Petroleum engineers
Discussion in 'General Tundra Discussion' started by T-Guy69, Jul 18, 2020.
  1. Jul 18, 2020 at 4:09 AM
    T-Guy69
    T-Guy69 [OP] New Member
    Long Island
    Black 2020 Tundra SR5
    A question to Petroleum engineers....
    My question is regarding the detergent level in gasoline.
    I know the difference in between the octane levels. But some sites say regular gas has the same detergent levels as Premium gas. Others say Premium gas has more.
    If you are not in the petroleum business, please site a reference. It help separate an opinion from fact.
  2. Jul 18, 2020 at 6:33 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I'm in the industry but don't know for sure as I don't work with gasoline blending directly. I believe it's the same as the detergents are in the additives, which I believe are the same for both premium and regular but I'll see what I can find out.
    P-Factor and Mountun Goat like this.
  3. Jul 18, 2020 at 6:38 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    ASTM has a specification for commercial gasoline. It covers chemical limits including required additives.
    Cpl_Punishment likes this.
  4. Jul 18, 2020 at 7:24 AM
    T-Guy69
    Long Island
    Thank you! There is a post on this site that mentioned Premium has more detergent. I think it was for Shell gasoline. But I can't find it. Thank you for looking into it for us.
  5. Jul 18, 2020 at 7:35 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I've actually seen ads at some of our stations as well saying "use premium for more cleaning" but I'm not sure if those are actually sanctioned by the company since all stations are independently-owned franchises now.
    This has been a hot button issue for me since a very biased story on the CBC saying that oil companies are trying to trick people into buying premium. Their "research" included asking a gas jockey at one of those independent stations which grade to put in their old Civic and running a car at 50 kph on a dyno and showing that the car with regular recorded the same amount of horsepower as the car with premium at that fixed speed. :der:
    Anyway, I'll try to remember to pull the fuel specs when I'm back at work in August.
  6. Jul 18, 2020 at 7:38 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    FYI, the majority of “petroleum engineers” focus on exploration and production of hydrocarbons from the ground. I work in the industry at one of the majors and there is the exact same additive package in every grade of gas.
    myt1, Black Wolf, Wynnded and 3 others like this.
  7. Jul 18, 2020 at 7:41 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Unless they work downstream, it’s more of a chemical/process engineering question.
  8. Jul 18, 2020 at 7:44 AM
    ninjajay
    Spoolston, TX
    Yeah most downstream folks I know are Chem E’s or Mechanical
  9. Jul 18, 2020 at 7:44 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Correct. OP, you might want to ask for chemical/ process engineers instead.
    Mountun Goat[QUOTED] likes this.
  10. Jul 18, 2020 at 7:47 AM
    prevent
    prevent New Member
    2014 5.7L Tundra SR5 DC
    TRD Catback Stillen CAI DAP Tune Tow Mirrors Light sensor Dashcam TRD Pro Grill LED Interior lights + DRL’s
    GODZILLA and CTB Mike like this.
  11. Jul 18, 2020 at 7:49 AM
    Jas4tundra
    Jas4tundra New Member
    Jasmeet
    2019 Tundra limited white
    Stock
    It’s same amount of additives volume. Your engine will run cleaner with premium gas due to higher octane, some brands have no ethanol in premium gas - That’s what I have been told by my distributor.
    prevent likes this.
  12. Jul 18, 2020 at 7:51 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Octane and ethanol have nothing to do with "running clean".
  13. Jul 18, 2020 at 8:08 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    There was a member here, @Cubanchem, that worked for Shell. His member name doesn't pop up now when referenced. Maybe he decided trying to educate us was a lost cause. :D If he said Shell premium grade had more detergent than Shell regular gasoline, then you can believe it. He was clearly an insider, a process engineer or lab technician, because he knew the knock engine tests inside and out.
