PEX vs copper
Discussion in 'Home Improvement' started by L_S_SHOE, Jan 9, 2022.
  1. Jan 9, 2022 at 7:18 PM
    L_S_SHOE
    L_S_SHOE [OP] New Member
    SE Louisiana
    2021 MGM TRD Pro
    Let’s pretend I’m building a new house and there’s no price difference between PEX and copper plumbing. I’m less concerned with freezing where I live. Is copper the better option? Which would you use and why?
    Thanks in advance.
    Prostar 190 likes this.
  2. Jan 9, 2022 at 7:19 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    You had better provide insulation for either.
    L_S_SHOE[OP] and BlueCrushSC16 like this.
  3. Jan 9, 2022 at 7:25 PM
    DEboater
    DEboater New Member
    2021 DC SR5
    I would be surprised if you can even find someone who would do copper. PEX is the better option hands down.
    D4x4TRD likes this.
  4. Jan 9, 2022 at 7:26 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Don’t take it from me as I’m not a plumber, but I have been in the plumbing and heating wholesale industry for nearly 20 years. Take a tour of the Uponor factory in Minnesota and watch the testing they do on their cross linked polyethylene pipe and it’ll make anyone a believer. Pex hands down in my opinion.
    D4x4TRD and DZ_ like this.
  5. Jan 9, 2022 at 7:26 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    PEX
  6. Jan 9, 2022 at 7:29 PM
    boostedtrdpro
    Jeremy
    Also note there are different grades of pex. I’d strictly use pex-a if it were my house. You can use anyones fitting system (Uponor, Rehau, Heatlink) but I’d definitely stick with pex-a.
  7. Jan 9, 2022 at 7:33 PM
    We are builders and prefer copper over the pex. The only time we use PEX is if we are working on a house that already has it.
    FrenchToasty and Darkness like this.
  8. Jan 9, 2022 at 7:36 PM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    New to me house has pex and aside from initial learning curve of what is pex-a, tools, and fitting types it's really quick and easy to work on even in tight spaces. No more sweating fittings for me!
  9. Jan 9, 2022 at 7:37 PM
    L_S_SHOE
    SE Louisiana
    2021 MGM TRD Pro
    In my area, many of the higher-end custom houses are being built with copper, but I didn’t know if that meant that copper was actually better.
  10. Jan 9, 2022 at 7:39 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Pex for sure, I live in socal so obviously no freezing concerns, but pex is very vulnerable to UV damage so just gotta make sure it's been shielded before you put it in.
  11. Jan 9, 2022 at 7:39 PM
    2mchfun
  12. Jan 9, 2022 at 7:44 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    If you water is very acidic PEX may be preferable.
    With PEX I still use copper stub outs - much cleaner look
    I like crimp rings over other solutions
    Beware cheap chinesium copper
    Use appropriate wall thickness
    I like using manifold in easy to reach location
    Consider the Moen wifi auto leak detector/shutoff
    BlueRibbon4x4 likes this.
  13. Jan 9, 2022 at 7:47 PM
    I should add we always use type L copper.
    FrenchToasty, Darkness and 2mchfun like this.
  14. Jan 9, 2022 at 7:49 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Just curious as to which Pex and pvc pipe you use? As in the company that made it.
  15. Jan 9, 2022 at 7:53 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I stopped plumbing just as PEX started getting really popular, also right after those sharkbite couplers hit the market. I never used or trusted either, granted I never spent the time to learn about either.
    It was my understanding that as mentioned PEX doesn't hold up well in direct sunlight, which shouldn't be a big deal. The other concern was that much like similar "soft" tubing used in manufactured homes, PEX doesn't hold up well to rodents.
    Easier to work with for sure (the joints still make me nervous) and significantly cheaper for parts and labor.
    If I'm doing the work, I would still run copper. Sweating pipe is no big deal as long as you have room to work. As long as you don't have the pipe touching other metals or cement and you use the blue grade it should last a lifetime.
  16. Jan 9, 2022 at 7:59 PM
    2mchfun
    Off the shelf from Home Depot, Lowe's, or Locke supply. Depends on who has what when I need it and where I am at the time. Not brand loyal really. All is pressure tested well above operating pressures after installation.
