Phoenix Automotive HU
Discussion in 'Audio & Video' started by TundraAF, Mar 13, 2024.
  1. Mar 13, 2024 at 11:04 AM
    TundraAF
    TundraAF [OP] New Member
    Cnote
    21 tundra crewmax TRD off-road
    Hey, I want to pull the trigger on the new 13” Tesla style display screen from Phoenix Automotive
    https://phoenixautomotiveinc.com/pr...oyota-tundra-2014-2019?variant=42507883217082
    it says you can run your heated seats through the display. My question is my heated seats didn’t come from factory, they were dealer installed before it was sold. It’s just a small switch with two buttons. Upper button is driver seat and lower button is passenger seat. They’re either on or off, no setting high, medium or low.
    Anyone have something like this installed and know if it should or will work with the Phoenix display?
  2. Mar 13, 2024 at 1:03 PM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I do not have that head unit, but !!! My brother in law did (older model head unit) on his tundra.
    FYI - im also considering purchasing this same unit. Make sure you plug in their discount code!
    With regards to your switch for the seats - there should be a plug for each seat that snaps into the on/off switch.
    I assume the actual plug ends are same size as the oem wiring. Try and pop out the plug to see whats on the back side.
    Those plugs would have a spot in the back of the phoenix unit where they snap in. I dont recall if my BIL had any adjustment
    for low/med/high temps on his. I think they were also on or off.
    Check out this Facebook page. Maybe they can provide additional input.
  3. Mar 14, 2024 at 9:00 PM
    TundraAF
    Cnote
    Contacted them, nope won’t work.
