the car play to connect. Finally, after updating all my door speakers to some nice focal components and adding a kenwood xcelon shallow mount 12 the sound was what I wanted ish. I started the truck to thaw my windshield and went in the house to grab some rock salt inside the front door. The stereo then raised the volume all the way to 40, I ran out and turned off the ignition. Too late. I blew every single one of those speakers. After this every time I'd start the truck it would default to 40 for the volume, no matter if you turned it down, it would just go back. I tested this after disconnecting the new amp pushing the new, now useless speakers. I got a full return from them but they would not compensate for the 1k in speakers that were now junk. I busted my nut on buying all those speakers and sub, but I was able to get another set of focals for the front and some hertz for the rear. I replaced the sub with the same one I had and got a kenwood head unit, powered by a 5 channel amp. Sometimes these work great and for those it does, awesome. Buyer beware that these may or may not have flaws and may be an expensive mistake. I will say, the sound quality is much better from the kenwood, since it has a 13 band eq compared to the 3 on the andriod. Also having a crossover that I can set on the head unit, lets me fine tune the sound. Sorry for the rant, but I just thought you peeps should know.
    Foggynogginz likes this.
  10. Mar 7, 2020 at 11:35 PM
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    Ditto that. I had enough and sent that pos packing . I had to many issues that popped up while I was trying to focus on the road.
  11. Mar 7, 2020 at 11:48 PM
    TXTundra2722
    2015 Black Tundra
    I've had mine for 2 years now with way less issues than the stock HU was giving me. This radio is only worth your time if your willing to work with it and set everything up correctly to your specific truck. Just like everything else im sure there are lemons out there, but most people with them that can tinker and have patience get them working correctly. Hate it for the guys that have had issues they couldn't work out.
  12. Mar 8, 2020 at 12:35 AM
    ZPMAN
    Minnesota
    2 years plus for mine, I see alot of people diving in and changing to much and not documenting the changes then get frustrated.
    TXTundra2722 likes this.
  13. Mar 10, 2020 at 12:42 PM
    Foggynogginz
    Foggynogginz New Member
    KC
    2018 Platinum 4x4 CM
    Wow - this is horrible, and this was exactly my fear. Bleeding edge tech can add a lot of risk in an expensive electrical system. Appreciate the heads up. I'll drop this idea in the "Nope" bucket.
  14. Mar 10, 2020 at 8:05 PM
    CPdaddy
    Tom
    Denver
    I do want to be clear that this may not happen to everyone. Some people have a very good experience with theirs and I’m jealous. It’s really nice and I wish it would have worked out.