  17. Jan 9, 2022 at 8:23 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Don’t know about in-house use but I see people putting in pex heated driveways. I personally wouldn’t do that; go with electric coils. Also, if you’re building north of the Mason-Dixon; spend the cash now and put in a heated driveway. Heated driveway comes out to be about the same cost as a broken hip. Even less if you’ve already got things ripped up. Just my $.02.
    Sunnier likes this.
  18. Jan 9, 2022 at 8:26 PM
    X2
  19. Jan 9, 2022 at 8:41 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    I’m in the construction industry (GC) and bar none every building being done in Upstate NY is using Pex. Great product. Easy to install. They have manifolds that you can isolate every line with ease to expand the system, fix issues that may arise, etc. Not to mention the cost in materials let alone the labor difference.
  20. Jan 10, 2022 at 4:28 AM
    DEboater
    DEboater New Member
    2021 DC SR5
    If you have hard water copper can actually be worse, much worse. The labor and time it takes to install copper is much more than PEX. Used to be that material is more as well but who knows right now. They may just be doing copper stub outs or feel better running copper under the slabs down there. Btw my in laws are from Cut Off LA, I went to college at UNO. I hope ya’ll made out okay from IDA.
  21. Jan 10, 2022 at 5:50 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    PEX. Easier to install and or repair. Less likely to have a leak due to a "bad" braze joint.
  22. Jan 10, 2022 at 6:00 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Mind sharing why?
  23. Jan 10, 2022 at 6:04 AM
    Outbound
    Aaron
    Northern Alberta
    My brother is a plumber. He says he only installs PEX on new builds and when doing renos, if at all possible he'll replace copper with PEX.
  24. Jan 10, 2022 at 8:52 AM
    One thing is copper is proven for many years and is not like working with a limp dick. Plus I can sweat copper in my sleep and can trust what I have done. I know everyone has there own opinion on things but I think most people use PEX because 1 it's cheap and 2 anyone can do it. You can have a bad joint in either of them if not done right. For us we just rather work with copper plus a nice straight pipe run looks 10 times better to me. When we run electrical or copper everything is run on a chalkline we are not trying for speed. I have a friend that's a full-time plumber and he will tell you he just uses PEX because it's fast an cheap and it makes him more money. But hey that's why we have choices.
    Darkness and FrenchToasty like this.
  25. Jan 10, 2022 at 8:56 AM
    Plus I know some people's argument is PEX doesn't freeze and bust as easy as copper which is true but if it's ran right you shouldn't have that problem anyway.
  26. Jan 10, 2022 at 8:58 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I'm not sure if it's really a PEX vs Copper but more of a PEX diameter vs 1/2 or 3/4 copper tubing...
  27. Jan 10, 2022 at 9:00 AM
    L_S_SHOE
    SE Louisiana
    2021 MGM TRD Pro
    Still have a tarp on the roof and can't find a trim carpenter to save my life but otherwise made out ok.
  28. Jan 10, 2022 at 9:02 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    You can get pieces for copper and pvc all over the place pex you can not if something goes bad. You need special tools for pex and not so much for copper and pvc. A lot of plumbers do not mess with pex if you have to call one out. There are pros and cons for both. I would stick with what you know and have access to.
    Bprose and Darkness like this.
  29. Jan 10, 2022 at 9:52 AM
    BlueCrushSC16
    Charleston, SC
    Special tools? Pex you need a tube cutter, crimp sleeves, and a crimper. Copper you need a torch, fire resistant cloth, leather gloves, solder, not to mention maybe having to drain the line so the copper will heat up properly for the solder joint. PEX is easier and faster. I don't care how good of a plumber someone is. You can't beat the speed of PEX install. As far as getting pieces for PEX, any big box store I.E. Lowes, Home Depot, Ace True Value, etc. has what I've needed.
    TomC843 and Cock-A-Doddle-Do like this.
  30. Jan 10, 2022 at 9:57 AM
    bwh
    bwh New Member
    Go with copper and press fittings. Just as fast as PEX and more durable.
    Also looks cleaner.
    BlueCrushSC16 likes this.
