Phantom power drain
Discussion in 'General Tundra Discussion' started by gosolo, Jun 30, 2016.
  1. Jun 30, 2016 at 2:11 AM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    How long till the battery goes dead when you leave your tundra parked?
    There wasn't enough juice to unlock the door with the key fob when I tried yesterday after returning from work out of state. Been about a month since its been moved.keep it garaged. Anyone else experience this? I know it's going to drain over time but I expected it to hold a change much longer than this.
  2. Jun 30, 2016 at 6:28 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Depends on the draw. A month is a good amount of time. Are you good with a volt meter?
  3. Jun 30, 2016 at 7:05 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I had this happen to me last summer when I put my truck in storage while I drove my summer car. It was in there for a couple of months and when I swapped them back, I had to jump start the truck with the car. As the truck still had its original battery and that was nearly five years old, I bought a new one at the next reasonable opportunity. Now I'm wondering if that was "normal" behavior.
  4. Jun 30, 2016 at 7:07 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Fairly knowledgeable.
    Are you thinking I could check for flow with everything off?
  5. Jun 30, 2016 at 8:19 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Yea that is what i would think. Check what the amp draw is when parked. I know the truck does something a few hours after shutting off the engine. Not sure if it continues over time or if its just a one time thing. Think it is a purge of gas fumes, could be wrong.
  6. Jun 30, 2016 at 9:35 AM
    Mike Tread lightly.
    south carolina
    Clock,radio, fob alarm should be in milliamps.
    Unless you have a bad cell starting to go in the battery...
    Check your battery connections. If you have resistance the higher the draw rate.
  7. Jun 30, 2016 at 11:17 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Pop the hood, lock the doors and remove the key. Looseb the negative cable. Connect your meter on the negative post under the cable keeping a connection and the other lead to the negative cable. Set the meter to the largest amp setting at first... just I case. Then reduce from there depending on reading. Or buy a meter that does it automatically;)
    Anything more than 50 MA is excessive. Or .050 amps. If it is excessive, then start disconnecting power from all aftermarket stuff first. Remember, if u hit the unlock button or open a door with ur meter still connected in series, your gonna blow the fuse in the meter. Good luck!;)
    Wynnded and mdavis like this.
  8. Jun 30, 2016 at 10:21 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Thanks for the feedback and help