    Like @Cpl_Punishment, I never worked in process engineering or blending, and I also doubt there is typically any difference in detergent additive content from regular grade to premium grade. Reason: Regular engines need detergents just as badly as premium engines. IMO, the higher price for premium is for higher octane number, not additive packages.
  14. Jul 18, 2020 at 8:14 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I am a process engineer working in a refinery. I've just never worked on the blending/ product supply side of the business. I'm interested in these type of questions but to do that job would require being on call all the time, which I have no desire to do any more.
    Also, our blending guru who used to answer all my stupid questions retired so I'll have to try to piece things together myself.
    Mountun Goat likes this.
  15. Jul 18, 2020 at 8:19 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @Cubanchem was last seen: Dec 21, 2016 ¯\_(ツ)_/¯
    Black Wolf likes this.
  16. Jul 18, 2020 at 8:23 AM
    JohnLakeman
    Oh...Yeah...Dang, I was reading posts nearly 4 years old in that thread! :eek: But...his info is still just as accurate. :D
    Wynnded[QUOTED] likes this.
  17. Jul 18, 2020 at 8:25 AM
    T-Guy69
    Long Island
    This must have been the post I was referring to. I also understand that if Shell premium grade has more detergent than Shell regular gasoline, that may not apply to other brands.
  18. Jul 18, 2020 at 8:25 AM
    T-Guy69
    Long Island
    No insult intended.
  19. Jul 18, 2020 at 8:28 AM
    As I understand it, Regular to Premium is all the same additives from the refinery/distribution points. You will run into a difference in "Top Tier" vs non top tier stations though. The additives are added at the station as I have been told. So Shell, for example, is a top tier fuel supplier and puts additional cleaners into their fuels on site, so they could put more into the premium than the regular.
  20. Jul 18, 2020 at 8:29 AM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    I work in the Petroleum equipment distribution industry and sell equipment to gas station owners and jobbers.
    I have asked this question my self. it's all about marketing and oil companies trying to convince the public their fuel is better.
    Here are some examples of oil company adds:
    What is Techron®? Techron® is a patented fuel additive with powerful detergents to help keep vital engine parts clean. Techron's unique formulation helps fight deposits in an engine's fuel intake system and minimize contribution to harmful combustion chamber deposits.
    Shell V-Power®NiTRO+ Premium Gasoline is an innovative premium formulation engineered with four levels of defense against gunk, corrosion, wear and friction to help keep your engine running like new*
    They put it in all grades of gas.
    STP gas treatment will accomplish the same thing.
    None of them will give you better gas mileage by the way.
  21. Jul 18, 2020 at 8:30 AM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    I agree. The "Premium cleans your engine better" claims are snake oil designed to lighten your wallet.
  22. Jul 18, 2020 at 8:33 AM
    I get the ethanol free 91 from a local station, and just periodically run Lucas through it.
  23. Jul 18, 2020 at 8:36 AM
    CTB Mike
    Southern Arizona
    GODZILLA[QUOTED] likes this.
  24. Jul 18, 2020 at 8:36 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    In the case of the Shell ad, I'm thinking "premium" means "of exceptional quality or amount; also : higher-priced" rather than something they only put in their 91 octane gasoline.
  25. Jul 18, 2020 at 8:37 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Even the 91 has ethanol there?
  26. Jul 18, 2020 at 8:38 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Elduder likes this.
  27. Jul 18, 2020 at 8:42 AM
    Most fuel around me has ethanol, too. There is only one station within 100 miles that I know of that has anything ethanol free. Luckily it's only a couple miles from the house.
  28. Jul 18, 2020 at 8:43 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    https://www.pure-gas.org/index.jsp?stateprov=WY
    The closest E0 place to me is about 50 miles, in a town I seldom drive to...:(
  29. Jul 18, 2020 at 8:45 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    All our 87 octane has 10% ethanol in it. I'd like to run E0 but not enough to pay ~20% more for 91.
  30. Jul 18, 2020 at 8:45 AM
